CoPilot for Palm Pilot ??
Old February 14th 06, 11:19 AM posted to rec.aviation.piloting
Default CoPilot for Palm Pilot ??
Hi guys,
Just got me a Palm pilot and have downloaded some software for it. I'm
particularly interested in using it for loading etc..
Ive come across a program called "CoPilot" and it seems pretty good (for
a freebie). Anyone else use this program, i'm having trouble setting it
up for use with R22 and R44 aircraft..
Any other loading software anyone recommends ???
thanks,
Jad
Old February 14th 06, 01:35 PM posted to rec.aviation.piloting
Ive come across a program called "CoPilot" and it seems pretty good (for a freebie). Anyone else use this program, i'm having trouble setting it up for use with R22 and R44 aircraft..
I use co-pilot all the time, and it's terrific. What problems are you
having adding the R22 and R44? (helicopters or homebuilt planes?)
Jose
Money: what you need when you run out of brains.
Old February 14th 06, 03:38 PM posted to rec.aviation.piloting
What sort of trouble? I don't know if it's an issue, but CoPilot doesn't
do left-to-right weight and balance, and I read somewhere that
left-to-right is important in helicopters.
Have you discovered the waypoint generator at http://navaid.com/CoPilot/
yet?
Any sufficiently advanced technology is indistinguishable from magic.
-- Arthur C. Clarke
Old February 14th 06, 03:42 PM posted to rec.aviation.piloting
You can dummy it up though. Create an aircraft R22A, and put in
left-right stations as if they were front-back stations. Do both
calculations (relying on the front-back for total weight envelope) and
if you are ok for both "aircraft" you should be good to go.
Jose
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 11:33 AM
Sport Pilot pilots not insurable? Blueskies Piloting 14 July 12th 05 06:45 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Piloting 114 July 22nd 04 06:40 PM
