New gun
Old January 23rd 06, 06:15 AM posted to rec.aviation.homebuilt
Default New gun
Interesting development in guns.
Big John
New super-gun to be tested in Feb
By PAMELA HESS
UPI Pentagon Correspondent
WASHINGTON, Jan. 20 (UPI) -- Next month a new high-explosive munition
will be fired in Singapore and then tested again by the U.S. Army,
heralding what may be a sea change in weaponry: a gun that can fire
240,000 rounds per minute.
That's compared to 60 rounds per minute in a standard military machine
gun.
Metal Storm Inc., a munitions company headquartered in Virginia but
with its roots in Australia, has been developing a gun that can shoot
at blistering speeds, albeit in short bursts as each barrel is
reloaded.
A Metal Storm gun of any size -- from a 9 mm hand-gun up to a machine
gun size or a grenade launcher -- has no moving parts other than the
bullets or munition inside the barrel. Rather than chambering a single
slug for each shot - very quickly in the case of machine guns -- the
bullets come pre-stacked inside the barrel and can be shot all at
once, or one at a time, as the shooter decides through the electronic
controls.
Because there are no moving parts, the weapon is less likely to jam,
and will presumably need less maintenance.
Lashing many barrels together increases the number of rounds per
second. Once fired, however, each spent barrel has to be reloaded.
Starting in 2006 the company will demonstrate its prototypes with
applicability that is especially likely to interest the U.S. military.
The weapon system can be mounted on an unmanned ground combat vehicle,
an unmanned aerial vehicle, and might be used as a defense against
rocket-propelled grenades and mortars.
Metal Storm's speed allows it to lay down a blinding wall of slugs
that can intercept and pulverize incoming enemy fire, according to
company CEO David Smith. As long as the grenade or mortar is fired
from outside a range of about 50 meters or 162.5 feet and a Doppler
radar is in use, a Metal Storm system could be an effective defense,
he told UPI.
Closer than that and there is just not time to react.
"But if you are from 50 meters and beyond, if everything can work fast
enough -- the radar -- there is enough time mathematically" to shoot
down incoming fire, Smith said.
At least 153 U.S. troops have been killed in Iraq by enemy rockets and
mortars since the start of the war. Nearly 2,000 have been wounded.
The grenade launcher barrel can also carry less-than-lethal munitions,
like small bean bags, sponge grenades or smoke. On Jan. 16, the Army
awarded Metal Storm a $975,000 contract to further develop its
non-lethal rounds.
"Our so-called competition is (the) Mk19 - grenade machine gun," Smith
said. "It's enormously heavy. It takes six people to carry it into a
battlefield scene. It's not mobile.
"But the military has had this transition out of big system
warfighting into much lighter, higher firepower that can be carried
into battle by individuals or light vehicles. Our guns have no moving
parts -- so they have the same amount of fire power at significantly
reduced weight ratio."
Metal Storm technology has been under development for about a decade,
but a series of small-business innovative research contracts awarded
recently by the Department of Energy and the Army mean prototypes are
now being produced and demonstrated.
"We are to the point we can start providing prototypes. The Army is
very, very parochial in how they buy weapon systems," Smith said. "But
now we can put it into an actual environment."
The company is also studying whether it can mount a Metal Storm weapon
on a small helicopter, particularly looking at the recoil effect from
the gun.
Smith said such a system - deployable down to the squad level -- could
be useful in a place like Iraq, where it's a common tactic for
insurgents to launch a mortar and then run. By the time soldiers on
foot or in a vehicle get to the launch site, the shooters are long
gone. But a UAV quickly launched can see where the shooters run to,
and if a gun is on board, can shoot at them.
The Australian military is testing a Metal Storm gun of its own, the
Advanced Individual Combat Weapon (AICW). The AICW combines both an
assault rifle and a 40 mm grenade launcher in a single unit with a
common trigger, allowing the shooter to choose which munition he wants
to fire without having to refit his weapon. It also allows three
grenades to be fired at once, whereas one is the only option in the
current generation of weapons.
Metal Storm Inc. will demonstrate a high-explosive munition with a
10-meter (32.5 feet) or burst radius in Singapore on Feb. 6, Smith
said, and for the Army's Picatinny Arsenal and Armament Research,
Development and Engineering Center later that month.
© Copyright 2006 United Press International, Inc.
Old January 23rd 06, 06:55 AM posted to rec.aviation.homebuilt
Default New gun
Metal Storm Intro
http://tinypic.com/view/?pic=mhabrr
Metal Storm Pistol
http://tinypic.com/view/?pic=mhabfr
Metal Storm UAV
http://tinypic.com/view/?pic=mhabl4
Metal Storm Area Denial
http://tinypic.com/view/?pic=mhabv8
Metal Storm Aircraft Pod
http://tinypic.com/view/?pic=mhac11
Metal Storm Robotic Grenade Launcher
http://tinypic.com/view/?pic=mhac76
The Monk
Old January 23rd 06, 07:03 AM posted to rec.aviation.homebuilt
Default New gun
"Big John" wrote in message
Big John
By PAMELA HESS
gun.
That oughta' be 600 rounds per minute. It's still a lot fewer than the metal
storm, though.
Harold Burton
Old January 23rd 06, 08:27 AM posted to rec.aviation.homebuilt
Default New gun
"Richard Riley" wrote
Whether or not MetalStorm is a good concept (and I have doubts)
they've had remarkable success at getting press. I've been seeing
them in the general media for about 2 years, with nothing more than a
few prototypes and a contract for a design study. They all talk about
how it can fire a million rounds a second. They don't follow up with
"for 1/100,00th of a second."
Yeah, then heaven forbid the bad guys know we have that, then fire a 2nd,
3rd or 4th round at us. Until the system is reloaded, everyone is standing
around with their pants down around their ankles.
I'll make a bold prediction and say that it never leaves the prototype
stage, except for a few odd applications.
Old January 23rd 06, 09:31 AM posted to rec.aviation.homebuilt
Default New gun
2nd, 3rd or 4th round at us. Until the system is reloaded, everyone is
standing around with their pants down around their ankles.
You are probably right, Jim, but think of the Navy's AGIS.
Close-in high-rate radar-guided anti-air fire.
(A lot of dashes, but you get the drift)
Scale it down for use against ground threats - at a reasonable price -
and you've got youself a market.
It's one of the things they mentioned.
Richard
Old January 23rd 06, 10:28 AM posted to rec.aviation.homebuilt
Default New gun
Yes, but AGIS can shoot off a couple of bursts (maybe more) then put some
more ammo to it and keep going. With this, you change out the whole system,
guns and all. Sounds like a lot more time between being ready for new
threats, and being exposed while reloading, or lots of systems mounted all
at once,
I could see this new system mounted on a hummer or Bradley for RPG
protection, but you shoot one RPG, unload the system, then fire another RPG
and get right through.
Good idea, but I just can't see it being practical.
The best way to use it might be for IED's disposal, mounted on a RC vehicle.
Now if we could just detect them all.....
Old January 23rd 06, 11:23 AM posted to rec.aviation.homebuilt
Default New gun
Richard Riley wrote:
On Mon, 23 Jan 2006 07:03:47 GMT, "kd5sak"
:"Big John" wrote in message
: Interesting development in guns.
: Big John
: New super-gun to be tested in Feb
: By PAMELA HESS
: UPI Pentagon Correspondent
: WASHINGTON, Jan. 20 (UPI) -- Next month a new high-explosive munition
: will be fired in Singapore and then tested again by the U.S. Army,
: heralding what may be a sea change in weaponry: a gun that can fire
: 240,000 rounds per minute.
: That's compared to 60 rounds per minute in a standard military machine
: gun.
:That oughta' be 600 rounds per minute. It's still a lot fewer than the metal
:storm, though.
I'm with you. Looks like more smoke than fire at present.
Matt
Old January 23rd 06, 01:52 PM posted to rec.aviation.homebuilt
Default New gun
It's as good as a shotgun, no?
The Monk
Old January 23rd 06, 02:14 PM posted to rec.aviation.homebuilt
Default New gun
"Matt Whiting" wrote in message
Matt
Would seem to me to have possibilities if clustered and used as a variation
on the principle of the Claymore mine. Would think a Claymore would be more
economical though.
HWB
Old January 23rd 06, 03:19 PM posted to rec.aviation.homebuilt
Default New gun
I'd like to have one mounted on my Skycar for to shoot evildoers.
Rich
