Torque wrenches...
Old January 10th 06, 01:31 AM posted to rec.aviation.homebuilt
Default Torque wrenches...
Anyone know any good sources for these.
It seems like I will be needing a nice repeatable one in the 5-100 in/lb range for 10-32 screws and nuts. I am not sure
what the torque is that I will be using, the screws are AN509-R10 (MS24694 #10) and the nuts are MS21040-3. I have seen
from 20 in/lbs to 60 in/lbs for these.
TIA
Dan DeVillers
http://www.ameritech.net/users/ddevillers/start.html
Old January 10th 06, 07:10 PM posted to rec.aviation.homebuilt
My personal ones are Snap-On's. All of ours at work are also Snap-On.
At 20 inchpounds, you are almost down to the point of needing to use
torque watches instead.
Craig
Old January 10th 06, 09:31 PM posted to rec.aviation.homebuilt
I concur with Craig. If your'e going to buy a torque wrench, buy a good one
and stay away from Taiwanese junk. I tried that. Bought one from Harbor
Freight (cheap). You get just what you pay for. I suspected that the torques
wern't right and had it checked out by an instrumentation lab at work. Was
repeatably 35 in/lbs over set value. Couldn't set low enough to use and
finally just threw it out. Real bargain. I bought one from Avery Tools for
$150.00 (same as those made for Snap-On). Was right on the money for torque
values. It's your plane and your life on the line. What's it worth?
Bill
Craig
Old January 11th 06, 03:20 PM posted to rec.aviation.homebuilt
On Tue, 10 Jan 2006 00:31:04 GMT, ".Blueskies."
TIA
I paid $aus250 for the smallest australian Warren & Brown.
it is a round section tempered beam with a separate rectangular
section pointer and a click indicator mechanism. measures 10 - 210
inch pounds.
almost impossible for it to go out of tolerance.
whole thing is under 9 inches long.
almost the only thing I use it for is tightening my prop bolts.
but worth every penny to get these right.
if you are totally stuck in the usa email
Stealth Pilot
australia
Continental A-75 hub torque SteveR Home Built 8 July 21st 05 10:49 PM
Proper Torque for Fuel Fittings Steve Waltner Home Built 10 February 20th 05 01:46 AM
Torque values for oil screen John Clonts Owning 2 January 25th 05 01:01 AM
Drum dia and torque Bob Johnson Soaring 15 November 22nd 04 08:37 PM
Prop bolt torque setting Whunicut Home Built 2 September 4th 03 01:12 PM
