when did THIS happen in aviation?
Old September 25th 05, 12:59 AM
Retro Pilot
Default when did THIS happen in aviation?
how long has it been since airports have gone from 3-to-4 letter
identifiers?
also, when did ATC go from 2000 feet vertical separation above FL290 to 1000
feet?
and, no, I was not doing time in prison for the past 20 years for
trafficking.
Old September 25th 05, 03:49 PM
George Patterson
identifiers?
I'm not sure what you mean by this. If you mean an identifier like KABE, where
the "K" indicates a U.S. airport, I first saw that in 1989, and it had been that
way for many years. I haven't seen four-letter Ids in the States where the first
letter wasn't "K."
feet?
IIRC, sometime last year, but it could've been a bit earlier. The new collision
avoidance systems make closer separation standards possible.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old September 25th 05, 04:38 PM
Steven P. McNicoll
"George Patterson" wrote in message
news:rOyZe.1925$%L4.26@trndny02...
where the "K" indicates a U.S. airport, I first saw that in 1989, and it
had been that way for many years. I haven't seen four-letter Ids in the
States where the first letter wasn't "K."
The "K" indicates an airport in the contiguous 48 states. Alaskan ICAO
identifiers begin with PA, PF, PO, or PP, and Hawaiian ICAO identifiers
begin with PH.
A bit later, actually, January 20th 2005.
The new
collision avoidance systems make closer separation standards possible.
It's not collision avoidance systems that make RVSM possible, it's new
altitude tolerance criteria. An aircraft type has to demonstrate it can
remain within a specific altitude error tolerance. Some older aircraft types
required improvements in their autopilot and air data systems to meet the
standard, some required special attention to the skin surface in the area
surrounding the static ports.
Old September 25th 05, 05:59 PM
Matt Barrow
identifiers?
1000 feet?
RVSM began this past January.
Old September 26th 05, 12:56 AM
rotor&wing rotor&wing is offline
Member
First recorded activity by AviationBanter: Sep 2005
above FL290 seperation is now 1000 ft.
Old September 25th 05, 04:17 PM
Paul Tomblin
identifiers?
You're confusing two types of identifiers. FAA identifiers are three
letters or letters and numbers. ICAO identifiers are four letters long,
the first letter identifies a region, and they don't allow numbers. The
continental US is the region with the identifier "K". By convention,
those airports in the continental US with ICAO identifiers just use their
FAA id with a K put on the front for their ICAO id. Most of the world
uses a more complicated system with the second letter designating a
sub-region. Hawaii, Alaska, the US Virgin Islands and other places use
"P" and a second code letter, and then the mapping between the FAA id and
the ICAO id is more complicated.
US pilots became more aware of the ICAO identifiers when the US started
using METAR and TAF weather reporting formats, the same as the rest of the
world. That happened about 10 years ago. We had to change the FAA id of
several airports to elminate numbers so that they could be given ICAO ids.
Also, GPSes use the ICAO id rather than the FAA id when the airport has an
ICAO id, just to reduce confusion between airport ids and co-located or
nearly co-located VORs with the same FAA id.
feet?
RVSM (Reduced Vertical Separation Minimums(?)) were phased in quite recently.
They came about because of improvements in altimeter technology, and maybe
also as a result of TCAS and mode-S.
please excuse my typing, but my whole left arm is in a cast. and i don't
mean _the king and i_.
Old September 25th 05, 04:25 PM
Steven P. McNicoll
"Retro Pilot" wrote in message
identifiers?
They haven't, not really. The 4-letter identifier is the ICAO identifier.
They've been in use since probably some time in the fifties. They've only
come into common domestic use in recent years because of GPS databases and
the need to distinguish airports from navaids of the same identifier. The
3-letter airport identifiers are just as valid as ever.
1000 feet?
US domestic RVSM, Reduced Vertical Separation Minimums, was implemented
January 20, 2005.
Old September 26th 05, 01:47 AM
Steve Rubin
In article et,
There are also private airports (atleast here in california) that have
4 digit's.
http://airnav.com/airport/CA20
for example.
Steve Rubin / AE6CH / http://www.altdb.net/
Email: / N6441C / http://www.tch.org/~ser/
"Why don't you mind your own business?" -- John Navas 01/04/05
"If you don't like it, keep it to yourself" -- John Navas 01/04/05
Old September 26th 05, 03:52 AM
Steven P. McNicoll
"Steve Rubin" wrote in message
4 digit's.
for example.
Two-letter, two-number identifiers are assigned to private-use landing
facilities in the United States and its jurisdictions which do not meet the
requirements for three-character assignments.
Old September 26th 05, 07:19 AM
Matt Barrow
In article et,
4 digit's.
for example.
Ummm..no, it has four characters and two of those are digits. If it has even
a single digit in it, it's not an ICAO identifier.
High-tech gizmos propel aviation into the future Omega Piloting 3 June 11th 05 06:48 AM
ATC User Fees Larry Dighera Piloting 80 May 12th 05 07:20 AM
Aviation Conspiracy: FAA Calls Controller Whistleblowers "Rogue Employees!!! Bill Mulcahy General Aviation 0 March 31st 05 04:29 AM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Home Built 3 May 14th 04 11:55 AM
