Carbon Monoxide Detector?
Old October 22nd 05, 05:26 AM
Morgans
Default Carbon Monoxide Detector?
Another informal survey.
How many of you have, and use a battery powered Carbon Monoxide Detector
when you fly?
Why, or why not?
Old October 22nd 05, 10:15 AM
Mortimer Schnerd, RN
when you fly?
Why, or why not?
I've flown many aircraft that have one of those stick-on type brown dots but
I've never flown anything with a battery powered detector. I've also flown an
old Apache with a Janitrol heater that would give you a headache every time you
used it. I flew all that winter with a blanket on my lap. What can I say?
Part 135 maintenance....
VE
Old October 22nd 05, 01:06 PM
Jay Honeck
when you fly?
Yes.
See it he
http://makeashorterlink.com/?P4845270C
It's small, and VERY sensitive. (It will sound an alarm in an extended
climb, when the nose is high and the exhaust stream hits the fresh-air
intake mounted way up at the top of the tail.)
It's not cheap, but we fly all winter -- and I never trusted those dumb
"Dead Stop" things to do anything...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 22nd 05, 02:37 PM
tom418
I use several $ 2 variety "button" CO detectors. I started using them after
seeing a bunch of emergency vehicles surrounding a PA28 on the ground at
Long Island MacArthur APT back in 1985. A couple from New England became
unconscious during their taxi out. Leak was traced to a faulty heater
shroud. They made it. Fortunately, they passed out before they took off.
"Morgans" wrote in message
when you fly?
Why, or why not?
Old October 22nd 05, 03:27 PM
Jonathan Goodish
when you fly?
Why, or why not?
Yes. The "why" should be obvious, particularly if you fly a
single-engine airplane with cabin heat provided by the muffler shroud.
The cardboard dots and most of the "Home Depot Specials" are almost
worthless. You need an electronic monitor that will display low levels
of CO, starting at 10ppm or lower, and alarm at those lower levels.
The CO monitor that Jay Honeck linked to is a very good one. Aeromedix
used to sell an imported Senco detector that alerted at low CO levels,
but I believe that Senco went out of business or was acquired by someone
else (this is the detector that I'm using). The key is to avoid the
purchase of a detector that is UL listed or approved to US residential
standards, because those detectors will alarm only at fairly high CO
concentrations.
JKG
Old October 23rd 05, 04:09 AM
I looked up the AC article from Oct 2000. Here is verbatim what they
said.
"The Underwriters Lab standard, which was recently revised upward,
requires CO alarms to signal well ahead of the onset of symptoms for
the "average" person. (That in itself may be a moving target, since
response to CO varies by individual.)
Specifically, UL requires an 85-decibel alarm signal to sound within
189 minutes if 70 parts per million CO is detected. If the level is 150
PPM, the alarm limit is 50 minutes and it's 15 minutes at 400 PPM.
The old requirement was 90 minutes for 100 PPM and 35 minutes for 200
PPM. "
About the dead stop spot detector;
"Having seen these in dozens of aircraft, nary a one darkened, we
assumed they were nothing more than a feel-good gimmick, albeit a cheap
one. That's hardly the case, however. When exposed to CO in our test
device, the Dead Stop turned noticeably darker after about five minutes
of exposure at around 125 PPM, a low to mid-level of CO. At 500 and
above, the patch darkens fast enough to watch, turning pitch black."
Like a poster said, the electronic ones can be useful for finding
leaks, and if you feel that the spots are not sensitive enough for you.
But I think the spots have good value and are hardly worthless. Every
airplane should have at least as much onboard.
when you fly?
Why, or why not?
concentrations.
JKG
Old October 22nd 05, 07:16 PM
Carl Orton
I use the same one as Jay - AeroMedix. Love the sensitivity.
Why battery over the "dots"? Allegedly the dots wear out over time (OK - so
do batteries), but more because I value my life. Plus, being an engineer,
it's fun to play around with it. In the winter with all the vents closed up,
it's amazing to see how much CO comes in from the tailcone area. Just
cracking a vent or cabin air or heat just a bit to produce positive pressure
almost instantly removes the issue.
when you fly?
Why, or why not?
Old October 22nd 05, 07:41 PM
john smith
The dots will give a false CO reading when exposed to autogas fumes,
also. AVIATION CONSUMER did a report on the CO dot detectors back in the
80's or 90's.
PIREP--CO Experts low level carbon monoxide detector Jay Honeck Piloting 10 December 3rd 04 11:21 AM
Foil Antenna on Carbon Fiber Dennis Mountains Home Built 7 April 24th 04 12:54 AM
Carbon fiber vs. antennas Jim Weir Home Built 8 January 2nd 04 01:40 PM
Portable Carbon Monoxide Detectors Cecil E. Chapman Piloting 9 November 18th 03 10:00 PM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 04:44 AM
