I need to wire some basic idiot lights for my homebuilt. Some are simple
independent switched light circuits but others indicate motors, such as a fuel pump is active. Are there any basic schematics/resources available on the web to show how to run an indicator in parallel with something like a pump motor. My guess would be that a diode needs to be included someplace. BTW I will probably be using LEDs with drop down resistors Thanks, Doug |
The "D" in LED means Diode, so you will have a diode there whether or not
you want it. The simple answer is that a resistor in series with an LED across an active circuit (like a motor) will light up. THe problem is the reverse voltage spike (back EMF) of an inductive circuit like a motor when it is shut off. You may wish (and probably should) break the current limit resistor to the LED into two parts and put a fairly hefty snubber diode in the circuit. Like so: + bus ----- switch ----- motor --- ground | | resistor | |------resistor---LEDA-LEDK---ground | diodeK diodeA | | ground Jim "Doug Palmer" wrote in message ink.net... I need to wire some basic idiot lights for my homebuilt. Some are simple independent switched light circuits but others indicate motors, such as a fuel pump is active. Are there any basic schematics/resources available on the web to show how to run an indicator in parallel with something like a pump motor. My guess would be that a diode needs to be included someplace. BTW I will probably be using LEDs with drop down resistors Thanks, Doug |
Hi Doug,
I'm planning on doing this kind of thing also. Can you give some example part numbers for a snubber diode. Are you referring to zener diodes? RST Engineering wrote: The "D" in LED means Diode, so you will have a diode there whether or not you want it. The simple answer is that a resistor in series with an LED across an active circuit (like a motor) will light up. THe problem is the reverse voltage spike (back EMF) of an inductive circuit like a motor when it is shut off. You may wish (and probably should) break the current limit resistor to the LED into two parts and put a fairly hefty snubber diode in the circuit. Like so: + bus ----- switch ----- motor --- ground | | resistor | |------resistor---LEDA-LEDK---ground | diodeK diodeA | | ground Jim "Doug Palmer" wrote in message ink.net... I need to wire some basic idiot lights for my homebuilt. Some are simple independent switched light circuits but others indicate motors, such as a fuel pump is active. Are there any basic schematics/resources available on the web to show how to run an indicator in parallel with something like a pump motor. My guess would be that a diode needs to be included someplace. BTW I will probably be using LEDs with drop down resistors Thanks, Doug |
The 1N400x series are generally hefty enough to use for snubbers. For a
small motor like a fuel pump, I'd probably use a 1N4004 or above. Jim "ejb" wrote in message ups.com... Hi Doug, I'm planning on doing this kind of thing also. Can you give some example part numbers for a snubber diode. Are you referring to zener diodes? |
Great stuff. I'm very glad to have this forewarning.
There's no substitute for this usnet group :-) |
Thanks All, Very Helpful
Doug |
| Thread Tools | |
| Display Modes | |
| Panel lights failure in Piper WarriorII | Piperflyer | Owning | 6 | September 23rd 04 08:26 AM |
| Panel Lights - Need Help | Barnyard BOb - | Home Built | 2 | May 29th 04 08:51 PM |
| Anti collision light mod for Piper Arrow 1968 model? | Frode Berg | Owning | 4 | May 20th 04 06:16 AM |
| Building chasing airport lights -- Attn: Jim Weir? | Jay Honeck | Owning | 79 | February 29th 04 03:10 PM |
| LEDs for Nav Lights - Jim Weir | Scott Gettings | Home Built | 3 | February 17th 04 02:53 AM |
