I've been researching how to replace an old AC Spark Plug CHT probe in our
Aztec. AC doesn't make them anymore and the replacement Rochester brand probe operates at a different resistance range requiring the gauge to be removed, shipped out and recalibrated. Not a fun proposition. Rumor, and a couple parts houses, have told me that the American Bonanza Society published an article about this problem and a solution is to install an 82ohm resistor inline with the probe to account for the difference between the AC and the Rochester gauges. Sounds easy enough. Is there a group member that belongs to the ABS that could verify the article and possibly post or email me a copy?? Any other thoughts or comments about this?? Thanks again, again!! Jim |
On Wed, 31 Aug 2005 12:53:46 -0500, "Jim Burns"
wrote: I've been researching how to replace an old AC Spark Plug CHT probe in our Aztec. AC doesn't make them anymore and the replacement Rochester brand probe operates at a different resistance range requiring the gauge to be removed, shipped out and recalibrated. Not a fun proposition. Rumor, and a couple parts houses, have told me that the American Bonanza Society published an article about this problem and a solution is to install an 82ohm resistor inline with the probe to account for the difference between the AC and the Rochester gauges. Sounds easy enough. Is there a group member that belongs to the ABS that could verify the article and possibly post or email me a copy?? Any other thoughts or comments about this?? IMHO, an accurate CHT indication is one of the things that can tend to contribute to engine longevity. Unless you were planning on installing a PMA'd primary replacement http://www.buy-ei.com/Single%20Primary.htm or http://www.buy-ei.com/Dual%20Primary.htm at some point in the near future, I would recommend doing the "right" thing and getting your probe replaced and your indicator calibrated. I probably would consider installing a resistor to be a minor alteration, but would still recommend getting the system checked/cal'd. Actually, I would recommend getting both CHT gages cal'd and replacing both probes. I allegedly used to maintain a bunch of working GA aircraft (including PA23's), one of the things we ALWAYS did at engine o-haul was replace the CHT and oil temp probes, and have the gages cal'd (APoLH). Did the EGT/TIT systems also, but we had the capabilities to do 'em in-house. Compared to the cost of engine overhaul/installation, this is cheap peace-of-mind. Remember, this advice is worth exactly what you paid for it... TC |
And remember, there is an absolutely wonderful and free calibration point at
212°F available for nothing more than a pan of water and a hotplate. Jim wrote in message ... Remember, this advice is worth exactly what you paid for it... TC |
RST Engineering wrote:
And remember, there is an absolutely wonderful and free calibration point at 212°F available for nothing more than a pan of water and a hotplate. If you're at sea level. If your elevation is substantially different from that, you need to look up the boiling point of water. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
I
guess we could also calibrate it with a pan of oil, a hot plate, and a candy thermometer. RIght on! This is the sort of thing that is taught in high school physics (or was, in my day, right after the earth first cooled) denny |
But I think the width of the needle of our gauge will compensate for that.
It's an old style gauge with only a dot at 200F and the next dot is at 400F. The best we can do is try to keep the needle below the 400F dot a tad. I guess we could also calibrate it with a pan of oil, a hot plate, and a candy thermometer. Jim "George Patterson" wrote in message news:cgvRe.12917$LK.8705@trndny09... RST Engineering wrote: And remember, there is an absolutely wonderful and free calibration point at 212°F available for nothing more than a pan of water and a hotplate. If you're at sea level. If your elevation is substantially different from that, you need to look up the boiling point of water. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
BTW, that 82 ohm power resistor (??) you need is available at www.mouser.com
5 watt cement coated fireproof resistors (280 CR5 series) are 39 cents in onesies. 3 watt flame retardant resistors (283 series) are also 39 cents in onesies. Mouser has no minimum order and a decent shipping policy. Somebody needs to measure the current that these things are sucking. In order to dissipate 1 watt in an 82 ohm resistor, you need a bit more than 100 mA (0.1 amps) to flow. My gut says that this is not happening. Jim "Jim Burns" wrote in message ... But I think the width of the needle of our gauge will compensate for that. It's an old style gauge with only a dot at 200F and the next dot is at 400F. The best we can do is try to keep the needle below the 400F dot a tad. I guess we could also calibrate it with a pan of oil, a hot plate, and a candy thermometer. |
Thanks Jim, I appreciate the link.
I also found some 82ohm 2W 5% flameproof resistors on ebay. Some more goggling found that this Rochester probe w/82ohm resistor "work around" has been used by owners of Pipers, Bonanzas and Commanders, all with the AC Spark Plug CHT gauge. The 82ohms is the one constant in everything I've read, the W varied between 2 and 3Watts and the tolerance was either 2 or 5%. Not having a background in electronics, what ultimate difference would a resistor of higher wattage rating have on the circuit, the gauge, or the probe? If the circuit is only drawing mA's, 1) are there "smaller" mA rated 82ohm resistors available or 2) with a mA rated resistor would the required ohm rating change? Forgive my ignorance regarding resistors, I basically understand what they do, but do not know the implications of the sizes/capacities. I'm just looking for a way to get out of several hours of tedious PITA work with my upper torso stuffed up underneath our panel. Instrument Tech of Dallas TX seems to have quite a bit of experience with the combo and emailed me the American Bonanza Society newsletter that contains the article. The original question was published June 1990, and the explanation and work around was published some time shortly after however I do not have that date. Jim "RST Engineering" wrote in message ... BTW, that 82 ohm power resistor (??) you need is available at www.mouser.com 5 watt cement coated fireproof resistors (280 CR5 series) are 39 cents in onesies. 3 watt flame retardant resistors (283 series) are also 39 cents in onesies. Mouser has no minimum order and a decent shipping policy. Somebody needs to measure the current that these things are sucking. In order to dissipate 1 watt in an 82 ohm resistor, you need a bit more than 100 mA (0.1 amps) to flow. My gut says that this is not happening. Jim "Jim Burns" wrote in message ... But I think the width of the needle of our gauge will compensate for that. It's an old style gauge with only a dot at 200F and the next dot is at 400F. The best we can do is try to keep the needle below the 400F dot a tad. I guess we could also calibrate it with a pan of oil, a hot plate, and a candy thermometer. |
Jim Burns wrote:
Not having a background in electronics, what ultimate difference would a resistor of higher wattage rating have on the circuit, the gauge, or the probe? If the circuit is only drawing mA's, 1) are there "smaller" mA rated 82ohm resistors available or 2) with a mA rated resistor would the required ohm rating change? Forgive my ignorance regarding resistors, I basically understand what they do, but do not know the implications of the sizes/capacities. I don't have a background in electronics, either, but I'd think 3 watts is way overkill from an electrical point of view, *but* a higher power rated resistor is also more robust from a mechanical point of view, and may stand up better to the vibration environment. Just an idea from an ignorant observer. Dave |
![]() I don't have a background in electronics, either, but I'd think 3 watts is way overkill from an electrical point of view, *but* a higher power rated resistor is also more robust from a mechanical point of view, and may stand up better to the vibration environment. Just an idea from an ignorant observer. Dave You summed up my thinking pretty close. I'm thinking if 3W is overkill, what are the downsides of it? Shorter probe life? shorter gauge life? shorter resistor life? If it doesn't detrimentally effect the operation of either the probe or the gauge and the life of the components isn't compromised, then the only downside I see is about $0.10. But like I said, I don't have much knowledge in this area but I'm willing to learn so I defer to the pros. Thanks Jim |
Old CHT probe replacement | Frank Ch. Eigler | Owning | 3 | August 31st 05 03:22 PM |
T.E. Probe Question | KP | Soaring | 2 | July 27th 05 02:58 PM |
Replacement JPI EGT probe | Robert M. Gary | Piloting | 4 | July 16th 05 02:28 AM |
Cleaning a 3-way TE probe | Jack Glendening | Soaring | 37 | November 5th 03 06:45 PM |
Broken line to Oil Temperature Probe, Repairable? | rkane33 | Owning | 2 | July 25th 03 03:19 AM |
