PA28 Battery replacement
Old December 5th 05, 02:55 PM posted to rec.aviation.owning
Default PA28 Battery replacement
Hey all. I'm pretty certain I've convinced myself that my "bad starter"
and/or bad ring gear are actually my battery going bad. With the skytec starter, it
makes sense that at high-load, the voltage could drop enough so the starter solenoid
cannot hold the gear engaged to the flywheel. It pops back out while cranking on a
compression stroke.
So, what are the thoughts on the different batteries? I'm pretty sure mine is
the old Gill G35. It's been in there for at least 3.5 years. Any good replacement
ones that might save weight, etc? FWIW it's a 180hp O-360 so it is high compression.
Thanks
-Cory
* Cory Papenfuss *
Battery Question [email protected] Soaring 19 September 15th 05 02:38 AM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 02:37 AM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 03:38 PM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 02:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 07:32 PM
