Ttransponder question #3
Old September 15th 05, 09:25 PM
Ross Richardson
Default Ttransponder question #3
What do you do when requested to "recycle" your transponder?
Regards, Ross
C-172F 180HP
KSWI
Old September 15th 05, 09:33 PM
Steven P. McNicoll
"Ross Richardson" wrote in message
Coax it to operate properly. Wiggle the wheels a little. Turn it off and
on again. Push on the face to ensure good contact. Whatever.
Old September 15th 05, 09:41 PM
Maule Driver
power off, power on, test, cuss
Old September 15th 05, 10:28 PM
Chris Kennedy
Twiddle knobs, power cycle, whack it harder.
Old September 15th 05, 10:29 PM
Newps
Immediately buy a new one. You need to spend at least $1500 to make
this work.
Old September 16th 05, 03:44 PM
Ross Richardson
Oh, thanks!!!
What is interesting is that I get an occasional reported loss of Mode C
in one area that I fly when under IFR or FF. Departure questions me. No
problems other places. Like there is a hole there. I also was
embarrassed once when taking off and told to contact departure which I
did and they asked me to turn on my transponder. Yep, I forgot to do it.
Regards, Ross
C-172F 180HP
KSWI
this work.
Old September 15th 05, 11:04 PM
George Patterson
Turn it off and then back on.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old September 15th 05, 11:47 PM
Matt Whiting
Turn it on. This request means you forgot. :-)
Matt
Old September 16th 05, 12:03 AM
Jay Masino
I check to see if something isn't set correctly, but othewise I don't do
anything. Turning the transponder off and on again practically guarantees
that it won't transmit for 30 to 45 seconds, because all modern
transponders are build to wait that long, before starting to transmit, to
allow for warm-up.
--- Jay
__!__
http://www2.ari.net/jmasino ! ! !
http://www.OceanCityAirport.com
http://www.oc-Adolfos.com
Old September 16th 05, 12:14 AM
Newps
allow for warm-up.
If the transponder is already warm then it will transmit right away.
It's not a process that has to be repeated because the switch was turned
to STBY and back.
I want to ask you the most important question of your life. Douglas Olson Owning 1 May 22nd 05 05:15 AM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
