advise on re-painting an all-wooden airplane.
Old December 2nd 05, 05:16 PM posted to rec.aviation.homebuilt
Default advise on re-painting an all-wooden airplane.
I own an all-wood homebuilt that needs a re-paint job. It's mostly
covered in plywood, but some small areas are fabric only. Fabric
covers all the wood also. The only way I can think of to prepare it
for re-painting is to sand the entire airplane down by hand, and spray
on a new coat of paint. I've talked to a few people that know that
type of construction, one was a mechanic at an approved Belanca repair
station. He said pulling the old fabric off the plywood is out of the
question, as it would probably splinter the plywood under it, taking
some of it with the fabric. I just wonder how deep to sand, as would
it be advisable to sand through all the old paint and primer, tyring
to get down to the fabric, or to just rough up the existing paint and
spray over it? Either way, I'm in for a lot of work. The plane has
1,700 hours on it, and the existing paint is too far gone to
rejuvinate, so a new coat is needed. Plus, the paint scheme needs
changing. If anyone out there has done this type of job, I'd like to
hear how it went.
Old December 2nd 05, 07:27 PM posted to rec.aviation.homebuilt
hear how it went.
What is the original finish? Dope? Enamel? Polyurethane?
Also, what is the fabric? Cotton? Linen? Glass? Dacron?
Is there a silver (or equivalent) UV undercoating?
I doubt that removal of the fabric from the wood would splinter it, as
most fabric is attached to wood by dope. The fabric will just peel off.
Remve "_" from email to reply to me personally.
Old December 2nd 05, 08:04 PM posted to rec.aviation.homebuilt
On Fri, 02 Dec 2005 18:27:58 GMT, Orval Fairbairn
The original finish is Emron, Piper Daytona white. And the fabric is
Polyfiber. I'm not sure about the undercoating, as I haven't sanded it
down into it yet. But I'm sure the builder used the Stits process,
(now Polyfiber) I would prefer to pull the fabric off, but then again,
that sure seems like an enormous job to repaint. Something to consider
when building a wood airplane. When that day comes when the paint is
worn out, a re-paint is definitely more work than stripping and
re-painting a metal plane. But I've done that job too (to a Swift) and
it's no fun either.
Old December 3rd 05, 01:33 AM posted to rec.aviation.homebuilt
it's no fun either.
OK -- You can wet sand the Imron (not Emron) down to roughen the surface
and take out any poor spots. White is a great base coat, as some colors
(especially reds) tend to show through.
Now -- a second thought: Have you tried to polish the old paint? All of
the polyurethanes (Imron is one) are extremely durable, but will oxidize
somewhat over time. If you use a power buffer (I use a Makita) and visit
your local automotive paint store, you will find some high-quality
finishing compounds (3M Perfect-It is a good one). These work very well
at restoring old paint, but are messy, as you need a fair amount of
water in the process. The buffer will sling the goop around, so masking
is a good idea.
Old December 3rd 05, 02:10 AM posted to rec.aviation.homebuilt
If you sand through the finish, you can probably soften the
underlying stuff with MEK and it will strip off the wood OK. I would
suppose that it's Poly-Brush and Poly-Spray, and MEK should attack
them.
Dan
Old December 3rd 05, 06:17 PM posted to rec.aviation.homebuilt
is a good idea.
The idea of buffing it out had crossed my mind, but the paint scheme
is un-attractive and needs to be totally changed. Not uncommon on
homebuilts. I think a lot of homebuilts end up with ugly paint schemes
due to the fact the painting is done at the end of the project, and
some builders just want to get it painted and go fly. So shortcuts and
lack of imagination are used.
Crash In The Nolichucky W P Dixon Piloting 2 June 22nd 05 05:16 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 03:54 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
