Hi
A question for those who fly with Becker 4401-1 transponders. Normally the "Reply Indicator" triangle on the display of our transponder flashes briefly when the unit is interrogated, but otherwise it remains off. Today I noticed today that it was displayed continuously. This was when I was at low altitude and the transponder was shielded from ATC radar by a mountain. When I climbed higher it seemed to behave more normally, but still displayed for several seconds on some occasions. Is this normal behavior for this unit that I have just not noticed before, or has ours developed some kind of fault? I can't help thinking that a continuously "Reply Indicator" implies continues transmission, which can't be healthy. Thanks Ian |
Mine only responds to ATC queries, which increase or
decrease in relation to distance. If yours sends replies when out of ATC range I would suspect the unit. At 08:54 17 July 2005, Ian wrote: Hi A question for those who fly with Becker 4401-1 transponders. Normally the 'Reply Indicator' triangle on the display of our transponder flashes briefly when the unit is interrogated, but otherwise it remains off. Today I noticed today that it was displayed continuously. This was when I was at low altitude and the transponder was shielded from ATC radar by a mountain. When I climbed higher it seemed to behave more normally, but still displayed for several seconds on some occasions. Is this normal behavior for this unit that I have just not noticed before, or has ours developed some kind of fault? I can't help thinking that a continuously 'Reply Indicator' implies continues transmission, which can't be healthy. Thanks Ian |
Transponders will also reply to TCAS interrogations, even when out of ATC
radar range. Putting the glider in a metal hangar or glider trailer should adequately "shield" the transponder. If it replies then, I'd think you have a problem. Easy approach would be to just fly with it for awhile and see if it returns to the behavior you expect (g). bumper "Gary Evans" wrote in message ... Mine only responds to ATC queries, which increase or decrease in relation to distance. If yours sends replies when out of ATC range I would suspect the unit. At 08:54 17 July 2005, Ian wrote: Hi A question for those who fly with Becker 4401-1 transponders. Normally the 'Reply Indicator' triangle on the display of our transponder flashes briefly when the unit is interrogated, but otherwise it remains off. Today I noticed today that it was displayed continuously. This was when I was at low altitude and the transponder was shielded from ATC radar by a mountain. When I climbed higher it seemed to behave more normally, but still displayed for several seconds on some occasions. Is this normal behavior for this unit that I have just not noticed before, or has ours developed some kind of fault? I can't help thinking that a continuously 'Reply Indicator' implies continues transmission, which can't be healthy. Thanks Ian |
| Thread Tools | |
| Display Modes | |
| Operation without a transponder | flyer | Piloting | 11 | September 14th 04 09:48 AM |
| Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 04:09 PM |
| More on transponder petition | Ian Cant | Soaring | 1 | February 27th 04 07:37 PM |
| FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt | Juan E Jimenez | Home Built | 0 | August 6th 03 05:21 AM |
| FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt | Juan E Jimenez | Owning | 0 | August 6th 03 05:21 AM |
