I have a Winpilot Adv. 6.09 and a ILEC SN-10
and a Volkslogger. My question has to do with the accuracy of the wind displayed in the cockpit. Is it true that I should rely on the wind shown on the ILEC SN-10 and not that shown on the Winpilot? If this is true, I would like to understand the reason(s). Thank you. Doug Whitehead (EDW) |
My experience is that the wind calculation of the SN10 is extremely
reliable and accurate. I reckon WP is as good as any other device calculating based on circling drift only, like the LX20 for example. I often compare SN10 and LX20 values and normally the SN10 is far better. I'm sure Dave N. can explain why. Marcel |
Doug,
I'm curious to know how much variation you get between the two, if any. I use WinPilot Pro 6.x and an LX7000 Pro, and the two wind indications are usually very close. ~ted/2NO |
I tend to agree with Marcel. I also fly with an ILEC SN-10 and an IPAQ
with Winpilot. My sense is that algorith and precision from the SN-10 is always more accurate than Winpilot. The reason I say this is the same as what Marcel mentioned, which is the ILEC is capable of calculating windspeed and direction while in level flight, whereas most other software/computers require you to be circling. Respectfully, wrote: Doug, I'm curious to know how much variation you get between the two, if any. I use WinPilot Pro 6.x and an LX7000 Pro, and the two wind indications are usually very close. ~ted/2NO |
Don't know 'bout Doug but I find LX- computers give you fairly exact
wind indications IF you circle steadily keeping bank and airspeed as constant as possible for a few circles. Then I normally get very silmilar values on the LX20 and SN10. Not being careful doing that the values often are 20-40% apart in strength and 20-60° in direction. Especially in weak wind the values can differ 180°! |
Well, I could explain but then I'd have to kill you ;-)
I'm really not sure what algorithms other software currently uses, but my understanding is that we have a big advantage by using ASI as well as GPS. Happy Holidays and Best Regards, Dave MaD wrote: My experience is that the wind calculation of the SN10 is extremely reliable and accurate. I reckon WP is as good as any other device calculating based on circling drift only, like the LX20 for example. I often compare SN10 and LX20 values and normally the SN10 is far better. I'm sure Dave N. can explain why. Marcel |
Borgelt also uses true airspeed and GPS derived groundspeed to
calculate wind speeds in non-circling flight. I found my B 2000 agreed pretty well with my colleagues' SN10s so I imagine Dave's algorithms are similar. Now I have an SN10, I check the measured wind vertical profile with thaqt predicted from the sounding forecast. Agreement between forecast, SN10 and other instruments is well within expected errors. Mike |
Calculation of windspeed and wind direction without circling:
Here's my understanding. If it's not correct, doubtless someone will straighten me out and I will have learned something. DISCLAIMER: I have absolutely no "inside" information on the algorithms used in the SN10! Aircraft heading (direction the nose is pointing) and airspeed together define a velocity vector that can be drawn as an arrow on a piece of paper, the angle of the arrow representing the direction and the length of the arrow representing airspeed. Starting at the tip of this arrow we can add a second arrow representing wind speed and direction. If we now draw a third arrow that closes the triangle (from the start of the first arrow to the end of the second) this arrow represents the aircraft track (direction of travel over the ground) and ground speed, this being the classical "wind triangle" well known to pilots. Note that defining any two of the vectors of a wind triangle automatically defines the third, this vector (like all vectors) being defined by its magnitude and direction. The above describes the graphical addition of two vectors.We can also do vector addition (or subtraction) mathematically, instead of plotting arrows on paper. The key point here is that the six quantities involved, aircraft heading, aircraft airspeed, wind direction, wind speed, ground track and ground speed define three vectors that are related mathematically by a single (vector) equation: In the case of a sailplane with an SN10 that has input from a GPS, we have three knowns, namely true airspeed (the SN10 can compute this from pitot pressure, static pressure, altitude and temperature), groundspeed and track (the last two come from the GPS). There are three unknowns, aircraft heading, wind direction and windspeed. Basically, multiple unknowns can be calculated by setting up and solving simultaneous equations. There are well known mathematical and computer algorithms for doing this. If we make the assumption that the wind direction and speed are constant (at least in the short term, and within a given altitude band) and if (in the same short term) the sailplane flies on two distinct headings and / or airspeeds within that altitude band, we have two different sets of "known" values to insert into the vector equation. We can treat the resulting equations as simultaneous equations and solve for the above-mentioned unknowns. For the best result, the headings and /or airspeeds should be as different as possible. Theoretically, we can get a unique solution as long as the headings and / or airspeeds are not absolutely identical, but in the real world, it appears that (at least sometimes) we need significantly different headings to get a reliable result. Bear in mind that the even if the windspeed and direction are indeed constant, the three "known" values are not known with absolute precision and computers always introduce round-off errors, some of which can get to be significant in these types of calculations. Remember too, mathematically-speaking we are cheating. The "known" values that are plugged into "simultaneous" equations should really be values that are measured simultaneously! In this case, they are not, they are values derived at different times and places, the main effect of which is to make it more likely that the initial assumption of constant wind speed and wind direction is not quite correct. If we continue to fly in the same altitude band, with new headings/ airspeeds, we can get new and different input values that can be plugged in and solved for new values of windspeed and direction. For the reasons stated above, these results will not be all the same. If the results are clustered closely together, we can have a high confidence in them. If the values are all over the place, we can still display a value for the user (pilot), e.g., by averaging a number of results, but we will have a low confidence in the displayed values. (Note: the SN10 does indeed display a confidence value for each calculated wind speed and direction). Advantages over windspeed and direction calculated from circle drift: there's the obvious one that you don't have to circle to get a result. Additionally, a circling sailplane pilot will often be moving his circle to get better centered, and such shifts adversely affect the wind calculation. And anyway, who ever flies perfect circles? Disadvantages? In practice, the method does seem to require significant heading changes and sometimes (e.g. some ridge flying, straight line cruises between thermals, some wave flights) these are just not available. I have flown with an SN10 for several years and sometimes found it necessary to make one or more deliberate heading changes to get a calculated wind that makes sense. If an accurate aircraft heading sensor were added to the SN10, thus completely defining two of the vectors in the "wind triangle", this would not be necessary. One lives in hope... Ray Roberts wrote in message oups.com... Well, I could explain but then I'd have to kill you ;-) I'm really not sure what algorithms other software currently uses, but my understanding is that we have a big advantage by using ASI as well as GPS. Happy Holidays and Best Regards, Dave MaD wrote: My experience is that the wind calculation of the SN10 is extremely reliable and accurate. I reckon WP is as good as any other device calculating based on circling drift only, like the LX20 for example. I often compare SN10 and LX20 values and normally the SN10 is far better. I'm sure Dave N. can explain why. Marcel |
Ray Roberts wrote:
If an accurate aircraft heading sensor were added to the SN10,=20 thus completely defining two of the vectors in the "wind triangle", = this=20 would not be necessary. One lives in hope... That is exactly what the Zander SR940, ZS1 and (I believe) all other = flight computers with compass coupling do. It makes good wind speed = readings possible in straight flight even without weaving. Furthermore, = for reasons that I cannot explain, the wind vectors calculated by the = computers above in circular flight are not affected by bank angle = changes. |
"Ray Roberts" wrote in message
. .. Calculation of windspeed and wind direction without circling: Here's my understanding. If it's not correct, doubtless someone will straighten me out and I will have learned something. DISCLAIMER: I have absolutely no "inside" information on the algorithms used in the SN10! Aircraft heading (direction the nose is pointing) and airspeed together define a velocity vector that can be drawn as an arrow on a piece of paper, the angle of the arrow representing the direction and the length of the .... In the case of a sailplane with an SN10 that has input from a GPS, we have three knowns, namely true airspeed (the SN10 can compute this from pitot pressure, static pressure, altitude and temperature), groundspeed and track (the last two come from the GPS). There are three unknowns, aircraft heading, wind direction and windspeed. Basically, multiple unknowns can be calculated by setting up and solving simultaneous equations. There are well known mathematical and computer algorithms for doing this. .... makes sense. If an accurate aircraft heading sensor were added to the SN10, thus completely defining two of the vectors in the "wind triangle", this would not be necessary. One lives in hope... For $300 you can add a fluxgate compass that will communicate via NMEA... Fixing the software to use it would be up to you. Of course, the heading information will only be good when you are flying straight and level... http://www.westmarine.com/webapp/wcs...001/606/137/14 -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
| Thread Tools | |
| Display Modes | |
| WinPilot offer... and UK news | Paul Crabb | Soaring | 2 | February 19th 04 10:22 AM |
| Volkslogger, LX160 and WinPilot ADV | Michael Nyrup | Soaring | 1 | November 24th 03 07:21 AM |
| WinPilot Offers Free WinPilot XP for your Desktop Computer | Richard Pfiffner | Soaring | 0 | November 8th 03 05:44 PM |
| Declaring a flight in WinPilot to the Volkslogger | JohnD | Soaring | 0 | October 2nd 03 12:55 AM |
| Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 04:06 PM |
