Hi there..
I have no idea about aviation so excuse me if this is a dumb question. Why is that on planes the landing gear: a) has such an unique interface relative to the other avionics. E.g Why the long handle? b) What is the purpose of the wheel at the end of the landing gear arm? Cheers Steve |
![]() "Steve Franklin" wrote in message ... Hi there.. I have no idea about aviation so excuse me if this is a dumb question. Why is that on planes the landing gear: a) has such an unique interface relative to the other avionics. E.g Why the long handle? b) What is the purpose of the wheel at the end of the landing gear arm? Cheers Steve What kind of airplane are you looking at Steve? Some gear handles are only an electric switch that activates a valve and on others the handle moves the valve itself. The wheel on the end is a symbol of what the handle does. Flap handles are usually a flat blade. Helps reduce the accidental gear retraction accident ![]() Allen |
I have just been watching 'Executive Decision' on TV and the aircraft was a
Boeing 747. The handle for the landing gear seemed very long and it had a wheel on the end that look a lot like a roller-blade wheel. So you are saying the wheel has no function other than to provide an instant identification to the pilot that it's the gear handle? Cheers Steve "Allen" wrote in message t... "Steve Franklin" wrote in message ... Hi there.. I have no idea about aviation so excuse me if this is a dumb question. Why is that on planes the landing gear: a) has such an unique interface relative to the other avionics. E.g Why the long handle? b) What is the purpose of the wheel at the end of the landing gear arm? Cheers Steve What kind of airplane are you looking at Steve? Some gear handles are only an electric switch that activates a valve and on others the handle moves the valve itself. The wheel on the end is a symbol of what the handle does. Flap handles are usually a flat blade. Helps reduce the accidental gear retraction accident ![]() Allen |
![]() "Steve Franklin" wrote in message ... I have no idea about aviation so excuse me if this is a dumb question. Why is that on planes the landing gear: a) has such an unique interface relative to the other avionics. E.g Why the long handle? Landing gear is not avionics. The size of the gear "lever" depends on the method of gear actuation. Aircraft with manual gear retraction and extension need fairly long gear levers in order to obtain sufficient mechanical advantage for the pilot. Aircraft with straight hydraulic systems generally have longer gear levers than those with electric or electrohydraulic systems because it takes more force to turn a valve than actuate a switch. b) What is the purpose of the wheel at the end of the landing gear arm? To readily identify it as the gear lever; move the "wheel" to move the wheels. |
Steve Franklin wrote:
I have just been watching 'Executive Decision' on TV and the aircraft was a Boeing 747. The handle for the landing gear seemed very long and it had a wheel on the end that look a lot like a roller-blade wheel. So you are saying the wheel has no function other than to provide an instant identification to the pilot that it's the gear handle? You're correct, it's so you can tell by feel and visual shape. power = cylindrical supercharger = cylindrical with triangular teeth rpm = ridges like a section of a mechanical gear, flat ridges mixture = like rpm, but thin sharp ridges flags = flat with thin edge facing you heat/alternate air = square facing you gear = wheel Kev |
![]() power = cylindrical supercharger = cylindrical with triangular teeth rpm = ridges like a section of a mechanical gear, flat ridges mixture = like rpm, but thin sharp ridges flags = flat with thin edge facing you heat/alternate air = square facing you gear = wheel Kev Thanks Kev...that makes so much more sense now....I can understand now. I just couldn't understand why it wouldn't just be a button like so much else.. But I can see now how important it would be if you say lost all power to the cockpit instrumentation to be able to easily find the landing gear in the dark if neccessary... It all makes perfects sense... Cheers Steves |
But I can see now how important it would be if you say lost all power to the cockpit instrumentation to be able to easily find the landing gear in the dark if neccessary... Actually, that's for all the time. In many cases you don't want to take your eyes off of something else (like the runway) just to be sure you have the right lever. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
A&P heroics | Jim | Piloting | 31 | July 18th 05 07:26 PM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
