Anyone know the weight difference?
Old January 5th 06, 03:08 AM posted to rec.aviation.homebuilt
Default Anyone know the weight difference?
Does anyone have the knowledge of what the weight difference is between
1 square ft. of 3 mil. plywood and 1 square ft. of 1/2" styro core
composite?
Or maybe someone could give me the weight of the 1 square ft. of 1/2"
styro core composite?
Lou
Old January 5th 06, 07:42 AM posted to rec.aviation.homebuilt
On Wed, 04 Jan 2006 19:05:51 -0800, Richard Riley
:1 square ft. of 3 mil. plywood and 1 square ft. of 1/2" styro core
:composite?
:Or maybe someone could give me the weight of the 1 square ft. of 1/2"
:styro core composite?
: Lou
Sorry, not enough information to be accurate but we can wing it :^)
The core's going to be around 2 - 3 oz. Bidirectional fiberglass will
be about 1 oz per ply plus 1/2 oz per ply for epoxy. 2 or 3 plies per
side, so about 8 to 12 oz. YMMV
You can make it a whole lot more compact if you use Vinyl Ester Resin
though. I'm assuming you are talking about Styrofoam (TM) the blue
construction foam. (has a styrene solvent in it)
I was using some Styrofoam as spacers under one corner at the front
end of the G-III. I "dripped" a little excess Vinyl Ester resin on
the *stuff* and it just plain vanished. I guess there is a reason
they don't use that stuff on wet lay-ups over Styrofoam cores. :-))
www.rogerhalstead.com
Old January 5th 06, 05:53 PM posted to rec.aviation.homebuilt
"Lou" wrote in message
composite?
The weight difference between Okume or Mahogany plywood and that of Finnish
Birch is significant as well.
Rich S.
Old January 5th 06, 07:02 PM posted to rec.aviation.homebuilt
Thats true, the plane I'm building calls for 3 mil Okume. I've come
across a website of a kr2 builder who decided to install the
composite/foam instead of plywood. Unfortunatly he didn't weight
anything before he made this change. Also he oversized everything on
the plane and made quite a few modifications. His plane is overweight,
but doesn't know if it's from the redesign, the oversize, or the
material change. I like how it's coming out and it promises to be a
very slick machine.
Lou
Old January 5th 06, 10:33 PM posted to rec.aviation.homebuilt
very slick machine.
Sure hope he registers it as a "Swiftfoam Special" or something other than a
"Rand KR2". I can understand the toothgrinding that a designer suffers when
someone substantially alters their design, yet keeps the name the same.
2 mm Finnish Birch is the equivalent in weight and strength to 3 mm Okume,
IIRC.
Rich S.
weight difference Lou Parker Home Built 7 October 27th 04 03:42 AM
Dutch Roll SelwayKid Piloting 31 June 20th 04 12:43 AM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 05:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 08:32 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 05:20 AM
