Why Haven't Airbus A-320s Been Grounded?
Old October 6th 05, 08:54 PM
Jay Honeck
Default Why Haven't Airbus A-320s Been Grounded?
After seven (?) incidents of landing gear malfunctions similar to the Jet
Blue incident, why has the FAA not issued an emergency Airworthiness
Directive on the Airbus A320?
Or has an AD been issued, but without the requirement to "ground" them until
they've been repaired?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 6th 05, 09:07 PM
Jimmy
until
Why should they ground them ? It's just a few sparks, no big deal. These
planes have to work for a living and can't sit around waiting for some FAA
pencil pusher. Maybe they can get some mechanics in a truck to drive down
the runway under the plane and twist them back into alignment next time it
happens.
Old October 6th 05, 09:13 PM
Paul kgyy
As long as it's mis-aligned by 90 degrees, it's maybe not a serious
hazard.
I don't know what the odds are, but it seems to me that having the nose
gear locked at 20 degrees off would be a significant hazard..
Old October 8th 05, 10:52 PM
Robert M. Gary
A jet lands with so much energy (weight) the nose wheel really has no
authority until your almost down to taxi speed. If you didn't have a
rudder, the nose would slip back and forth without really effecting the
direction of the aircraft.
Old October 6th 05, 09:18 PM
until
happens.
The FAA has its hands full with the NWA replacement mechanics. Dead
birds
left in engines and engine flames on T.O. are becoming a frequent
occurance.
JG
Old October 6th 05, 09:16 PM
Flyingmonk
Because they are still airworthy, just not ground worthy. : -)
Bryan "The Monk" Chaisone
Old October 6th 05, 09:39 PM
James Robinson
Jet Blue incident, why has the FAA not issued an emergency
Airworthiness Directive on the Airbus A320?
until they've been repaired?
They did issue one. A number of the earlier incidents were because an O
ring became distorted. The French version of the FAA had issued a
maintenance instruction requiring replacement of the ring, and the FAA
eventually did the same. They probably thought that solved the problem.
There are also apparently a couple of causes: One is the O ring, and the
other is incorrect reassembly of the gear by maintenance forces. They
probably thought both were fixed.
As far as grounding the A320, then you would also have to ground the
A318, A319, and A321, since they have essentially the same gear. You
might also have to ground the other Airbus models, since the gear is
made by the same company, and might have similar design deficiencies.
While were at it, why didn't the FAA ground the middle vintage 737s when
they had two fatal accidents from suspected rudder reversals, plus a
couple of rudder control incidents reported by other airlines while in
flight? At least the A320 nose gear problem hasn't yet resulted in any
fatalities.
Airbus A380 water purification john smith Piloting 1 July 7th 05 02:50 AM
Australia chooses Airbus tankers John Cook Military Aviation 0 April 16th 04 10:25 AM
Airbus 15 minutes of fame over? Buzzer Military Aviation 5 January 20th 04 04:42 AM
Airbus Charts Course for Military Contracts Otis Willie Military Aviation 0 November 24th 03 11:04 PM
Airbus Aiming at U.S. Military Market Otis Willie Military Aviation 0 September 21st 03 08:55 PM
