Can you see me now?
Old September 5th 05, 04:09 AM
Default Can you see me now?
Today I took a step toward settling a question I've had for a long
time. After making sure the frequency was pretty empty, I went ahead
and made the call:
Me: Pitt Approach, Schweizer glider 34367.
PA: Aircraft calling Pitt, say again call sign.
Me: Pitt Approach, this is Schweizer glider 34367.
PA: pause Glider 34367, go ahead.
Me: Schweizer 34367 is five miles southeast of Washington County at six
thousand one hundred. Just wondering, can you actually see me on your
radar?
It's something I've always wondered about. Our club's airport (Bandel,
22D) has a few of the house thermals just south of the approach course
for the ILS 27 at Washington County (KAFJ). It's not a very busy
airport, but they get a few King Airs and bizjets every day. If a
couple of us came close, could approach even see a primary return from
the glider and give advisories? (Of course they wouldn't have our
altitude, but even so.)
PA: bemused Hang on a second 367, let's have a look.
PA: There you are, 367, looks like, are you more south-southeast of
Washington County?
Me: Pitt approach, 367, yeah, south-southeast is more accurate. Thanks!
pause
PA: Glider 367, are you heading westbound?
Me: 367 is circling at my present position.
Now I was in our club's lowly 2-33, which has that huge aluminum wing.
Has anyone ever tried this in a sailplane that doesn't have any big
metal parts? I'm not so sure they could see a glass ship...
--Tom
Old September 5th 05, 06:40 AM
BTIZ
Our local ClassB approach control can readily spot our club 2-33 and 1-26,
also our Grob 103 and LS-4, primary radar only. I tend to listen up on the
frequency when I'm up in "airliner altitudes", sometimes that can be as low
as 7-8000ft MSL, I hear them call "traffic, suspected glider altitude
unknown" to the airliners, and sure enough, it's me they are talking about.
Once I even called them to report 4-6 gliders working the "ridge" between
two fixed points at altitudes from 14K and below after watching about 4
airliners circumnavigate the ridge. He appreciated the call.
BT
and made the call:
radar?
Washington County?
pause
--Tom
Old September 5th 05, 08:12 AM
bumper
Flying out of Minden, NV, we are in Reno Approach's area. They have assigned
all glider traffic the VFR transponder code 0440, so they know that it's a
glider and they have the altitude to. Of course a transponder squawk doesn't
get lost in the clutter as a primary return can.
Bottom line, if you want to be seen by ATC and aircraft with TCAS, and
especially if you fly where the heavy iron does, consider installing a
transponder.
all the best,
bumper
"BTIZ" wrote in message
news:M_PSe.8279$ct5.6666@fed1read04...
low as 7-8000ft MSL, I hear them call "traffic, suspected glider altitude
about. Once I even called them to report 4-6 gliders working the "ridge"
between two fixed points at altitudes from 14K and below after watching
about 4 airliners circumnavigate the ridge. He appreciated the call.
BT
and made the call:
radar?
Washington County?
pause
--Tom
Old September 6th 05, 07:01 PM
Andy
Yes primary radar can see glass ships. The metal push rods provide a
visible return. I once enjoyed having Tucson approach vector airliners
round me while I climbed on the edge of their class C airspace. That
was in an ASW 19. The radar can be set to reject slow primary targets
so they may not see you if they are not looking for you.
Being a possible primary target won't give you much protection though
unless you are talking to ATC. At best conflicting traffic will get a
report of "traffic 12 o'clock slow moving altitude unknown". You will
be invisible to TCAS.
