Any recommendations for textbooks addressing designing, especially
stress analysis, with composite materials? -- FF |
I took a composite stress analysis mechanical engineering class at a
major university (the only class offered). We didn't use any textbook, but used a series of pdf files. Anything in particular you looking for? On 21 Jan 2005 11:51:18 -0800, wrote: Any recommendations for textbooks addressing designing, especially stress analysis, with composite materials? |
Robert Dorsey wrote: I took a composite stress analysis mechanical engineering class at a major university (the only class offered). We didn't use any textbook, but used a series of pdf files. Anything in particular you looking for? On 21 Jan 2005 11:51:18 -0800, wrote: Any recommendations for textbooks addressing designing, especially stress analysis, with composite materials? Mr/Ms Mitchell has posted quite a list of books. My particular interest is in stress analysis so as to be able to compare strength to weight ratios for various choices of materials. In particular I'd like to see if there is any advantage to substituting composite members for wood or metal members in stick and rag designs. For instance, one could use swim noodles wrapped in a hard shell of epoxy filled carbon fiber, glass or kevlar tapes and cloth to make tubular members. -- FF |
I have contemplated something similar.
I think you would be best to wind the tubes using a carbon / glass tow material and epoxy around a mandrell. Tow would be a lot cheaper then wrapping the tubes in cloth and would allow the properties of the tube to be optimised by changing the winding angle. Pro's and Con's .... It is going to cost more than alumnium. Might save a little weight. Joints will be hard to make at intersections of tubes. The composite tubes will lake the ductility of the alumnium tubes and hence crashworthiness will be compromised. wrote in message ups.com... Robert Dorsey wrote: I took a composite stress analysis mechanical engineering class at a major university (the only class offered). We didn't use any textbook, but used a series of pdf files. Anything in particular you looking for? On 21 Jan 2005 11:51:18 -0800, wrote: Any recommendations for textbooks addressing designing, especially stress analysis, with composite materials? Mr/Ms Mitchell has posted quite a list of books. My particular interest is in stress analysis so as to be able to compare strength to weight ratios for various choices of materials. In particular I'd like to see if there is any advantage to substituting composite members for wood or metal members in stick and rag designs. For instance, one could use swim noodles wrapped in a hard shell of epoxy filled carbon fiber, glass or kevlar tapes and cloth to make tubular members. -- FF |
.......... :-)) wrote: I have contemplated something similar. I think you would be best to wind the tubes using a carbon / glass tow material and epoxy around a mandrell. Tow would be a lot cheaper then wrapping the tubes in cloth and would allow the properties of the tube to be optimised by changing the winding angle. Pro's and Con's .... It is going to cost more than alumnium. Might save a little weight. Joints will be hard to make at intersections of tubes. The composite tubes will lake the ductility of the alumnium tubes and hence crashworthiness will be compromised. Wrapping in cloth or tape would be a lot easier and faster if doing the layup by hand. It would also be trivial to orient it so that half the fibers of the cloth or all the fibers of unit-directional tape run the length of the tube to maximise bending strength. Before doing anything of the sort I want to be able to calculate that strength, hence the original question. Joints could be made with tows/cloth/tapes to fabricate saddle-like fittings perhaps in-situ. Crash-worthiness remains an important issue. -- FF |
My two cents: for a reasonably simple structure such as the "carbon
around swim tube" proposed, I think the best approach may be to simply build one or two of them and test it/them to destruction. Compare this against a likewise destructive test of the wood part you're proposing to replace. Allow a generous margin for error -- especially if others are going to be building it from your plans, because there can be a great variance in composite strength depending on the builder's skill and environmental conditions. Greg |
I ran across an excellent book on composites in Barnes & Nobles about a
year ago. It was nearly $70US so I had to pass it by. Been kicking myself ever since. Sorry, that is the only clue I remember 8-(. AI Nut wrote: Any recommendations for textbooks addressing designing, especially stress analysis, with composite materials? |
There are not that many books that give a begineer a practical overview of
how to design with composites. It is a art leaned by a small number of engineers who to date have not been very prolific and writing down what they know .... try the following for starters. Niu "composite Airframe Structures" not a cheap book but about the best general intro but it will not give you everything you are going to need. Tsai, Stephen. W. "Composites Design" Think Composites or the earlier book by Tsai and Hahn (actaually better in some respects that the later Tsai volume IMHO) Daniel and Ishai "Engineering Mechanics of Composite Materials" I will post more referenes on monday and I get to work .... cannot remember them all right now. You are going to need design allowables ... if doing a simple wet layup then perhaps the best source of such data is the old ANC-17. This was replaced by MIL-HDBK-17 but this only contains data for a lot of more advanced prepreg materials. If you want to use prepreg than my guess is that it will be a low temperature cure material and the best source of data for these materials are the AGATE style data bases supplied by many of the manufacturers such as Fibercote, Toray and Newport for their materials. Actually some of the best sources of info are the design manuals from some of the large airplane manufacturers - if you can get hold of them. This is because a lot of the more practical aspects of design and analysis are simply not covered in the more academic texts. I would not recommend the popular 2 volume book from a well know engineer of homebuilts. They are really too superficial .... they lack any real meat IMO. Interesting background info but probably not worth the price if you are expecting a design text. You cannot really design composite structures without some software as well .... as a minimum you will need a laminate analysis program such as Tsai's Genlam. Ideally you will have an FEA program that has laminate elements. There are a lot of courses out there on composite design but in reality most of these should be called an intro to laminate theory or something. My experience is that they usually don't talk much about the practical issues and problems associated with the design of composites (allowables, hot wet, strain limits, through thickness and edge effects etc) ... concentrating instead on the more academic aspects of pure analysis. Also check the FAA web site there are some interesting AC's, Memo's, research reports etc that address some of the major issues ... this is the sort of info you will not find in text books and university courses. Finally grab some repair manuals for certificated composite airplanes and gliders ... many of these show details of all the laminates (materials, # ply's, ply orientation etc). A careful study of some airplanes designed by people who know what they are doing can be worth more than a dozen texts. If you have specific questions fire away. wrote in message ups.com... Any recommendations for textbooks addressing designing, especially stress analysis, with composite materials? -- FF |
As per my previous post ... here is some additional references for use in
the design of composite structures: Agarwal and Broutman "Analysis and Performance of Fibre Composites" Armstrong K.B. & Barrett R.T., Care and repair of Advanced Composites, SAE, Warrendale, PA, 1998. Ashton, J.E. and Whitney, J.M. "Theory of Laminated Plates" Ashton, J. E., Halpin, J. C. and Petit. P. H. "Primer on composite materials: analysis" Baker A.A. & Jones R., Eds., 1988, Bonded Repair of Aircraft Structures, Martinus Nijhoff Publ., Dordrecht. Bitzer, Tom. "Honeycomb technology : materials, design, manufacturing, applications and testing" Christensen, J. "Mechanics of Composite Materials" Hoskin B.C. & Baker A.A., Eds., 1986, Composite Materials for Aircraft Structures, AIAA Education Series, AIAA, New York. Hull, D. and Clyne, T.W. "An introduction to composite materials" Jones, R.M. "Mechanics of Composite Materials" Kollar, L.P. and Springer, G.S. "Mechanics of composite structures" Springer, G. "Environmental effects on composite materials" 3 volumes Schwartz, M.M. "Joining of Composite Matrix Materials" Schwartz, Mel M. (Ed). "Fabrication of composite materials" Schwartz, Mel M. "Composite materials handbook" Schwartz, Mel M. "Composite materials" Whitney, J.M. "Analysis of Laminated Anisotropic Plates" Whitney, J.M., Daniel, I.M. and Pipes, B. "Experimental mechanics of fiber reinforced composite materials The literature is huge ... this is just a start. Do your own research and you will find a whole lot more. |
| Thread Tools | |
| Display Modes | |
| Looking for a two-seater design | Shin Gou | Home Built | 13 | December 21st 04 07:44 AM |
| Design Software | Brad Mallard | Home Built | 12 | November 12th 04 10:54 AM |
| Aircraft Design 1942 flying boats FA | Sally | Home Built | 0 | August 19th 04 07:49 PM |
| amateur design consultant? | Shin Gou | Home Built | 14 | June 30th 04 02:34 AM |
| Carbon Spar design and construction workshop | Marske Flying Wings | Home Built | 0 | September 18th 03 06:47 PM |
