Cherokee battery box repair
Old August 29th 05, 02:59 PM
Default Cherokee battery box repair
Hey all... I've got the plane down for an annual and have discovered a small
weeping leak in the bottom of the battery box (where the drain nozzle attaches). Am I
correct in recalling that the box is made of tin and the nozzle of copper? Will
regular Lead/Tin (60/40) solder this, or do I need some special solder for it? It
seems like it should be repairable, since it looks like it was *made* by soldering.
Oh yeah, and of course a good cleanup and repaint is in order back there.
Very little corrosion back there, but enough to do a bit of cleanup.
-Cory
* Cory Papenfuss *
Old August 29th 05, 03:19 PM
Mike Rapoport
The battery boxes that I have seen are made of aluminium.
MU-2
small
attaches). Am I
Will
it? It
soldering.
-Cory
* Cory Papenfuss *
Old August 29th 05, 05:29 PM
So far there's one vote for aluminum, one for stainless, and one for tin, eh?
I'm sure it depends on which aircraft and model year, but I'm sure hoping I can get
away with some form of solder. A friend of mine had to fix his '65 Cherokee 150's
box... probably the same as my '69. He got some funky solder/brazing rod that
apparently worked on his. What I see on min is not magnetic, but doesn't look like
aluminum either. Seems too heavy to be aluminum, although I haven't removed the
solenoid from the side of the box yet, either.
Speaking of that, anyone figured out the purpose of the diode and resistor
back there on that vintage PA-28? As near as I can tell from the schematic, it allows
the alternator to slowly charge a completely dead battery with the master off.
Then will allow the alternator/partially charged battery to close the master and
charge it properly. Of course all this would require the alternator to self-excite...
something I didn't think they were typically set up to do. Thoughts?
I just figured I'd ping the collective wisdom here since I'm sure lots of
folks have dealt with it. I just didn't like the idea of weeping battery acid on the
airframe. Since I broke it further upon removal, now I *have* to fix it.
-Cory
Aaron Coolidge wrote:
: wrote:
: : Hey all... I've got the plane down for an annual and have discovered a small
: : weeping leak in the bottom of the battery box (where the drain nozzle attaches). Am I
: : correct in recalling that the box is made of tin and the nozzle of copper? Will
: : regular Lead/Tin (60/40) solder this, or do I need some special solder for it? It
: : seems like it should be repairable, since it looks like it was *made* by soldering.
: My Cherokee's battery box is made of stainless steel. It also had a little
: seepage at the drain tube. Someone had brazed (!) a galvanized (!) pipe
: flange onto it, and threaded a little 1/8" pipe nipple into it. The braze
: broke off the battery box (go figure).
: I TIG welded a patch onto the bottom, and TIG welded a little length of
: 316 stainless pipe to the bottom of the box. All is now well.
: Aaron C.
* Cory Papenfuss *
Old August 29th 05, 07:26 PM
John Kunkel
off.
master and
self-excite...
I've always assumed they were there to prevent the volotage induced by the
collapsing magnetic field around the solenoid from spiking the electrical
system.
Old August 29th 05, 07:50 PM
John Kunkel wrote:
: I've always assumed they were there to prevent the volotage induced by the
: collapsing magnetic field around the solenoid from spiking the electrical
: system.
I don't think so for two reasons:
1. The starter operating would require the master solenoid to be closed, so the
diode/resistor pair is shorted out and not a factor.
2. The direction of the diode is the wrong way to be a path for flyback current in the
starter solenoid.
Assuming the master solenoid stays closed, the battery should do a pretty good
job of absorbing voltage transients from the starter.
Good theory though.... I'm sure there are some setups where it's set up that
way... I just don't think this is one of them.
-Cory
* Cory Papenfuss *
Old August 29th 05, 10:06 PM
nrp
I don't know Cherokee electrics, but does it maybe offer a way to (very
slowly) charge the battery thru the external service plug?
My Cessna 172M has a funny diode-resistor circuit like that in the
battery circuit in which that's the only reason I can see for it. It
is not described in the POH or even the service manual. Otherwise with
a completely dead battery, if I used the ground service plug to start
it, there still wouldn't be anything in the battery to initialize the
alternator.
Flyback diodes don't usually have a resistor in series with them.
Old August 29th 05, 10:48 PM
Another good idea, but the schematic has rather clearly shown the
diode/connector setup for the external connection, but has it shown as "optional."
This diode/resistor is in addition to that.
nrp wrote:
: I don't know Cherokee electrics, but does it maybe offer a way to (very
: slowly) charge the battery thru the external service plug?
: My Cessna 172M has a funny diode-resistor circuit like that in the
: battery circuit in which that's the only reason I can see for it. It
: is not described in the POH or even the service manual. Otherwise with
: a completely dead battery, if I used the ground service plug to start
: it, there still wouldn't be anything in the battery to initialize the
: alternator.
: Flyback diodes don't usually have a resistor in series with them.
* Cory Papenfuss *
Old August 29th 05, 11:57 PM
tom418
eh?
I can get
Cherokee 150's
that
look like
removed the
off.
master and
self-excite...
Hence the term : "Alternator Source- Power Relay energizing circuit"
used by Piper, in my Cherokee's Operating Manual
-Cory
discovered a small
attaches). Am I
copper? Will
for it? It
by soldering.
little
braze
: Aaron C.
* Cory Papenfuss *
Old August 30th 05, 01:32 AM
John Kunkel
electrical
: system.
so the
current in the
starter solenoid.
I was thinking of the collapsing field around the master contactor solenoid.
Checking the battery in a Cherokee nobody Owning 15 May 5th 05 01:39 PM
Calibrate? Repair? Adjust? RST Engineering Owning 3 April 4th 05 02:41 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 02:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 02:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 07:32 PM
