Help with QNH
Old October 26th 05, 08:35 AM
Default Help with QNH
hi,
Was wondering if someone could help me with calculating the derated
take-off thrust, if there is a change to the QNH for a given actual
takeoff weight.
I know that the thrust setting depends on temp so if you have a Actual
TOW less than the RTOW it is possible replace the OAT reading to a
higher value and therefore allowing for a reduced thrust setting on
takeoff.
What I don't understand is how this is calculated. Also what happens if
there is a change in QNH. how is this taken into account in the
calculation.
sorry if its a bit vague but got to start somewhere.
Old October 26th 05, 01:00 PM
Thomas Borchert
I can't really help you with your question, but just a hint at why
you're getting few answers: QNH is a European term for what in this
mostly American forum is known as "altimeter setting".
If I understand your question correctly, however, your interest is in
the effect of pressure and density altitude on take-off power settings.
Thomas Borchert (EDDH)
Old October 26th 05, 04:11 PM
Stefan
Just nitpicking: No, QNH is *not* a European term. The Q-code system is
defined worldwide. It is true, however, that in today's USA aviation
radio communications, the Q-codes are usually not used.
Stefan
Old October 26th 05, 04:29 PM
Thomas Borchert
Stefan,
You're right, of course. It's an ICAO term, and it is used anywhere in
the world but... Same goes for "decimal" instead of "point".
