Where do you put the luggage in an A36? (do you have to take out the 3rd row
of seats?) |
There is a space behind the 3rd row that can contain baggage.
THe usual caveat about Bonanza's and their empty fuel/end of trip CG issues applies. Dave John Doe wrote: Where do you put the luggage in an A36? (do you have to take out the 3rd row of seats?) |
"Dave S" wrote in message k.net... There is a space behind the 3rd row that can contain baggage. THe usual caveat about Bonanza's and their empty fuel/end of trip CG issues applies. Can you explain further? |
On Sun, 23 Oct 2005 22:08:43 -0400, "John Doe"
wrote: "Dave S" wrote in message nk.net... There is a space behind the 3rd row that can contain baggage. THe usual caveat about Bonanza's and their empty fuel/end of trip CG issues applies. Can you explain further? Fuel is typically forward of the spar/c.g., bodies and "stuff" typically aft of the spar/c.g. In-flight the fuel gets turned into various combustion by-products and the c.g. shifts aft. AFAIK the A36 has the 2 front seats located further forward than any of the other Bananer's, but the passenger/baggage compartment extends further aft. TC |
Newps wrote:
In an A36 if you can takeoff within CG you will land within CG. I've got a flight planner which came loaded with the data for an A36 with club seating, N90002. The CoG shifts aft 4" from full to empty tanks. It's very easy to load that plane in such a way that you take off within the envelope and attempt to land outside the envelope without anyone changing seats. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
That hard part is loading it. I flew a Debonair before I bought my
Mooney. I still don't understand why Beech continues having people load baggage from that little door on the side. In the Mooney, you load it like a car's truck, from the top. In the Beech, I had to load the first bag, then lift it up and load the next under it, etc. The other option was to load the bags over the back seat, skipping the door. There is a reason Chevy puts a trunk on cars rather than have a little door on the side to load your car. I guess for those that only carry 1 or 2 bags the Beech way may work but for those of us that load to the ceiling, the Mooney way is clearly the best. I"m also 6'4", I've always thought that Beech designed for shorter pilots, while Mooney designed for taller pilots, perhaps that is a factor too. -Robert |
You're 6'4" and you fly a Mooney? Wow. Good on ya. Probably don't have
much leg room for passengers in the back. Do you find the Mooney to be a tight fit? "Robert M. Gary" wrote in message oups.com... That hard part is loading it. I flew a Debonair before I bought my Mooney. I still don't understand why Beech continues having people load baggage from that little door on the side. In the Mooney, you load it like a car's truck, from the top. In the Beech, I had to load the first bag, then lift it up and load the next under it, etc. The other option was to load the bags over the back seat, skipping the door. There is a reason Chevy puts a trunk on cars rather than have a little door on the side to load your car. I guess for those that only carry 1 or 2 bags the Beech way may work but for those of us that load to the ceiling, the Mooney way is clearly the best. I"m also 6'4", I've always thought that Beech designed for shorter pilots, while Mooney designed for taller pilots, perhaps that is a factor too. -Robert |
In article .com,
"Robert M. Gary" wrote: In the Beech, I had to load the first bag, then lift it up and load the next under it, etc. The other option was to load the bags over the back seat, skipping the door. Sounds like how I load the 182 for AirVenture. |
baggage from that little door on the side. In the Mooney, you load it like a car's truck, from the top. In the Beech, I had to load the first bag, then lift it up and load the next under it, etc. The other option was to load the bags over the back seat, skipping the door. There is a reason Chevy puts a trunk on cars rather than have a little door on the side to load your car. Interesting. The few times I've loaded a Mooney, I found the location of the baggage compartment door to be awkward. Having to lift the bags up so much higher in order to clear the lip made me long for the nice, low baggage doors in most other planes. Of course, I wasn't loading for Oshkosh. If I was loading to the roof, I can certainly see your point. I"m also 6'4", I've always thought that Beech designed for shorter pilots, while Mooney designed for taller pilots, perhaps that is a factor too. First time I've ever heard that. Usually I've heard pilots describe both planes the other way 'round... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
| Thread Tools | |
| Display Modes | |
| Anyone know a good way to make a belly baggage pod? | Tedstriker | Home Built | 34 | June 29th 05 08:33 AM |
| Stolen From Checked Baggage | [email protected] | Rotorcraft | 3 | March 25th 05 01:04 PM |
| looking for a baggage door handle for a Baron/Bonanza | Baron Man | Aviation Marketplace | 0 | May 11th 04 09:38 PM |
| RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 05:08 AM |
| Bicycle's as baggage | Mike Noel | Owning | 17 | August 17th 03 05:31 PM |
