why my plane stalls
Old August 12th 05, 06:31 PM
Grandss
Default why my plane stalls
Ok if someone could explain me that, I will be very happy
I have a simulator, if i pitch up OK, but if I pitch down, my plane
stalls and i don't understand why.
thank's
Old August 12th 05, 06:54 PM
Ron Garret
Your simulator is broken (or you have not described the situation
accurately).
rg
Old August 12th 05, 06:58 PM
Gary Drescher
"Grandss" grandss@nospam wrote in message ...
I have a simulator, if i pitch up OK, but if I pitch down, my plane stalls
It should be just the opposite: pitching up too far can cause a stall, but
pitching down is supposed to *recover* from a stall.
So there are two possibilities. Either the simulator is flawed, or else
you're mistaken to think that the plane is stalling when you pitch down. Can
you tell us exactly what the plane does that leads you to conclude that it
is stalling?
--Gary
Old August 12th 05, 07:08 PM
Andrew Gideon
You're inverted.
- Andrew
Old August 12th 05, 07:54 PM
Grandss
is stalling?
--Gary
Hi,
plane stalls really when i pitch down.
I'm not sure to know exactly how it have been determined but i try to
explain.
A plane stalls in my case if liftcoefficent for a cambered airfoil with
a plan trailing edge flap is equals to zero.
Flaps to calc. liftcoefficient are landing flaps and ailerons.
Old August 12th 05, 08:31 PM
TripFarmer
Bottle to Throttle..........8 hours.
In article , grandss@nospam says...
thank's
Old August 12th 05, 10:48 PM
Dan Luke
hee-hee!
Old August 13th 05, 01:26 AM
george
Grandss wrote:
Gary Drescher a =E9crit :
I have a simulator, if i pitch up OK, but if I pitch down, my plane sta=
lls
It should be just the opposite: pitching up too far can cause a stall, =
but
you're mistaken to think that the plane is stalling when you pitch down=
.. Can
you tell us exactly what the plane does that leads you to conclude that=
it
is stalling?
--Gary
Hi,
explain.
Go to your local aero club or flying school.
Get into a REAL aeroplane with an instructor and find out what happens
when you pitch the nose down.
And don't use terms that you don't understand....
Old August 13th 05, 01:31 AM
Greg Farris
thank's
Please don't call it a plane.
Readers here may take it badly, present company included.
Old August 13th 05, 01:42 AM
If you're on a simulator, maybe your joystick or yolk is set up
incorrectly? (pitch reversed).
As anyone on this group will tell you in an instant, stalling is not
about pitch *per se*, but angle of attack. That said, one pulls up to
case a stall, and pushes down to get out of one -- unless you're
inverted, or your controls are rigged backwards (which, unfortunately,
has been known to happen).
-- dave j
thank's
My first aerobatic lesson Marco Rispoli Piloting 6 April 13th 05 03:21 PM
Three more newbie Qs, if you don't mind :) Ramapriya Piloting 17 November 7th 04 06:03 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 08:27 AM
