How to break your Garmin 396
Old August 28th 05, 04:04 AM
Dan Luke
Default How to break your Garmin 396
Just let battery run down with the USB XM weather antenna connected.
I did this to see how much battery life I would get with the screen set
at half brightness (5+ hours), but when I reconnected external power,
the unit begin an endless series of re-boots, never getting past the "I
agree" lawyer acknowledgement screen. If I disconnect the XM antenna,
the unit will boot up and run normally, but if I plug the XM back in,
the unit shuts down.
By fiddling around with the unit for a while, I discovered that by
starting the unit in simulator mode, then plugging in the XM antenna,
then putting the unit back in normal mode I can get the whole mess up
and running as it is supposed to.
I installed the latest firmware rev (2.40) but that didn't help, so I've
e-mailed Garmin tech support for help. Stay tuned for their response.
Dan
C172RG at BFM
Cable break recovery spin entry... as previously discussed [email protected] Soaring 26 July 3rd 05 09:28 AM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 02:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 5th 04 12:55 AM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 07:57 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 10:32 PM
