simple prop overhaul
Old August 29th 05, 10:25 PM
Marty from Florida
Default simple prop overhaul
At my annual, the IA said my plane is in great, clean safe condition, but I
need to have my prop overhauled. It's a 2 blade aluminum prop on a Lycoming
235/L2 engine. My understanding is that it just needs a clean up, some paint
and filler, then a balance and return to service. Has anyone done this
recently, and what should I expect to pay?
Thanks all.
Marty
Old August 29th 05, 11:00 PM
George Patterson
Not recently, but about 12 years ago, my 150 prop overhaul cost about $500 at
Eastern Propellor Service.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old August 30th 05, 01:00 AM
Bob Fry
"MfF" == Marty from Florida marty@-x-x-x- remove -x-x- worth.net writes:
MfF At my annual, the IA said my plane is in great, clean safe
MfF condition, but I need to have my prop overhauled. It's a 2
MfF blade aluminum prop on a Lycoming 235/L2 engine. My
MfF understanding is that it just needs a clean up, some paint
MfF and filler, then a balance and return to service. Has anyone
MfF done this recently, and what should I expect to pay?
I had the above done plus a check of the pitch and dressing of the
leading edge to a 71" C-90 prop for $375 at Stockton Propeller in
N. California...but it wasn't a complete overhaul. The latter would
have involved a magnaflux check and maybe some other checks.
Old August 30th 05, 03:23 PM
joe
If you are operating under part 91 your IA is wrong...you may not have
to overhaul it
Old August 30th 05, 04:34 PM
Newps
$1500-$2000.
Thanks all.
Marty
Old August 30th 05, 09:00 PM
George Patterson
Newps wrote:
$1500-$2000.
For a fixed-pitch aluminum prop???
George Patterson
Old August 30th 05, 09:08 PM
Marty from Florida
I called our local prop shop and got a quote for $ 570.00 to sand, paint and
test my simple propeller + $ 100 to remove and install it. In conversation,
it turns out that the entire fleet of 152's with the McCaully prop now has 2
AD's on them. One is a recurring annual item, the other addresses the way
the prop is fastened to the engine. My best venue would be to toss the prop
and get a Sensenich which has been in use on these planes for 20 years and
has no issues or AD's.
If anyone has a prop that would fit my 1982 C152 with a Lycoming 0-235/L2
engine, please let me know. I don't want to have to service a prop annually!
Thanks again.
Marty
"Marty from Florida" marty@-x-x-x- remove -x-x- worth.net wrote in message
I
Lycoming
paint
Thanks all.
Marty
Old August 31st 05, 12:39 AM
Mike W.
annually!
Thanks again.
Marty
After reading what I think is the recurring AD for that prop, it's not
necessarily an overhaul, but an inspection. It is to check for cracks at the
bolt holes around the hub. This inspection is to be done every 800 hrs or 12
months, if it's OK the prop is painted and returned to service. The other AD
(one-time) has to do with specific bolts and a spacer used to mount the
prop. So you said it was $100 to r/r the prop? How much is a dye test for
cracks? to paint?
Hello, my name is Mike, and I am an airplane addict....
Old August 31st 05, 03:39 AM
Marty from Florida
Mike,
Thanks for the comment. I'm pretty certain the one time AD for the bolt
holes has been complied with, but I'll check to be sure (I've only had this
152 for a few months). The annual inspection was completed last year with a
dye test for $ 52.00 from a mechanic who is 1,400 miles from where the plane
now lives. I called a local shop, and was told a dye test involved 80% of a
complete overhaul, in that the prop had to be pulled, scraped, tested, and
re-painted. I'm confused about how someone could do this for $ 52.00, but
I'm also in Palm Beach Florida, where dishonesty is only superseded by
incompetence. (Sorry for the bitching, but I've been handed a lot of
nonsense from professionals in my area). I had a new alternator installed by
a very expensive shop, only to find the main harness and wires were pressed
hard against an exhaust pipe.
The reason I need an overhaul is not to comply with the AD, but because the
prop is rough. No visible nicks or cracks, and it doesn't have any
noticeable vibration, but the surface is anything but smooth. At annual, the
IA said it needed an overhaul to be airworthy, and when I found out what it
would cost to just sand and paint a prop, I was amazed. If any A&P's read
this, please toss in an opinion. If anyone has a replacement Sensenich
72CKS6-0-56, please drop me an email.
Marty
"Mike W." wrote in message
message
0-235/L2
annually!
Thanks again.
Marty
12
AD
cracks? to paint?
Old August 31st 05, 01:46 PM
were in fl ?
last prop oh last mo. $652
jon
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
my ignorance LCT Paintball Home Built 25 April 9th 05 06:54 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
Major Overhaul Jim Weir Owning 10 June 8th 04 05:12 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
