"Refusing to Handle You"
Old July 16th 05, 11:08 PM
Mike Granby
Default "Refusing to Handle You"
So, an interesting thing happened today. I am at a fly-in at Hagerstown
and about to head back to my home-base at York (THV). I can see from
the PC they had there that there is a line of heavy rain and possibly
thunderstorms blocking my route back. There is no way around it to the
north, but there is a way to the south. So, instead of the usual
KHGR-SCAPE-THV to take me north of Camp David, I file a route via
HGR-MRB-EMI to so south and get in to York through the back door.
When I pick up my clearance, I am given the route via SCAPE, but I
"unable" that for weather, and they go away for a few minutes, and then
clear me as filed. I take off, and everything is fine, until I'm headed
southbound from the HGR VOR, when the Washington Center controller
calls me and says "Err, 8096J, Potomac Approach is refusing to handle
you, say intentions." So now, here I am, in the air with two small kids
on board, and being turned back towards what was, a while back at
least, some nasty weather. I ask for a hold at HGR to consider my
options, and luckily, by now the StormScope is showing the line has
dissipated. Now, I'm not happy, 'cos I know there's been cells
appearing along that route all PM, but I have little choice, so I take
the SCAPE route. All ends well, and we have an almost smooth ride, but
I was amazed that they gave me a clearance for that route, and then
wouldn't honor it! Comments???
Old July 16th 05, 11:58 PM
Steven P. McNicoll
"Mike Granby" wrote in message
Some TRACONs simply do not handle thruflights, that may be the case here.
One way around that is to make a stop at a field within that TRACON's
airspace. Then you're not a thruflight, you're an arrival and a departure.
Old July 17th 05, 12:07 AM
Mike Granby
at a field within that TRACON's airspace.
I know someone who pulled this trick on NYC TRACON once, but he even
had the nerve to call them as he neared the airport he'd file to, and
ask to change his destination to where he really want to go!
Apparently, there was much sighing from the controller, but in the end,
the pilot got what he wanted.
Old July 17th 05, 12:27 AM
Michelle P
Mike,
A phone call to their QA/QC dept. in order.
540-349-7500 main number
540-349-7548 QC dept. if no answer in a couple of days call the number
below.
540-349-7505 for the QC Manager.
Have the time, frequency and tail number ready. You will likely need to
leave a phone message.
Let them know they refused the hand off from Washington.
Michelle
Old July 17th 05, 01:00 AM
A Lieberman
Mike,
You are PIC. I would have declared an emergency and squawked 7700.
Go to http://asrs.arc.nasa.gov/report_sets_nf.htm and download the .pdf
file weather encounters. Happens more frequently then I ever expected.
Allen
Old July 17th 05, 01:28 AM
Steven P. McNicoll
"A Lieberman" wrote in message
What would the emergency be?
Old July 17th 05, 01:29 AM
Warren Jones
"Michelle P" wrote in message
nk.net...
Mike,
below.
Michelle
Michelle, what good would come of such a phone call? QA will give you lip
service, but you'd be wasting your time calling about this IMO.
Chip, ZTL
Old July 17th 05, 01:38 AM
Mike Granby
Well, I can just about understand if Potomac doesn't want to handle
routes like that, but they ought to find a way of making sure that
clearances don't get issued that contain those routes. I would have
liked to have been able to plan my other options on the ground with a
PC in front of me, instead of in the air relying on the variable
accuracy of 'spherics.
Old July 17th 05, 02:16 AM
Matt Whiting
That's a new one for me. I've not had that happen in 10+ years of
flying IFR.
Matt
Old July 17th 05, 02:17 AM
Matt Whiting
Shouldn't that be taken into consideration by ATC prior to issuance of
the clearance?
Matt
Flap handle activated Climb/Cruise switching Andy Smielkiewicz Soaring 5 March 14th 05 04:54 AM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
G103 Acro airbrake handle Andy Durbin Soaring 12 January 18th 04 11:51 PM
How do you handle your EFB in the cockpit? greg Instrument Flight Rules 5 November 17th 03 03:47 AM
Need door handle for 1959 Cessna 175 Paul Millner Owning 0 July 4th 03 07:36 PM
