Poll: Ignition Harness Replacement
Old January 26th 06, 07:03 PM posted to rec.aviation.owning
Default Poll: Ignition Harness Replacement
The ignition harnesses on our Aztec are not the newest items on the airplane
by any means. In fact, if somebody told me that they were original, I
wouldn't be able to refute it. Our's show some fraying of the outer cover,
some of the cigarettes are looking pretty old, showing fatigue, some of the
contact springs look tough, ect. Relatively speaking, new harnesses are
also not the most pricey items I've investigated, especially for the
performance that we get out of them.
So, what say the group?
Replacement Ignition Harnesses...
Who's replaced them?
Reason(s)?
Engine Make/Model?
Airplane Make/Model?
Straight or 90 degree?
Standard or all weather?
Best or worst brands or manufacturers?
Custom features or wire sizes?
Thanks as always.
Old January 27th 06, 12:58 AM posted to rec.aviation.owning
On Thu, 26 Jan 2006 13:03:16 -0600, "Jim Burns"
Me.
Reason(s)?
You name it. old-and-trashed, oil soaked and deteriorated, burnt,
abraded by water, corroded hardware, chafed, pinched, cut..primarily
because I allegedly got paid to do it.
Engine Make/Model?
Pick one. 4-to-1 Lyc-to-TCM
Every "modern" Piper except a TCM Malibu, lotsa Cessna/Beech singles,
couple of Barons.
Both, depended on the install.
Both, depended on the install. Don't recall ever "converting" one from
standard to all weather.
Standard Unison/Slick harnesses are inexpensive and relatively easy to
repair, you can usually shorten them a couple times before poking in a
replacement lead. The silicone coating will gradually abrade and get a
little funky looking. Downside is they don't like the heat, and unless
they've changed the plug nut from the aluminium I'm familiar with, the
nuts will gall if you try to force them onto a boogered or corroded
sparkplug. Poking on a new nut on is fairly simple.
Have also used Bendix/TCM harnesses. They are pretty much mandatory on
turbo installs (w/90 degree elbows) depending on the wire routing so
you can keep them away from the exhaust stacks. They hold up a lot
longer, are a little tougher to repair/poke in a new lead. Cad-plated
steel nuts won't gall on funky plugs.
Didn't have any real need for them.
On our Aztec's we always used the standard Unison harness with
straight (all weather) ends, secured the lowers to the intake pipes,
uppers to baffle bolts extending through the head to the "inside" with
plain nuts/lock washers. We used the Unison's 'cause when (not if,
when) an exhaust gasket blew or a stack dropped and semi-torched the
lead they were easy and cheap to replace.
Really doesn't make a big difference whose leads you use if you are
careful routing and securing them.
TC
Old January 27th 06, 02:52 AM posted to rec.aviation.owning
On Fri, 27 Jan 2006 02:36:32 GMT, Orval Fairbairn
This is a good reason to use blowproof exhaust gaskets -- I have never
seen one blow. I would never use the copper/asbestos type again!
We yanked the exhaust every 100 hours (2-4 months) to free up the
ball- and slip-joints, inspect for cracks, and r/r the exhaust
gaskets. Used either the crappy c/a's or 2 stacked "all coppers". The
exhaust studs weren't long enuff to accommodate the heavy metal
blo-prufs, the flange, a washer and a nut. Am thinking toward the end
we were using low height stainless lock-nuts on 'em (from another OEM
exhaust install) and some would still would shake loose in 100 hrs.
When we switched to stacks with thicker flanges, the stacks lasted
longer, but it made the "thickness" problem worse.
At least we didn't have to worry about seized nuts...
TC
Old January 27th 06, 04:00 AM posted to rec.aviation.owning
Me, for one.
Reason(s)?
One wire went bad and the second plug on that cylinder fouled due to the poorer
flame front (I suppose). It made for an unpleasant flight (SEL, 4 cylinder). I
did not want to repeat the experience and figured the rest would go soon, one at
a time. It would also be cheaper to pay the mech once, rather than uncowling 8
times.
Engine Make/Model?
Continental O-200-A.
Cessna 150J.
Straight.
Standard.
Mechanic's choice - I don't know.
No.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
2005 SSA Contest Rules Poll and Election [email protected] Soaring 0 September 27th 05 01:47 PM
Ignition problem? nauga Home Built 10 July 1st 04 02:15 AM
Citabria aerobatic harness Ed Wild Aerobatics 0 February 1st 04 05:38 PM
Electronic Ignition Andre Home Built 1 September 5th 03 06:15 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
