transponder inspection
Old November 4th 05, 10:17 PM
Matt
Default transponder inspection
Looking over my 152's logs, it appears the transponder has not been
inspected since the altitude encoder was installed, about 10 years ago. Is
it legal (not necessarily smart) to pull the circuit breaker, placard the
transponder as inoperative, and continue to fly until I get it inspected at
the next annual? I would be staying clear of class B and C.
FYI, the mode C is working fine.
Thanks for all comments.
Matt
Old November 4th 05, 11:02 PM
Jon Kraus
We had our transponder require some work and the A & P added a placard
as "transponder inop" until we got it back. As long as you stay clear of
B & C you should be OK.
I'm curious as to why you wouldn't just have the inspection done? I
don't think it is that expensive to do. We ended up buying a
remanufactured unit for about $400. So the battery in yours has lasted
10 years or is it dead?
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Matt
Old November 4th 05, 11:50 PM
Matt
The plane is VFR right now. I was thinking of installing a digital
transponder and upgrading the rest of the panel to IFR at the same time
(next annual).
Matt
Old November 5th 05, 03:41 AM
Rip
Battery?
Rip
Jon Kraus
'79 Mooney 201
4443H @ TYQ
ago. Is it legal (not necessarily smart) to pull the circuit breaker,
placard the transponder as inoperative, and continue to fly until I
get it inspected at the next annual? I would be staying clear of
class B and C.
Matt
Old November 5th 05, 02:26 PM
Jon Kraus
Yea, there is a battery in the trasponder that requires replacement
every 2 years whether it needs it or not. It is used to power the unit
in the event of a crash and no power from the ship is getting to it.
The new models use regular "D" cells while older ones (like mine)
require a proprietary battery for about $40.
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Rip wrote:
Battery?
Rip
of B & C you should be OK.
Jon Kraus
'79 Mooney 201
4443H @ TYQ
breaker, placard the transponder as inoperative, and continue to fly
until I get it inspected at the next annual? I would be staying
Matt
Old November 5th 05, 02:51 PM
Matt
I think you are referring to the ELT battery right? That needs to be
replaced every 2 years.
"Jon Kraus" wrote:
Yea, there is a battery in the trasponder that requires replacement every
2 years whether it needs it or not. It is used to power the unit in the
event of a crash and no power from the ship is getting to it. The new
models use regular "D" cells while older ones (like mine) require a
Old November 5th 05, 03:21 PM
no such thing as a battery in a transponder
Old November 5th 05, 05:10 PM
Jon Kraus
You're correct it is the ELT not the transponder... duhhh...
Old November 4th 05, 11:10 PM
J. Severyn
Why not be legal and smart and just get it checked. If it is operating
within specs it takes about 10 minutes and can normally be done right at
your aircraft using portable equipment by a certified shop. The last check
of the transponder and altitude encoder on my bird cost $95 by the shop at
KLVK. There is nothing that says the transponder/encoder and pitot static
check must happen during the annual inspection.
John Severyn
"Matt" wrote in message
Is it legal (not necessarily smart) to pull the circuit breaker, placard
the transponder as inoperative, and continue to fly until I get it
inspected at the next annual? I would be staying clear of class B and C.
Matt
Old November 4th 05, 11:19 PM
Dave Butler
Sec. 91.413
ATC transponder tests and inspections.
(a) No persons may use an ATC transponder that is specified in 91.215(a),
121.345(c), or Sec. 135.143(c) of this chapter unless, within the preceding 24
calendar months, the ATC transponder has been tested and inspected and found to
comply with appendix F of part 43 of this chapter; and ... snip
Sec. 91.215
ATC transponder and altitude reporting equipment and use.
(c) Transponder-on operation. While in the airspace as specified in paragraph
(b) of this section or in all controlled airspace, each person operating an
aircraft equipped with an operable ATC transponder maintained in accordance with
Sec. 91.413 of this part shall operate the transponder, including Mode C
equipment if installed, and shall reply on the appropriate code or as assigned
by ATC. ...
As I read it, since your transponder is not maintained in accordance with Sec.
91.413, you need not operate the transponder, and indeed may not. You just can't
go anywhere a transponder is required.
All that aside: just get it inspected. You can get the inspection done for the
cost of an hour of flying.
Dave
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Operation without a transponder flyer Piloting 11 September 14th 04 09:48 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 04:09 PM
Transponder petition Ian Cant Soaring 11 February 28th 04 07:38 AM
More on transponder petition Ian Cant Soaring 1 February 27th 04 07:37 PM
