What's the defination of a motorglider?
John Morgans wrote: OK, here's a question. Does a seaplane motoglider exist? If someone were to make one, would it be eligible to be flown as a motoglider, and therefore be able to have a pilot (without a medical) fly it legally as a motoglider? And yes, I did Google, first. g |
John Ammeter wrote:
What's the defination of a motorglider? John My GUESS would be any airplane that is designed to be taken off under power and intentionally powered down. Oh and yes, most important, registered that way! I supposed you could built a 747 look alike (remember the post about the 747 plans?) and register it as a glider (with what about a 5 to 1 glide ratio!). Now that would be interesting! John |
Dick Schreder started a self-launched seaplane glider project back in the
1970s. I believe he was going to call it a HP-21. The project was never finished and was donated to Penn State University (PSU) prior to his death. The HP-21 was to be a two-place, side-by-side, self-launching, amphibious sailplane with automatic extending and retracting engine. Design specs called for a foam and fiberglass hull, retractable gear and wings constructed of metal and foam (like the HP-16, RS-15 and HP-18). Dick flew seaplanes in WW-II and was the first sinking of a U-Boat by a US aircraft. (It is a great story. It and others can be found in the book "10,000 Feet and Climbing - The Aviation Adventures of Richard E Schreder.) The HP-21 was going to be an attempt to combine his love of soaring with his love of "flying boats." The PSU Soaring Club has what remains of the project listed in the "Trading Post" section of http://www.soaridaho.com/Schreder. An article about the HP-21 appeared in "Soaring" many years ago. I have a copy and will posted on the "Schreder Designs" web site when time is available. Wayne HP-14 N990 "6F" http://www.soaridaho.com/ "Morgans" wrote in message ... OK, here's a question. Does a seaplane motoglider exist? If someone were to make one, would it be eligible to be flown as a motoglider, and therefore be able to have a pilot (without a medical) fly it legally as a motoglider? And yes, I did Google, first. g -- Jim in NC |
"Wayne Paul" wrote An article about the HP-21 appeared in "Soaring" many years ago. I have a copy and will posted on the "Schreder Designs" web site when time is available. Wayne Thanks. When you do, give a shout back here, if you have the time? -- Jim in NC |
"John Ammeter" wrote in message ... What's the defination of a motorglider? There are some pretty strict definitions, as I recall, having to do with weight to area, or span, and glide performance, IIRC. I'll try to see what I can find. -- Jim in NC |
UltraJohn wrote:
I supposed you could built a 747 look alike (remember the post about the 747 plans?) and register it as a glider (with what about a 5 to 1 glide ratio!). Now that would be interesting! I bet it would have a LOT better glide ration than that! I seem to remember a story about some airliner that ran out of fuel due to a mix up with metric vs English units, I think they had a malfunctioning fuel computer which made it necessary to do the calculations manually. Anyway, if I remember right, it glided around 85 miles from an altitude of 35,000 ft. If it landed at sea level, which I doubt, the glide ratio was nearly 13 to 1. -- Chris W Gift Giving Made Easy Get the gifts you want & give the gifts they want http://thewishzone.com |
"Morgans" wrote There are some pretty strict definitions, as I recall, having to do with weight to area, or span, and glide performance, IIRC. I'll try to see what I can find. After more than an hour of searching, I found the motor glider specs he http://www.sonex-ltd.com/motorglider_definition.html It could glide like a dog, but it has to carry no more than two, not exceed 1874 pounds, and the maximum weight to wing span squared can not exceed .62 lb. / ft squared. So that means that at maximum weight, you would need a wingspan of about 55 feet. Doable? I think so. For a seaplane, or amphibian, it would have to have some type of pontoons or floats on the tips, or it would hit the tips, on the slightest bit of rocking. Not a problem. How about the rating needed? For a powered glider, a glider rating, with an endorsement for self launch, I think, is all you need. What about launching from water? More endorsements, or is there one for water to add to glider? Would you have to have a single engine fixed wing land/seaplane? One thing I can say, is that I have never seen _this_ question here, (or anywhere) before! g -- Jim in NC |
So that means that at maximum weight, you would need a wingspan of about 55 feet. -- Jim in NC gee that'd be fun to dock ; ( |
"T o d d P a t t i s t" wrote in message ... "Morgans" wrote: After more than an hour of searching, I found the motor glider specs he http://www.sonex-ltd.com/motorglider_definition.html It could glide like a dog, but it has to carry no more than two, not exceed 1874 pounds, and the maximum weight to wing span squared can not exceed ..62 lb. / ft squared. These limits were adopted to prevent people from registering everything under the sun as a glider. :-) I've seen some designs with removable wingtips, allegedly for hangaring ease, but which made it far more like a typical airplane than a glider if flown with the tips off. I have no idea if they'd get the design actually registered as a glider. T o d d P a t t i s t (Remove DONTSPAMME from address to email reply.) ___ Make a commitment to learn something from every flight. Share what you learn. If my memory serves me correctly, the above requirement of wingspan ^2 divided by gross wt not to exceed 0.62 lbs is stated in the "Certification" limitations. It has been argued that this requirement doesn't apply to experimental air craft. If it did, "Space Ship One" would not be registered with the FAA as a glider. On the other side of the coin, the Windrose meets the requirement; however, you find cases where it has been registered as an "airplane". Communications with the owners revealed that this was done to avoid having to spend the time and money to get a glider rating. Wayne HP-14 N990 "6F" http://www.soaridaho.com/ |
| Thread Tools | |
| Display Modes | |
| Seaplane Rating Add-On and Seaplane Rental | Peter Bauer | Piloting | 10 | May 29th 05 12:53 PM |
| American Lake SPB Closing | C J Campbell | Piloting | 23 | December 27th 04 04:26 PM |
| Restored military seaplane ready for surfing duty | Otis Willie | Naval Aviation | 0 | December 15th 04 11:28 PM |
| Flew a seaplane | Michael 182 | Piloting | 17 | August 26th 04 02:52 PM |
| How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 01:05 AM |
