LS4 trim
Old September 10th 05, 06:09 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
Default LS4 trim
Flying a club LS-4a last weekend, trying to trim for a sandwich break I couldnt get a smooth speed. I figure this is a balance issue, as we would rise to 65 knots then fall back to 45 then up again. I would be 95kg clothed, no extra gear. I tried different altitudes with the same result, although higher speeds smoothed the dolphin tendency a bit, I wasnt in that much of a hurry. What am I missing?
Old September 10th 05, 04:00 PM
Udo Rumpf
If you fix the elevator, in your case a no flap glider, there will be only
one trim speed. With the shift of the CofG the trim speed changes
within a narrow range. Only in ideal conditions can the glider
maintain a fixed speed. Mostly it will speed hunt to find its equilibrium
All gliders should not have any divergent, in other words the speed
hunting should not get worse and should stabilize within a narrow
range. To experience a minimum speed excursion a CofG should be
in the middle range or a bit beyond, The cycles will either be shorter
and deeper with the CofG more forward and longer and flatter with
the CofG further back. The trim lever is used to set the "average"
speed at which those cycles occur.
Udo
"bagmaker" wrote in message
bagmaker
Mooney Electric Trim Problem [email protected] Owning 2 September 5th 05 07:16 PM
Cherokee Electric Pitch Trim Jonathan Goodish Owning 4 November 18th 04 03:43 AM
A very basic question Ramapriya Piloting 45 November 9th 04 02:57 PM
Ramifications of Cherokee Trim Jackcrew Failure Bob Chilcoat Home Built 23 June 9th 04 03:48 AM
Lance vx. 6/300 Bridgadoon Owning 27 September 28th 03 09:20 PM
