Hole Finder
Old March 5th 06, 09:46 PM posted to rec.aviation.homebuilt
Default Hole Finder
There are a few accomplished and talented brains here that can help
with this. We have a tailwheel steering control horn with holes
already drilled at right angles through its long shaft for two AN-3
bolts-- to fix it inside the rudder's vertical tube. Now when the
shaft is inserted up inside the 4130 tubing of the new rudder, what
would be the best way to drill the rudder's tube accurately, without
missing the holes in the shaft or wallowing them out? Those two AN-3
bolts are in shear and of course fasten the tailwheel steering horn to
the rudder. We want precision, and no slop. The old rudder's holes
looked like hell.
I can see where the problem was encountered elsewhere and the holes in
the tailwheel steering horn were elongated, then welded back and
re-drilled-- not such a good idea since the control horn is aluminum
alloy.
Ever seen that little mag-pecker device that lets you find a blind hole
you need to drill through to? There is a magnet centered in the blind
hole, which a sharp needle points to, making a prick in the precise
spot where you drill. Well, I don't think it will work here, but bet
you could make one that would.
TIA and apologise for all the Freudian terms.
Old March 6th 06, 03:12 PM posted to rec.aviation.homebuilt
Default Hole Finder
Gee I'm surprised none of the resident experts has responded to your
question yet. Especially since it begs for a smart-axx answer
Simple, use a hole finder.
Same principle at the commercial ones that you buy.
Overlay a thin piece of metal over the horn's shaft to mark the holes and
fasten at a point below what is being inserted in the rudder tube.
Slide the horn and into the rudder and keep the hole finder on the outside.
Wa lah you have the hole location.
I'm not sure what degree of precision you are desiring.
Use a small drill to open the hole in the rudder tube then use appropriate
piloted or non-piloted reamers for final sizing.
looked like hell.
alloy.
*** Free account sponsored by SecureIX.com ***
*** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com ***
Old March 6th 06, 03:32 PM posted to rec.aviation.homebuilt
Default Hole Finder
Excellent, my friend. Thanks.
That is precise enough. We just don't want any slop so that you have
to use tension loads rather than shear to hold the yoke in place.
What size hole saw do I use? [email protected] Home Built 22 July 16th 05 09:21 AM
DIGGING A DEEPER HOLE Cribsheet Piloting 3 December 10th 04 01:00 AM
How to drill a cenetered hole in end of solid rod Scott Home Built 21 November 2nd 04 04:04 PM
Finding vent hole in wing skin Martin Eiler Soaring 7 November 21st 03 02:44 PM
Fairing question... Tina Marie Home Built 5 July 16th 03 01:18 AM
