Oil leaks?
Old February 3rd 06, 09:18 PM posted to rec.aviation.owning
Default Oil leaks?
Looks like my mechanic just found a small crack in the bottom of my
oil pan
I had noticed a small amount of oil on the belly, around the front
gear well, and a small bit coming out the top of the cowling at the
oil access door that normally wasn't there.
Had him pull the cowling off and after a dye check, he found a small
crack.
Anyone have any experience with something like this?
Is there any kind of seal that can apply?
Welding options?
Cost of replacement?
Do nothing?
Any thoughts would be appreciated.
Thanks.
Daren
Compression Tests Doug Owning 10 March 27th 04 07:17 PM
Compression Tests Doug Aerobatics 4 March 27th 04 06:29 AM
Compression Tests Doug General Aviation 5 March 27th 04 06:29 AM
finally go fly and now we freeze (172 air leaks) Mike Z. Owning 11 December 11th 03 06:22 PM
Observations about oil leaks Ben Jackson Owning 5 October 10th 03 12:03 AM
