F18 dogfighting
Old March 24th 06, 02:14 AM posted to rec.aviation.military.naval
Default F18 dogfighting
IS the F18 as good a dogfighter as the F14?
Will F14 aviators transistion over to the F18?
-John Cip
Old March 24th 06, 03:23 AM posted to rec.aviation.military.naval
"John C" wrote in message
According to F-18 drivers, it's better. According to F14 drivers, it's not
as good. Generally, the guy that gets to the ready room blackboard first
"won" the engagement.
Some but not all.
Old March 24th 06, 10:00 PM posted to rec.aviation.military.naval
Depends on the circumstances of the fight - they are different
aircraft, and each possesses unique advantages over the other. In a
weapons-free environment, it's hard to see F-18 drivers surviving
against swarms of AIM-54's. One can't be said to be a better dogfghter
than the other because there are probably so many different ways an
engagement can be fought.
Doubtless some already have.
Old March 25th 06, 11:20 AM posted to rec.aviation.military.naval
John, judging that is not as simple. It all depends to what role you
would like it to use. Hornet might be more dangerous in a dogfight, but
it is missing F-14's range and loiter time. Hornet had a wider array
of air-to-ground ordnance, but the F-14 is faster. It all depend on the
warfighting scenario, and for littoral warfare Hornets seems to be
enough.
As far as I know US Navy has three training pipelines for future
F/A-18E/F flyers:
- those transitioning from F-14A/B/D,
- those who flew F/A-18A/C before,
- those totally new to fighters.
Hope that helps.
Best regards,
Jacek
Old March 25th 06, 08:44 PM posted to rec.aviation.military.naval
Default Who Will Transition to Hornets and Who Won't? [was F18 dogfighting]
Most F-14 squadrons are getting full transitions from Tomcat to F/A-18E/F.
Of course, some aviators are always left on the table during the transition.
Can you elaborate on this point please? Which aviators and/or NFO are most
likely to get "left on the table" and why? For those that do *not*
transition to the Hornet community, what are their options?
Old March 26th 06, 02:01 AM posted to rec.aviation.military.naval
i'm not sure that the aim-54 has seen too many upgrades over its life,
and tend to think it is an overrated weapon.
i bet the long range phoenix shots would be a pretty easy kinematic
defeat by a knowledgeable bandit.
Old March 26th 06, 08:54 AM posted to rec.aviation.military.naval
Default Who Will Transition to Hornets and Who Won't? [was F18dogfighting]
On 3/25/06 3:59 PM, in article ,
"Ed Rasimus" wrote:
On Sat, 25 Mar 2006 14:44:44 -0500,
(Paul Michael Brown)
1.) Folks with insufficient retainability to justify re-qual expense
2.) Individuals of high seniority who will transition to staff
positions
3.) Those with marginal or less-than-outstanding performance reports
who seem likely to fail for promotion
4.) Crew-members with established separation dates.
5.) Individuals who opt out.
Nothing is guaranteed working for any large company.
That just about covers it, Ed. Good post. The advantage that the Tomcat
has is that the community is replacing aircraft squadron for squadron. That
having been said, some squadrons have transitioned to E's which has caused
them to leave some NFO's behind.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
www.thunderchief.org
www.thundertales.blogspot.com
Old March 26th 06, 03:18 PM posted to rec.aviation.military.naval
I won't say that the AIM-54 is a wonder weapon, however please consider:
That thing is coming at you at about Mach 4;
It is descending as it does so;
It is in a ballistic flight, which means no tell-tale smoke or contrails;
For such a terminal flight, it is a tiny thing, almost impossible to acquire
visually;
It can pull 18G at the end - granted, for a very limited time;
It has a huge fragmentation warhead which translates into a good-sized kill
zone.
Beatable, yes, easy, not by a very long shot.
_____________
José Herculano
Dogfighting US jets make villagers run for cover, By Nick Britten Otis Willie Military Aviation 0 January 15th 04 11:10 PM
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 10:47 PM
