When Poorboys drill holes ...was: Drilling holes in steel tubing
Old October 29th 05, 12:18 AM
wright1902glider
Default When Poorboys drill holes ...was: Drilling holes in steel tubing
DONE!!!!
Yep, I finally broke down and drug the table saw up the stairs. Made a
v-block out of a chunk of 2x4 that I salvaged from a dumpster.
Tried the v-block yesterday, and after 2 hours of setup time, finally
got everything aligned and drilled the holes in the bike frame.
Following that I clamped the extra tubes to the frame one at a time,
and used the holes in the frame as a guide to drill through the new
tubes. Did I mention that that also required 2 hours of setup and
alignment time?
Anyway, the tubes are now attached to the bike frame with #12 screws
and it looks pretty good. I decided not to try brazing this time
because the gap in the tube fitup was just too wide. But I will try it
when I make the model airfoils to test in the rig. I found some 3/64"
brass rod that looks promising.
Harry Frey
Wright Brothers Enterprises
Drilling holes in steel tubing wright1902glider Home Built 20 October 9th 05 04:43 AM
