Pitot Static 411 413 followup post
Old June 17th 05, 03:46 AM
A Lieberman
Default Pitot Static 411 413 followup post
Well, I finally got my plane to another place to get my .411 and 413 pitot
static / transponder check, and it went from bad to worse.....
First person inspecting said everything was fine except for the VSI not
being hooked into the static system.
I take it to the new place (where I had it done 2 years ago) and they said
my transponder altitude encoder was off, and could not be adjusted, either
needs an overhaul or replacement, altimeter needs adjustment and overhaul.
I am just amazed at the wide differences of opinions.
My choices were, overhaul what I have, replace with an overhauled unit or a
brand new transponder. This is in order of expense with the first being
the lowest expense.
After talking with a couple of people, I decided to go with overhaul what I
got, as replacing it with another overhauled unit may be buying somebody
else's problem. For the Altimeter, I kinda expected it, since it was about
40 feet off when I compared field elevation to the altimeter setting, so no
surprises with that.
Transponder and Altimeter sent to Wichita for the overhaul, hope to be back
in the air early next week. Total cost, probably $1000.00 after all is
said and done.
Allen
Old June 17th 05, 05:56 AM
Mike Rapoport
A new encoder is only $160.
MU-2
"A Lieberman" wrote in message
a
the lowest expense.
I
about
no
back
said and done.
Allen
Old June 17th 05, 06:01 AM
A Lieberman
MU-2
Mike,
Is the encoder a separate component of the transponder?
Or am I paying labor for it to be installed into the transponder?
If I remember correctly, the estimate was about $400 for the overhaul of
the transponder, which I thought the encoder was inside the unit? I just
remember something like $600 for both, and I figured labor would jack it up
to $1000.
Allen
Old June 17th 05, 01:31 PM
Denny
Bend over, grab ankles...
Next time check with the group before spending money... From my POV,
the best solution would have been to purchase a new encoder (per Mike)
and a new altimeter (per me - never, never, never OH an instrument that
can kill you, when brand new is jsut a few bucks more!) and pay the
mechanic 'one time' to pull the old and replace with the new... Then
the old items can probably be sold to an instrument overhaul shop as
cores, recovering a few bucks... or on ebay ;()
Incidently, my encoder (ACK) older than the hills, mounted in a junker
Apache, with a ham fisted, incompetent, for a pilot, was adjusted and
passed the IFR check just fine a few weeks back... The altimeter was
brand new... It passed the check also...
denny
Old June 17th 05, 02:03 PM
Ron Natalie
Older encoders (especially certain manufacturers) have good days and bad
days. Oddly, I'm still using the same ancient TransCal that came with
my airplane (I thin this and the ASI is the only piece of original
instrumetnation I have) and it's still going strong. My altimeter
was progressively wonky at higher altitudes until one money hungry
FBO ripped me off for a new one (and oddly the core, which I got no
credit for disappeared). Particularly galling in that incident was
that they quoted me a price to pull everything out and bench test it
(which I've never had any other shop do). After the altimeter failed
they wanted an additional $200 to put the new one in. I figured if
the thing was on the bench already in the initial estimate, the only
thing additional that needed to be done an extra line in the log book
(which generally is covered when you pay list price for things).
The only thing that I can say is that I've dissed these guys baddly
enough in local forums (along with the local traffic reporting plane
company owner) that we've taken a good chunk of their business away.
Old June 17th 05, 05:27 PM
Mike Rapoport
The encoder is indeed separate from the transponder. It is a little box
attached to the static system that converts pressure information to an
electrical format that the transponder can understand.
MU-2
MU-2
Mike,
up
to $1000.
Allen
Old June 18th 05, 05:06 AM
Transpondets typically don't have any bearing on what altitude is being
sent out.
Most probably its a encoder problem. 90% or more can be adjusted back
into spec.
You can have a 125ft difference between the encoder and what the
altimeter is indicating.
Come to Dallas and I'll do a realistic ifr certification for you.
Did the shop tell you to send in your transponder?
Altimeters can be adjusted also.
There is a little Kollsman window adjustment which can change the
barometer set ie 29.92 and what the altimeter reads.
It's not legal to adjust unless your certified to do it. But Stevie
Wonder could do it in his sleep.
Dave
the lowest expense.
said and done.
Allen
Old June 18th 05, 05:07 AM
dave
sent out.
into spec.
Dave
MU-2
MU-2
Mike,
up
to $1000.
Allen
Old June 18th 05, 05:47 AM
Matt Barrow
ink.net...
How does it correct for variations in pressure, say, from 29.80 to 30.50HG?
Sharing static and pitot line Istvan Csonka Soaring 13 March 12th 05 04:00 AM
So I invested my US$6°°.....GUESS WHAT!!!... less than ten days later, I received money [email protected] Owning 1 January 16th 05 07:48 AM
Re; What do you think? Kelsibutt Naval Aviation 0 September 29th 03 07:55 AM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 08:25 AM
