Cambridge, SeeYou, and OLC
Old July 30th 05, 01:12 AM
Ray Lovinggood
Default Cambridge, SeeYou, and OLC
A friend uses a Cambridge model 20 (or 25?) gps and
made two flights last Sunday. The first flight didn't
last long and he took a relight. When he used SeeYou
to submit the flight to OLC, it was rejected (I don't
know if SeeYou rejected it or OLC) because, according
to him, 'too much time between recording points.'
What's the procedure for submitting a flight from a
flight log that will have more than one flight? How
would you select the flight you want to be scored by
OLC?
Thanks for any help,
Ray Lovinggood
Carrboro, North Carolina, USA
Old July 30th 05, 01:23 AM
Had the same thing happen-there was 'over 90 seconds between recording
points'.
In my case it was rejected by OLC and was due to GPS testing that also
effected other pilots, although not as badly.
OLC?
Ray Lovinggood
Old July 30th 05, 02:50 AM
5Z
In SeeYou set 1st marker near the takeoff and the 2nd marker near the
landing of one of the flights. Then optimize and submit. I've done
this in the motorglider if I have to start the engine and each half of
the flight is worthy of a claim.
-Tom
Old July 30th 05, 07:43 AM
Kilo Charlie
I've had this same problem occur when I started the logger too early and due
to some antenna interference prior to launch it had a gap. It is easily
changed by opening the flight log with Notepad or a similar program and
deleting the points prior to takeoff. If it occured in flight it may not be
possible to correct it however.
Casey Lenox
KC
Phoenix
Old July 31st 05, 11:16 PM
Ray Lovinggood
Tom,
My friend said your method works for him. Thanks!
Ray Lovinggood
marker near the
I've done
and each half of
-Tom
Old July 31st 05, 11:44 PM
Ray Lovinggood
Tom,
Ray Lovinggood
marker near the
I've done
and each half of
-Tom
Old August 2nd 05, 01:21 AM
Ian Strachan
Any alteration of a IGC flight data file with a text editor will cause
it to fail the (free) IGC Validation program that checks the file for a
number of things. An altered file will not be valid for any activity
that requires IGC-standards of flight data. This includes badge and
record flights, and competitions that use the IGC Validation check.
The alteration even of only one character in the flight data will cause
the Validation check to fail.
In terms of fix intervals, the Sporting Code makes the point that it is
the SETTING that the pilot that uses that matters. What happens in
flight may differ, particularly in conditions of poor GPS reception.
Short losses of GPS fixing should not invalidate a flight as long as it
is obvious that there was not time to carry out an intermediate landing
and re-launch. However, loss of fixes in an Observation Zone cannot be
remedied as there will be no evidence of reaching the point concerned.
Continuity of the flight record should be shown by a continuous
pressure altitude trace and, for motor gliders, a continuous engine
noise trace (even though no GPS fixes are being recorded, or, as often
happens, GPS altitude recording is lost for a time)
There is a significant difference between the pilot setting of fix
interval, and small variations that occur in the air due to adverse GPS
reception for short periods. Of course pilots should do everything
possible to ensure best antenna position, no kinks or breaks in the
antenna cable, adequate battery power to the GPS, and so forth. But
they should not be penalised by things out of there control when it is
perfectly obvious that no intermediate landing has occurred. IMHO, of
course!
Old August 5th 05, 04:07 PM
David Kinsell
Tried to respond to this before, apparently didn't make it out.
The Cambridge models 10, 20, and 25 have no capability of producing
a valid IGC file, and no validation programs exist for them. You
can alter one of those (pseudo-)IGC files all you want, it won't
be detected. Even if you don't own one of these things, you could
fabricate a flight trace, label it as coming from one of them, and
make it look authentic. Kinda kills the idea of IGC being a universal,
secure format, doesn't it?
-Dave
course!
Old August 5th 05, 04:20 PM
Jack
a valid IGC file....
You lost me there, DK.
If these Cambridge files are not valid IGC files, how is their lack of
security and universality of any relevance to the discussion of (valid) IGC
files' security and universality?
Jack
Old August 5th 05, 06:46 PM
Eric Greenwell
Since we know those recorders don't produce IGC files, won't we
immediately realize they aren't authentic IGC files, but only "IGC
format files"? For example, the OLC uses "IGC format files" from
Cambridge recorders for their purposes, but only after verifying the
security of the recorder's file in proprietary Cambridge format.
I don't think so. The fake files are easily determined to be fake simply
by looking at the file (no fancy verification program needed), so what's
the problem?
Eric Greenwell
Washington State
USA
