OLC-Posting flights ending after 2400UT
Old March 31st 06, 07:37 PM posted to rec.aviation.soaring
Default OLC-Posting flights ending after 2400UT
Last year I had problems with flights completed on the west coast after
2400UT when another flight was also submitted for the next day.
In my situation I had a great (for me) competition flight which ended
after 2400UT which was submitted and accepted. Then the next day I
attempted to post another flight which by UT started on the same day as
the previous flight ended. Not only was the second flight rejected but
the first flight was removed!
I have not attempted to resolve this issue, at the time I was too busy
flying and just said: #@#@ OLC.
Has anyone else had this problem? How do you get around it? Bound to
happen to me again this year.
Old April 2nd 06, 01:32 PM posted to rec.aviation.soaring
You can claim multiple flights on the same day, they just have to have
different file names. What I suspect happened is that you erased the
logger after your first flight, and the logger started a new log file
with the same name. If you can, leave the old file in memory and the
logger will use a different name. If not, just rename the IGC file by
increasing the last digit in the file name by one. Do not change any
other characters that represent the date/mfg/serial code.
This also works if you made multiple X/C flights on the same log file
because you left the master on after landing. Again, claim the longest
flight as normal. Then copy the log file increasing the last digit by
one, and claim the additional flight by adjusting the start/end times
in the OLC web form. You will need to erase the waypoints and let OlC
re-optimize.
fuel subsidies for Angle Flight pilots sashley Piloting 17 September 11th 05 10:25 AM
Angel Flight and Part 91 Dave Butler Piloting 8 July 8th 05 04:43 AM
Radio outage at ZLA grounds flights A Guy Called Tyketto Piloting 0 September 15th 04 06:56 AM
FAA to End part 91 Sightseeing flights? Vaughn Rotorcraft 7 November 2nd 03 02:20 AM
Ownership and passengers Roger Long Owning 30 October 11th 03 03:00 PM
