ASW20A and Cirrus
Old March 10th 06, 08:49 PM posted to rec.aviation.soaring
Default ASW20A and Cirrus
Hi guys,
After spending some time in Phoenix on a Grob 103,
I have started looking for my first glass glider. I
am currently looking at an ASW20A and a Standard Cirrus.
I know they are quite different. I guess my concerns
are the full flying tail on the Cirrus and the flaps
on the ASW. Any thoughts would be appreciated.
Jeff
Old March 10th 06, 09:37 PM posted to rec.aviation.soaring
I'll confine my comments to the ASW-20. I've flown four different ones
over the years. All handled beautifully in normal flight, but flying
slow in positive flap, two were perfectly benign, and the other two had
a tendency towards abrupt stall and spin entry with essentially no
warning. For whatever reason, there is some variation in stall/spin
characteristics from ship to ship. The good ones are suitable for
anyone with glass experience, the bad ones would be an unfortunate
choice for a low time pilot, given the limited amount of spin training
here in the US.
The other issue to note is that ASW-20s have a manual elevator hookup.
Some would argue that this is not an issue for the careful pilot, but
two of my otherwise careful friends managed to get careless with this
hookup, and are no longer with us.
If you want a 20, and can afford to pay a bit more, get a 20B or 20C, as
their spin characteristics are more predictable, and they have automatic
elevator hookups. There are other gliders in this price range worth
considering, including ASW-19, Std Jantar, DG-100/101, Std Libelle (if
you're small), Hornet, Mosquito, LS-1, LS-3, and LS-4.
Marc
Marc
Old March 10th 06, 10:52 PM posted to rec.aviation.soaring
Std Libelle (if
Yes, really I advise you not to get hung up on one
or two types - there are many fantastic gliders out
there. The ASW-19 is a fantastic first glider, forgiving,
good for cross country - but dont forget the Pegase
- almost the same as the 19 but considered slightly
'better'.
The Libelle is a personal favourite with good performance,
looks and price. Club Libelle could be worth a look
too.
Not flown a PIK20 but heard they are not bad, got flaps
and cheap.
The LS-4 is reputed as a legend, and quite rightly
so. Still competitive in club class and great for x
country it is a good link glider between early hours
and more performance gliders. Down side being a bitty
more expensive.
I dont know if you have considered (obviously I dont
really know your budget) a Discus. It is easy to fly
and something that will take you a long way, and I
dont just mean kilometers.
Although never actually flown a DG200/202 I have heard
great things about them - good performance at ~45:1
and flaps it sounds as though a bit more experience
is needed, but when buying a first glider there is
no need to rush into it. DG gliders generally have
outstanding gel coats, even after many years of use.
I know I am edging on the more expensive gliders, but
why not 'share' the glider with a partner, and get
something a bit sporty like a Discus, ASW24 or DG300/303?
Finding a partner who flies, say, during the week means
you save half the rice you would have to pay and still
get to fly it pretty much when you want.
But just careful not to rush into things - be properly
trained in a flapped 2 seater before taking on an ASW20,
DG202 etc. A K6 can do great stuff - I know of someone
who did 750km in spain, and I am sure people have done
more.
Hope this helps broaden things out a bit! Hope you
find something good,
JR
Old March 10th 06, 11:04 PM posted to rec.aviation.soaring
That's a lot of rice!
My suggestion is to talk to the people in your area that fly these
ships. Lots more out there than 20s and Cirrii.
Shawn
Old March 11th 06, 04:06 AM posted to rec.aviation.soaring
Hi guys,
Jeff
I cannot comment on the flying characteristics of the Std. Cirrus. The
big concern is mounting the horizontal stabilizer. It can be fitted on
improperly with quite fatal results. I unfortunately witnessed a fatal
accident from this a couple years back. The NTSB was able to
replicate.
Please carefully read the NTSB report for a Std Cirrus in Hilltown, PA-
August 10, 2002.
Chip F.
Old March 11th 06, 11:34 AM posted to rec.aviation.soaring
Am I correct in presuming your choice of ASW20 vs Std
Cirrus rather than everything else is because these
or shares of, are available locally??
Yes, you could spend forever looking at the full spectrum
of gliders and you'll probably get a differing opinion
on each from everybody!
I'll just stick to giving my (purely personal) thoughts
on the above...
There's probably a scare story for every glider made,
so read about it and learn from other people's mistakes...ASW20
elevator works perfectly if you remember to connect
it, likewise Cirrus stabiliser if you fit it right!
I felt immediately at home on my first flight in the
ASW20. Cockpit is very roomy and controls fell easily
to hand without having to look at them. Controls felt
well harmonised though roll felt to me a little sluggish
with tips on.
Approach control is easy and short field landing with
the aid of full landing flap is unbelievable!
Only ever wire launched it, which it does well. BUT
it is extremely important to make sure that the flap
lever is fully engaged with the gate (and that is unworn),
as there have been serious accidents where the flaps
have slipped into full landing on the wire, causing
an immediate stall...I have heard of the same thing
happening on the airtow ground run, though with less
dramatic outcome.
Get a carbon sparred wing one - the others feel like
they come pre filled with water ballast, seriously!
As with all AS gliders of that era, they suffered from
short lifed gell coat and there's a lot of fiddly bit
to have refinished.
Can be good value for performance but I think they're
over handicapped for comp flying.
I again felt at home in the Std Cirrus on the very
first flight. I was a little apprehensive about the
all flying tail, but that was a non event - light yes
but not over sensitive.
Cockpit is huge and the panel is a little too far away
for the short-armed (like me) but a small price to
pay for really delightful handling. There's a good
reason for it being the #1 club class competiotion
choice.
Wings are reasonably light and fit easily with a single
pin.
Control connections can be fiddly until you are used
to them, but you can opt for an assembly access panel
now.
There are several different variations of stabiliser
fittings with the last few made having a 'normal' tailplane
and elevator.
All flying one CAN be fitted incorrectly but is easily
visually and physically checked and if you manage to
still miss it, will show up immediately if you do a
'positive' control check with a helper.
If you do go for one, make sure it has had the double
airbrake paddle mod. Original airbrakes were adequate
at best - the mod transforms it.
There is a really first class web site for Std Cirrus
owners.
www.standardcirrus.org
I have to admit to a degree of bias - having flown
around 50 different types of glider and motorglider
over the last 25 years, I own a Std Cirrus...
Hi guys,
I
Jeff
Std. Cirrus. The
It can be fitted on
witnessed a fatal
able to
replicate.
in Hilltown, PA-
August 10, 2002.
Chip F.
Old March 11th 06, 05:04 PM posted to rec.aviation.soaring
To go one step further, building on what Marc has said, I would
encourage you to continue to obtain aerobatic/spin training while you
are shopping for a glider. You will be glad you did. The more
knowledge, and familiarity you have with being outside the straight and
level, the more comfortable you will be in whatever glider you
purchase. Some of those "devil spin ships" you'll read about won't seem
so devilish, when you know what your looking at.
I have watched friends sweat pounds off, messing with those manual
control hookups. I wouldn't have a ship with those antique hookups.
They're an accident waiting to happen.
I can't speak from experience, about any ship but the Standard Class
SZD55. It is our first glass ship, which we bought about four years
ago. Automatic hookups, 44/1, comfortable cockpit. It has been a great
utility ship, meaning we've just put it together and flown the heck out
of it. 180 hours the first year.
We checked my son, seventeen at the time, out in it. He had time in
1-26,Grob, Puchaz(spin/aerobatic), PW-5, and a flight in an LS8. He
checked out in January, and flew it at Hobbs, in July, at the 2002 15
Meter Nationals.
Despite what you might hear, the SZD55 is a great ship. It's water
ballast system is simple, the landing gear retract system is a simple
overcenter lock with no detents to screw up, and all has been trouble
free.
We looked at a lot of ships, starting from the junk to the beautiful
ships. We settled with the 55, because it only had 275 hours on it, and
it represented the low hours. It was like new, and four years ago, we
got a great purchase price on it.
Enjoy!
Snoop
Old March 11th 06, 05:22 PM posted to rec.aviation.soaring
Although not glamorous...looking over the trailer situation
might make a difference in what you select. Either
one of these gliders can be assembled solo with a rigger
and a good trailer. A crappy trailer that involves
standing on one's head while twisting vertebrate to
put the wings on generally will reduce the number of
friends one has at the airport.
Old March 11th 06, 05:28 PM posted to rec.aviation.soaring
One other item. Windpath Corporation is the SZD55 dealer, and we have
had great support from Jerzy and the folks at WindWindpath Corporation
]path, located outside of Toronto.
snoop
Old March 11th 06, 05:57 PM posted to rec.aviation.soaring
it,
I urge you to consider a B or C models. I know many people - all
experienced pilots - that took off with the elevator not connected in an
ASW 20. It's just an ASW 20 problem, of course. I think it's a lot
easier to deal with a disconnected flap or aileron, and it seems these
are much less likely to be overlooked.
snip
dramatic outcome.
Do you mean the flaps slipped into a high speed position? It takes a
fair amount of force to pull the flaps into the landing position, but
they will slide easily forward into a negative flap position. This will
reduce the lift and cause the glider to descend, which might look like a
stall. Regardless, having the flap handle move itself to a new position
is a bad thing!
Frankly, most ASW 20 pilots consider the bendy wings a real asset and
part of their charm! It was one of the reasons it was so popular with
the ridge runners on the Alleghenies: those bendy wings give it a
smoother, more comfortable ride in turbulence. I certainly enjoyed the
smooth ride in my ASW 20C, and was a bit disappointed that the carbon
fiber wing of my ASH 26 E wasn't so forgiving. It's still bendy compared
to many gliders, but not like the ASW 20 and 20 C.
Regardless, I know the ASW 20 and 20 C did not have carbon fiber spars,
and I'm pretty sure the B didn't either. The B model did have much
heavier wings because of the extra fiberglass to needed carry the extra
water ballast it was rated for, but I think was mostly due to thicker
wing skins. Should you decide on an ASW 20 model, and you don't need the
extra wing loading, go for a C model.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
ASW20A and Cirrus Jeff Runciman Soaring 4 March 12th 06 06:06 PM
