Can anyone ID this engine?
Old March 11th 06, 04:45 PM posted to rec.aviation.piloting
Default Can anyone ID this engine?
http://i2.tinypic.com/r7pq4z.jpg
From a down aircraft in Cambodia?
The Monk
Old March 11th 06, 07:34 PM posted to rec.aviation.piloting
What do you call that, a VV-6 ? I wonder which way it was mounted on the
A/C.
"Flyingmonk" wrote in message
The Monk
Old March 11th 06, 07:57 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
("Flyingmonk" wrote)
2 + 2 + 2 cylinder engine?
45 degree + 45 degree + 45 degree?
What is it?
Montblack
Monk posted this engine link over in RAP.
Old March 12th 06, 12:03 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
What is it?
Montblack
Looks like an air compressor.
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Old March 12th 06, 02:10 AM posted to rec.aviation.piloting
Do a Google Images search on "Anzani Engine" to see some similar
configurations. I did not see a 6-cylinder
of this type, but there is a 3-cylinder (among other oddities like 6
and 10 cylinder radials).
David Johnson
Old March 12th 06, 03:08 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
What is it?
Montblack
My thoughts exactly---one bank looks smaller than the others--but that
might be the viewpoint--Incidentally, there were quite a few "W"
configured engines made just after WW-I ---Jerry
Old March 12th 06, 09:24 AM posted to rec.aviation.piloting
The Monk
Looks like a half Napier Lion w-12 engine.
palle
Old March 12th 06, 10:02 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
In article , says...
They look the same to me . . .
Wonder what the crank looks like - 3 main bearings?
GF
Old March 12th 06, 12:01 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
What you have in the picture, seems to be a French Lorraine 12 Ed aircraft
engine, circa year 1922. It is a liquid-cooled W-type engine (yes, 60+60=120
degrees most probably), but instead of 6-cylinder configuration, it's a
12-cylinder layout (believe or not). Capacity 24,4 litres, dry weight 425
kg. Power output 450 hp.
Check out this link. It has a picture of the engine.
http://www.planes-and-tanks.com/EngineShop/lorraine.htm
"Montblack" kirjoitti
What is it?
Montblack
Old March 12th 06, 03:24 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Yes, that's it...
"JP" wrote in message ...
"Montblack" kirjoitti ...
What is it?
Montblack
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
