Redline (inspired by Gross Weight)
Old July 10th 05, 06:31 AM
Jose
Default Redline (inspired by Gross Weight)
So, how far over redline is it "ok" to operate an aircraft, and how
arbitrary is that red line (both on the tach and the airspeed indicator)
and how is it determined?
Jose
Nothing takes longer than a shortcut.
Old July 10th 05, 06:36 AM
Fred Choate
hehehe.......and how long could you fly over redline (airspeed) before
structural failure. Yikes....this one could get ugly
Fred
"Jose" wrote in message
Jose
Old July 10th 05, 06:38 AM
Dave S
Ask the aircraft and engine manufacturers.
Jose
Old July 10th 05, 07:33 AM
Robert M. Gary
Red line airspeed is a pretty specific thing. Unlike yellow line which
is only a problem in turb, red line is the point that things (like
wheel paints) begin to take damage. Red line is not a "if lots of
things happen it will be a problem" its a "something wasn't made strong
enough to do this".
Old July 10th 05, 09:25 AM
Peter Duniho
Check the engine manual. It will generally give detailed information about
what action(s) need(s) to be taken after exceeding some operational limit
for some amount of time.
For example (an invented example, not necessarily from any actual engine
manual), disasssembly and inspection of the engine if the RPM limit has been
exceeded for more than 5 minutes.
You'll find limits for RPM, temperature, manifold pressure, and possibly
some others.
Pete
Old July 10th 05, 09:57 AM
Ben Jackson
Well of course it all depends on how much over gross you are...
Ben Jackson
http://www.ben.com/
Old July 10th 05, 02:43 PM
Matt Whiting
Jose
Basically, the same answer as for the "gross" weight question.
Matt
Old July 10th 05, 03:01 PM
Kyle Boatright
Jose
IIRC, civil aircraft are tested to redline + 10% during the certification
process. That doesn't mean they won't safely fly at redline +11% or more,
but they have only been tested to redline +10%...
Old July 10th 05, 06:10 PM
Mike Rapoport
Jose
Nobody really knows. Redline on a piston airplane (turbines are different)
is usually set at 90% or Vd which is the highest speed demonstrated in a
dive without flutter or other problems. This is with a new airplane with
new hinges pivots ect.
MU-2
Old July 10th 05, 07:32 PM
Franklin Newton
Some red lines are only there because of noise (engine PA36-375)
k.net...
Jose
different)
MU-2
Gross Weight Fred Choate Piloting 153 July 14th 05 01:19 AM
Max gross weight Chris Piloting 21 October 5th 04 09:22 PM
Apache Alternate Gross Weight Jim Burns Owning 1 July 6th 04 06:15 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 05:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 08:32 PM
