Hi group,
About three years ago I had the second most beautiful monent in my life, buying my first airplane. Last weekend it was time for the most beautiful moment in my life, I've sold the same plane for good money. I never bought it to keep it for very long, just to learn to fly after I got my license. And I did learn, and not in small amounts. It was fun too. The most important thing I've learned is what my next plane should look like. Actually, there was nothing wrong with the Rallye except its speed, or to be more exact its lack of speed :-( So my next plane has to have: -stick, -bubble canopy, -low wing. -more speed than a Rallye, -2 POB and about 80 ponds of luggage with 3 hrs of fuel. Now a question for the group. Where can I find info about N-reg aircraft and foreign ownership. The reason I ask this because somebody told me that it is allowed to fly a N-reg over JAR countries with a JAR licence. What are the FAA views about this? For the JAR part I'll ask our FAA. I ask this because there is a nice looking Mooney M10 with N-reg for sale nearby. Ok, no stick but I think I can live with that. -Kees ex MS880B. |
That's a quandry.
The A-380 has a low wing, a stick (of sorts) and is faster than a Rallye, but no bubble canopy. It does hold the requisite 80 ponds of luggage, in it's freight-only configuration. If you can sell them as fast as you sold the other one, you may have a brilliant future lined up! ;-) GF |
On 5 Dec 2005 02:38:09 -0800, wrote in
.com:: So my next plane has to have: -stick, -bubble canopy, -low wing. -more speed than a Rallye, -2 POB and about 80 ponds of luggage with 3 hrs of fuel. http://www.moravan.cz/ The Z 143 L is a single engine, four-seat, low wing, cantilever monoplane of whole metal structure. Unlike the airplanes fully made of composite materials ZLIN is built to provide great ability to access any vital part of the airplane for easy check and repairs. Operating expanses are kept low thanks to replaceability of the parts. The seat arrangement is 2 + 2. This side-by-side seating offers incredible visibility from the canopy to all passengers useful for recognition flights, patrolling and search on the ground. It is powered by a world premier TEXTRON LYCOMING piston engine, type O-540-J3A5 giving the plane more than sufficient power of 235 hp through a three-blade, hydraulic pitch controlled, constant-speed propeller, Mühlbauer type MTV-9-B/195- 45a with diameter 1950mm. The Aircraft complies with the very strict Swiss noise regulations and is certified in the lowest noise class D to be allowed for flights in the high density residential areas. NORMAL UTILITY Airspeeds Maximum level speed 262 km/h 141 kt 267 km/h 144 kt Cruising 75% MC 232 m/h 125 kt 235 km/h 127 kt Cruising 60% MC 209 km/h 113 kt 216 km/h 117 kt Stall Speed (IAS, flaps 37°) 100 km/h 54 kt 90 km/h 49 kt Max climb speed 4.9 m/s 964 ft/min 7.4 m/s 1457 ft/min Operational loading Loading limitations + 3,8 g / - 1,5 g + 4.4 g / - 1.76 g Take-off distances ALT 0 m ISA, max continuous PWR, dry concrete RWY, flaps "TAKE OFF" Take-off run 295 m 970 ft 170 m 558 ft Take-off distance to 15 m (50 ft) 640 m 2100 ft 450 m 1477 ft Landing distances Landing run 380 m 1247 ft 305 m 1000 ft Landing distance from 15 m (50 ft) 765 m 2510 ft 590 m 1936 ft Range & Endurance (ALT 3030 m, 10000 ft) 65% engine power 1070 km 578 NM 506 km 273 NM 58% engine power 1314 km 709 NM 570 km 308 NM Maximal Endurance (58% engine power) 6° 14¢ 2° 47¢ Ceiling Service Ceiling 4170 m 13681 ft 5700 m 18701 ft Weights Empty weight 850 kg 1874 lbs 850 kg 1874 lbs Maximum take off weight 1350 kg 2976 lbs 1080 kg 2380 lbs Crew: 2 pilots 200 kg 441 lbs 200 kg 441 lbs PAX: 2 passengers 200 kg 441 lbs - - Baggage: back lockable compartment 60 kg 132 lbs - - Baggage: cabin compartment 20 kg 44 lbs - - |
Buy your old one back - you'll always miss it even if you get something
better. |
"Morgans" wrote:
wrote So my next plane has to have: -stick, -bubble canopy, -low wing. -more speed than a Rallye, -2 POB and about 80 ponds of luggage with 3 hrs of fuel. How about a RV 8? Nice handling, fast, low upkeep. If homebuilts are included, I think the RV-7, 8, or 9 would do since a bubble flip-up canopy option is available for all three models. |
![]() wrote So my next plane has to have: -stick, -bubble canopy, -low wing. -more speed than a Rallye, -2 POB and about 80 ponds of luggage with 3 hrs of fuel. How about a RV 8? Nice handling, fast, low upkeep. -- Jim in NC |
Larry Dighera wrote:
http://www.moravan.cz/ The Z 143 L is a single engine, four-seat, low wing, cantilever monoplane of whole metal structure. No price or cabin width info... |
Hi Paul,
Some things I'm going to miss for sure. Hovering, flying backward. 1500 fpm @ 55kts on short final. The very short landings. Harrier jump jet style take off. I was thinking about buying a Rallye with a bigger engine, but they are not much faster just climb better. -Kees. |
I do not think the guys in the tower at my home field will be happy
after the first landing with an A380. After that the tower will be better known as the pile-of-rubble-with-a-yellow-sign-showing-the-letter-C. ;-0 -Kees |
My first aerobatic lesson | Marco Rispoli | Piloting | 6 | April 13th 05 02:21 PM |
Rental policy | Robert | Piloting | 83 | May 13th 04 05:29 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
