Hi All:
Is there an actual requirement that a set of jacks be installed separate from the intercom jacks that go directly to the radio? I had thought this was needed so that in case of a catastrophic intercom failure the radio would still be available. This has been present in past planes that I have owned and flown. However I just purchased a plane without any jacks going directly to the radio. Before I ruin my back wiring a direct of jacks in place I ask Are direct inputs to the radio required? If so what requires them? Thanks Paul N1431A |
No.
Jim Before I ruin my back wiring a direct of jacks in place I ask Are direct inputs to the radio required? If so what requires them? |
Hello Jim!
It's been a while! I didn't get a chance to see you at Oshkosh this year, it was a short visit for me. Hope you are doing well and that the intercom business is treating you well. I would like to let you know that the answer to the question of the original poster would actually be yes, if he was installing one of our FAA TSO'd intercoms. The reason? Because these Auxillary Mic and Headphone jacks are listed as a requirement in our approved data, (Install Manual) when installed in a certified aircraft. Home built, you are correct, but installations in certified aircraft, our approved intercoms must be installed in accordance with our approved data. Remember, manuals are part of the TSO'd approved data. Anyway, just thought I'd throw my 2 cents in. Take care Jim. Mark RST Engineering wrote: No. Jim Before I ruin my back wiring a direct of jacks in place I ask Are direct inputs to the radio required? If so what requires them? |
Mark...
Sorry to miss you at Oshkosh this year. It is always a pleasure to see you again. The intercom business has never been better, thanks for asking. My advice stands. TSO is not required for part 91 aircraft, and notwithstanding your requirement for auxiliary (sp correct) jacks, your "approved data" is not required. Again, TSO for part 91 aircraft is NOT required, nor are hardwired jacks. If you have made your manufacturer's data required for all certificated (sp correct) aircraft, then you have placed an additional burden on those part 91 aircraft owners that is not required by the regulations. A bypass switch really is the clever way to provide redundancy rather than requiring the aircraft owner to drill, install, and wire jacks that they may or may not have room for on the aircraft panel. I'd much rather depend on a single switch than extra jacks and wire. Jim wrote in message oups.com... Hello Jim! It's been a while! I didn't get a chance to see you at Oshkosh this year, it was a short visit for me. Hope you are doing well and that the intercom business is treating you well. I would like to let you know that the answer to the question of the original poster would actually be yes, if he was installing one of our FAA TSO'd intercoms. The reason? Because these Auxillary Mic and Headphone jacks are listed as a requirement in our approved data, (Install Manual) when installed in a certified aircraft. Home built, you are correct, but installations in certified aircraft, our approved intercoms must be installed in accordance with our approved data. Remember, manuals are part of the TSO'd approved data. Anyway, just thought I'd throw my 2 cents in. Take care Jim. Mark |
Hey Jim, AOPA is coming up, are you heading over to FL? If so, my treat
at Starbuck (my favorite place). OK, you have a great point, no argument from me. Please know that our intercoms do have an automatic failsafe system, so this is not the reason we have required the aux mic and h/p jacks in certificated aircraft. It's for long and short term customer satisfaction. Look at it this way, lets say after a few years of use, as with all electronics, there's a failure. Without those auxillary mic and headphone jacks, when the guy removes the intercom to return for service, he no longer has access to his radios. Now there are lots of pilots that don't feel they need to use radios to be safe, and in these cases, these jacks are, as you said, an additional burden (heck, so are those radios, they problem should pull those too). But, if they want to use the radios while flying, he can't because the link between the pilot's headset and radio has been removed. He can builds up a pass through cable using a set of male and female sub-d connectors, but that would be a big pain (in my opinion). With these auxillary jack, he just plugs his heaset in and flys away. The other point is that we get calls all the time with the complaint that the intercom doesn't work through the aircraft radio. The vast majority of the time, when asked, we find out that these jacks haven't been installed. So, trouble shooting becomes difficult at best. We explain to them the benefits of having these jacks (makes the interface from intercom to radio fool proof, continue to have access to the radio when the intercom is removed, and provides a SECOND failsafe connection to the radio in the unlikely event that the intercom goes really haywire.) We don't want to put additional burden on anyone, but we believe that these jacks are worth the effort. We never hear from them again (they are either really mad at us, or, through the process of installing these jacks, they find some sort of wiring mistake. In any event, thanks for being so available to everyone Jim, you really do provide a wonderful service to pilots, I'm sure they appreciate it too! Sincerely, Mark |
Jim's intercoms are the best that I have ever had in our
Glasair. I built a beta kit of the 564 and it has been perfect. Good volume, good squelch, failsafe direct wiring to COM1 if the intercom goes belly up, which it hasn't. Nice product at a great price for the person who likes to solder. "Tri-Pacer" wrote in message ... Hi All: Is there an actual requirement that a set of jacks be installed separate from the intercom jacks that go directly to the radio? I had thought this was needed so that in case of a catastrophic intercom failure the radio would still be available. This has been present in past planes that I have owned and flown. However I just purchased a plane without any jacks going directly to the radio. Before I ruin my back wiring a direct of jacks in place I ask Are direct inputs to the radio required? If so what requires them? Thanks Paul N1431A |
| Thread Tools | |
| Display Modes | |
| FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | Instrument Flight Rules | 0 | December 11th 03 10:41 PM |
| FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | Aviation Marketplace | 1 | October 17th 03 03:04 AM |
| FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | Aviation Marketplace | 0 | October 17th 03 02:25 AM |
| FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | Instrument Flight Rules | 0 | September 4th 03 05:41 AM |
| 4 place portable intercom For Sale | Snowbird | Aviation Marketplace | 0 | August 26th 03 01:41 AM |
