Hello,
Is someone use odyssey battery for a Continental O200? what ref do you use? The PC680 seems a little oversize. Thanks -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
On Tue, 27 Sep 2005 17:37:49 +0200, Philippe Vessaire
wrote: Hello, Is someone use odyssey battery for a Continental O200? what ref do you use? The PC680 seems a little oversize. Thanks -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ I'm using a 680 to start my lycoming 0-290. It replaced a motorcycle battery that was bigger and had less power. A bit oversize maybe but I'm very happy with it. |
Local: Tues, Sep 27 2005 8:37 am Subject: odyssey battery Is someone use odyssey battery for a Continental O200? what ref do you use? The PC680 seems a little oversize. Thanks ************************************************* ************* We use a PC680 on a hi compression , 100 in^3 ,4 cycle.engine. Has enough capacity to run the starter for 30 sec,and supply all the power to the avionics for longer than we have fuel. It's been doing this for more than two years with no noticeable loss of capacity. BUT you need to know the starter stalled amps, cranking amps,main buss amps, secondary buss amps, and insure that regulator charging voltage conforms to the limits set by Odyssey. The Harley MC uses a PC545....Tiny little thing........ Reggie |
On Tue, 27 Sep 2005 17:37:49 +0200, Philippe Vessaire wrote:
Is someone use odyssey battery for a Continental O200? what ref do you use? The PC680 seems a little oversize. I put a PC680 on my C-85 Fly Baby about two years ago, and it's doing fine. I replaced a standard aircraft battery, so the "oversize" PC680 was actually quite a bit smaller than the one I took out. I posted the details of my PC680 conversion to the Fly Baby mailing list. Skim to "Installing My Odyssey Dry Cell" on this web page: http://www.bowersflybaby.com/tech/battery.html Once I got my starter clutch replaced, the PC680 cranks the engine quite nicely. Ron Wanttaja |
Ron,
I use the PC680 to start my 200HP, high compression (10.5 to 1) Franklin engine. I have a second battery PC925 for avionics, etc. About two years old both, no problems so far. -------------------------- SQ2000 canard: http://www.abri.com/sq2000 |
Scott Manning uses two 680's on his Canadian Stinger BD-5J Microjet that
he's currently flying in the airshow circuit. But he's going to be taking them out and going back to NICADs soon. "Philippe Vessaire" wrote in message ... Hello, Is someone use odyssey battery for a Continental O200? what ref do you use? The PC680 seems a little oversize. Thanks -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
| Thread Tools | |
| Display Modes | |
| Battery Question | [email protected] | Soaring | 19 | September 15th 05 02:38 AM |
| Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 05:30 PM |
| 14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 02:37 AM |
| Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 02:29 PM |
| Odyssey Battery-Jerry Springer | Badwater Bill | Home Built | 35 | September 7th 03 06:17 AM |
