Is there any information available about the new SMA jet fuel engines
that are being offered for the C182? I'm curious if maintenance would be much of an issue. Are there many shops that can handle working on them? Is it a replace only like the Centurion 1.7 on the Diamond airplanes? Or can it be overhauled to get flying again? Cost for an annual? How would they perform at high altitudes? - Colorado rockies region for example. Any way lots of questions so if any one knows where I might be able to find information it would sure be appreciated. I've already checked the www.smaengines.com web site and it is just a little light on information. Thanks |
Mike,
Is there any information available about the new SMA jet fuel engines that are being offered for the C182? They are? Actually being offered, I mean. Not just written about. I'm curious if maintenance would be much of an issue. Are there many shops that can handle working on them? I don't know of any kind of maintenance network - quite contrary to the Centurions. Is it a replace only like the Centurion 1.7 on the Diamond airplanes? Or can it be overhauled to get flying again? I think I read about overhauls. I've already checked the www.smaengines.com web site and it is just a little light on information. There might be a reason... -- Thomas Borchert (EDDH) |
it's just a Diesel Engine
"Mike" wrote in message ups.com... Is there any information available about the new SMA jet fuel engines that are being offered for the C182? I'm curious if maintenance would be much of an issue. Are there many shops that can handle working on them? Is it a replace only like the Centurion 1.7 on the Diamond airplanes? Or can it be overhauled to get flying again? Cost for an annual? How would they perform at high altitudes? - Colorado rockies region for example. Any way lots of questions so if any one knows where I might be able to find information it would sure be appreciated. I've already checked the www.smaengines.com web site and it is just a little light on information. Thanks |
Mike wrote:
Is there any information available about the new SMA jet fuel engines that are being offered for the C182? Prowl around http://www.smaengines.com . I'm curious if maintenance would be much of an issue. Are there many shops that can handle working on them? Not in the U.S.. There's only one or two 182s flying with that engine in the States. The French STC was granted only last July, and the company doesn't expect the FAA to grant an STC until later this year. Is it a replace only like the Centurion 1.7 on the Diamond airplanes? Or can it be overhauled to get flying again? They're targeting a 3,000 hour TBO. Since they use the term TBO, not TBR, it seems the company intends to support overhauls. Cost for an annual? As much as you have. :-) Seriously, SMA claims maintenance costs will be lower than gas. Since that tends to be true of diesels, they're probably right. How would they perform at high altitudes? - Colorado rockies region for example. Should be about the same as a turbocharged gas engine of similar torque. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
("George Patterson" wrote)
[snip] Is there any information available about the new SMA jet fuel engines that are being offered for the C182? Prowl around http://www.smaengines.com . For others, more than for the OP, who already knows this:. http://www.centurion-engines.com/c17/c17_retro.htm 295 lb engine (incl. all accessories for operation) Looks like FAA approval 'for all, not just a few' is just around the corner - maybe. http://www.dieselair.com/ Found this too Montblack |
After a bit more digging here is some more information I have found:
Current cost of the C182Q kit is about $77K soon to be reduced by "at least $10K" so around $67K Installation, at the dealer I contacted, runs about $9K. Or about 120-hrs @ $75/hr. So the installed price should be about $76K. Which includes almost everything from the firewall forward. "Normal" recurring maintenance is expected to be: 100 hour oil changes. 200 hour fuel filter change and glow plug inspection. 500 hour compression check With estimated time at 3~5 hrs. Annuals were - Quote: "Your overall annual inspection will be much less then an avgas engine by virtue of the fact that the engine contains 70% less parts and therefore there is virtually nothing left to change out or replace." So how much that will really mean ... ? Overhaul is estimated to run around $24K+ based on the 3000-hr TBO. So in the perfect world, I could either do 2 "cheaper" overhauls on the SMC or 3 regular overhauls on a Lyc or 3+ on a TCM engine over a 6000hr life. If you look at burning less cheaper (if available) JetA fuel than avgas over the life of the TBO. Might save a few bucks. Also saving on price of a few other pieces and parts (sparkplugs, etc.) there might be a few more bucks saved. And starting off with a new prop. So since I am rather new at this how much does an overhaul on a regular avgas burning C182 engine run? It almost looks like it might be something to look a little closer at. ??? |
Mike wrote:
So since I am rather new at this how much does an overhaul on a regular avgas burning C182 engine run? The current Aviation Consumer magazine has an article about the SMA 182. They also did a general review of 182 series in May quoted overhaul cost of $17K for the continentals and $23K for the Lycs. -- "You can support the troops but not the president" --Representative Tom Delay (R-TX), during the Kosovo war. |
Mike wrote:
Annuals were - Quote: "Your overall annual inspection will be much less then an avgas engine by virtue of the fact that the engine contains 70% less parts and therefore there is virtually nothing left to change out or replace." So how much that will really mean ... ? Probably this. The annual inspection on a gas engine is basically to run a compression test, clean and rotate the plugs, check and adjust the ignition timing, and check the air filter. All shops in this area also change the oil and filter, though the FAA doesn't require it. Of course, an AD check is also run. I would bet that the inspection for the diesel will involve running a compression test (whether it's been 500 hours or not), cleaning the glow plugs, checking the air filter, and changing the oil and filter. Plus an AD check. That basically will save you the cost of the magneto work (since there aren't any). The time needed to check the glow plugs will also be less than messing around with 8 spark plugs. Now, if the FAA will allow owners/operators to actually follow the 100, 200, and 500 hour inspection periods recommended by the manufacturer, you would see a *big* decrease in costs, but I bet they won't. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
"George Patterson" wrote in message news:rI1%e.17210$L15.10478@trndny01... Mike wrote: Is there any information available about the new SMA jet fuel engines that are being offered for the C182? Prowl around http://www.smaengines.com . I'm curious if maintenance would be much of an issue. Are there many shops that can handle working on them? Not in the U.S.. There's only one or two 182s flying with that engine in the States. The French STC was granted only last July, and the company doesn't expect the FAA to grant an STC until later this year. Is it a replace only like the Centurion 1.7 on the Diamond airplanes? Or can it be overhauled to get flying again? They're targeting a 3,000 hour TBO. Since they use the term TBO, not TBR, it seems the company intends to support overhauls. Cost for an annual? As much as you have. :-) Seriously, SMA claims maintenance costs will be lower than gas. Since that tends to be true of diesels, they're probably right. How would they perform at high altitudes? - Colorado rockies region for example. Should be about the same as a turbocharged gas engine of similar torque. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. Yea, and put a turbo on that Diesel Engine get better performance and better fuel economy |
You forgot about the fuel injection system inspection? Injectors fail become
leaky or clogged "George Patterson" wrote in message news:lWe%e.22$DO2.21@trndny06... Mike wrote: Annuals were - Quote: "Your overall annual inspection will be much less then an avgas engine by virtue of the fact that the engine contains 70% less parts and therefore there is virtually nothing left to change out or replace." So how much that will really mean ... ? Probably this. The annual inspection on a gas engine is basically to run a compression test, clean and rotate the plugs, check and adjust the ignition timing, and check the air filter. All shops in this area also change the oil and filter, though the FAA doesn't require it. Of course, an AD check is also run. I would bet that the inspection for the diesel will involve running a compression test (whether it's been 500 hours or not), cleaning the glow plugs, checking the air filter, and changing the oil and filter. Plus an AD check. That basically will save you the cost of the magneto work (since there aren't any). The time needed to check the glow plugs will also be less than messing around with 8 spark plugs. Now, if the FAA will allow owners/operators to actually follow the 100, 200, and 500 hour inspection periods recommended by the manufacturer, you would see a *big* decrease in costs, but I bet they won't. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
| Thread Tools | |
| Display Modes | |
| Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 08:04 PM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| "Out of fuel, out of hope: 'Help, I'm in the water'" | [email protected] | Piloting | 145 | May 4th 05 12:21 AM |
| Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 07:13 PM |
| What if the germans... | Charles Gray | Military Aviation | 119 | January 27th 04 12:20 AM |
