Aluminum Extrusion for trailer ramp (USA)
Old June 26th 05, 12:16 PM
ttaylor at cc.usu.edu
Default Aluminum Extrusion for trailer ramp (USA)
I am looking for a supplier of aluminum extrusion or channel in the US
that would be suitable for making a ramp for a 15M ship. Any
suggestions?
Tim
Old June 26th 05, 01:14 PM
Papa3
Tim
McMaster Carr sells various aluminum alloys in square and rounded channel.
www.mcmaster.com
P3
"ttaylor at cc.usu.edu" wrote in message
suggestions?
Tim
Old June 26th 05, 08:15 PM
I once had a sheet metal shop bend some heavy gauge steel to make a
tail wheel ramp for my DG400. I cut it to length and welded on some
fittings for use with my existing ramp. The extrusions used in Cobra
trailers are custom manufactured and you won't find them as stock items
(they are too specialized).
Tom
Old June 27th 05, 01:17 AM
Bill Daniels
suggestions?
Tim
3" Square "C" channel works pretty well. I used 2.5" for my Nimbus trailer
and, while it works, it's proving a bit too weak and flexes a lot.
Old June 27th 05, 07:20 PM
Bill,
Thanks, I was thinking of trying some H-beam (I-beam on its side).
This would give twice the suppport of structural channel in the same
width. Would also slide over my current channel in the tralier floor.
I used 2" steel on my Nimbus 2 trailer, but the weight was heavy.
Tim
Old June 28th 05, 04:19 PM
Papa3
Tim,
I once had a sample of rounded-channel H-Beam that sounds just like
what you're looking for. I'll see if I can find the old invoice to
find out where it came from.
P3
Mercury another threat to aviation security? Aviv Hod Piloting 2 October 7th 04 06:24 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
