antenna ground planes
Old November 2nd 05, 03:46 PM
Default antenna ground planes
I just bought a fiberglass homebuilt project with a conventional com
antenna mounted inside the leading edge of the vertical stab but it
doesn't have a ground plane yet. The instructions call for a 24in by
24in ground plane but there isn't that much room right there at the
base of the tail. Any suggestions as to what would work well? I
imagine there is info out there somewhere but am not sure where to
start looking.
many thanks,
steve
Old November 2nd 05, 03:55 PM
COLIN LAMB
If you have the room, make a vertical dipole. The bottom of the ground
plane will replace the horizontal surface. For the bottom, use a 24"
aluminum pipe. Connect the shield to the bottom pipe and run the coax down
the center of the pipe. It is better if the coax is centered.
That is all you need to do. Total length will be 48" plus the spacing of
the center insulator.
Colin
Old November 2nd 05, 04:08 PM
Philippe Vessaire
down the center of the pipe. It is better if the coax is centered.
In my Minicab i don't have the place for a full straight dipole. I just
bend the lower wire and all fit inside the fuselage.
I works fine with a Becker radio.
By
Pub: http://www.slowfood.fr/france
Philippe Vessaire Ò¿Ó¬
Old November 2nd 05, 05:47 PM
Bill Daniels
start looking.
many thanks,
steve
Take a look at the flexible dipole antennas he
http://www.wingsandwheels.com/page14.htm
Composite sailplanes have the same problem of no ground planes and
restricted space.
Bill Daniels
Old November 2nd 05, 05:59 PM
RST Engineering
antenna
What is a "conventional com antenna"?
If it is installed in the leading edge of the vertical stabilizer, how do
you intend to get a 24" length of conductor forward out into the slipstream?
Until you answer the above two questions, I can't offer suggestions.
Old November 3rd 05, 02:25 PM
Stealth Pilot
On Wed, 2 Nov 2005 08:59:35 -0800, "RST Engineering"
antenna
read it again jim.
inside the leading edge of the vertical stab ...like up inside it.
probably radio transparent fibreglass construction
how do you build a groundplane inside of the tailcone below it?
seems a reasonable post to me.
Stealth Pilot
Old November 3rd 05, 05:27 PM
RST Engineering
I *did* read it again. A "conventional com antenna" could mean anything
from a store-bought white fiberglass whip to a store-bought dipole to a
store-bought damn near anything.
And how FAR up the leading edge of the vertical stabilizer? Base right at
the fuselage junction? Six inches up? A foot up?
I understand radio transparent fiberglass. I don't understand the
configuration, and to simply spout "supposes" isn't a real good way to get
decent performance.
read it again jim.
Old November 3rd 05, 09:24 PM
abripl
A "conventional com antenna" could mean anything ...
Come on Jim. Most of us understood it to mean a regular 1/4 wave that
is used for metal airplanes with their "ground plane". You are
technically too correct sometimes.
There are all sorts of conventions addapted from coloqua. For example
"conventionaly" you know who Americans are. But America is a continent
and not a country.
Old November 3rd 05, 09:43 PM
raptor
On Thu, 3 Nov 2005 08:27:50 -0800, "RST Engineering"
decent performance.
I wonder about something else. How long would a "full wave" antenna
have to be for aviation comm radios? I've got some old walkie talkies
that have those very long pull out antenna's, they must be 5 or 6
feet. Are those full wave? And do full wave antenna's get the best
possible reception? Of course, in an airplane, the space limitation is
the problem. I use a di-pole in the vertical stab of my Glasair.
If you use a 1/4 wave antenna, and since it's 1/4 the size of the
radio wave, does that mean you will only get 1/4 of the strength that
is available in a certain location?
Old November 4th 05, 01:44 AM
COLIN LAMB
A full wave antenna wound not be what you normally want. A 1/4 wave antenna
gives you a good omnidirectional pattern, with limited nulls off the end.
If you installed a full wave vertical ground plane on an aircraft, it would
have a bit of gain - up.
Remember that gain is not free. It is realized taking the energy from one
direction and increasing it in another. Which direction are you going to
take it from? Easy when you are at a fixed location. Not so easy when you
are flying around in an aircraft.
What you hope to accomplish in a good installation is th make sure all the
connectors are installed properly, the coax is good and the antenna is tuned
for the proper frequency.
Regarding the ground plane, sometimes you have to do the best you can. If
there is not enough vertical room for a dipole or a ground plane, you could
install a 24" wire vertically in the vertical tail and then install a single
24" wire in the horizontal axis, also in the vertical tail. That will not
be perfect, but sometimes you have to live with less. You could also have
one vertical wire and three horizontal wires, serving as the ground plane,
with one in the vertical tail and two in the horizontal tail.
Colin
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Ground Stops and Ground Delay Programs [email protected] Piloting 1 February 18th 05 02:29 AM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 01:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 02:10 PM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 06:21 PM
