DG303 Acro
Old April 6th 06, 02:02 PM posted to rec.aviation.soaring
Default DG303 Acro
I am looking at a DG 303 Acro. I would appreciate any comments about
the plane. It will be my first plane, 50+ hours in Grob 103, 1500+
hours soaring in hang glider, 5000+ miles XC in hang gliders.
I plan on flying this plane XC in UT and to start competing in sports
class.
Thanks in advance
Old April 7th 06, 04:42 AM posted to rec.aviation.soaring
Default DG303 Acro
Go for it.. I've flown the DG303, non acro version. I'm 5-10 and 200# and
broad of shoulder. I enjoyed flying the 303, solid feel, easy assembly. With
50+ hours in the Grob 103, I think the transition should be easy.
BT
"Ron Gleason" wrote in message
class.
Thanks in advance
Old April 7th 06, 06:26 AM posted to rec.aviation.soaring
Default DG303 Acro
I have flown the DG 303 Acro perfect for sports class here in OZ.
http://www.dg-flugzeugbau.de/tm-300-e.html
Mal
Old April 7th 06, 07:24 AM posted to rec.aviation.soaring
Default DG303 Acro
If you are looking at N303MR it's a sweet ship...
Old April 7th 06, 07:36 AM posted to rec.aviation.soaring
Default DG303 Acro
I can attest to that 8^)
Marc
Old April 11th 06, 05:32 AM posted to rec.aviation.soaring
Default DG303 Acro
There was a DG-303 Acro at our field for a couple of
years. I got a chance to wring it out a couple of
times. Very nice control harmony. Not quite the roll
rate of my Salto or Silent, but certainly acceptable.
Retains energy really well. Deep seating position
keeps the belts low on the hips with very secure feel.
Inverted flight with that long canopy is a real kick.
I spun it several times. Spins to the right were fairly
normal. The spin would begin to oscillate and would
recover after about 4 revolutions. Spins to the left
were a bit more interesting. After the first 3/4 revolution,
the nose would come way up, followed by a violent pitch
down, this was accompanied by a fairly significant
yaw oscillation. I was not able to continue the spin
after this event. Really got my attention the first
time, but subsequent tries were a kick. Would make
a good airshow maneuver. I suspect this spin anomaly
has something to do with turbulent air at the blowhole
inlet.
Should thermal well inverted! All-in-all a very nice
multi-purpose aircraft.
Bob C.
At 06:00 07 April 2006, wrote:
Ron
I brought a DG-303 Acro and flew it last year. I had
less than a
hundred hours total time in gliders and no XC experience
at time of
purchase. I flew over 10,000km in it last year, including
some great
flights out of Parowan. My decision was based on wanting
something
somewhat aerobatic as well as having OK XC performance.
In reality I do
very little aerobatics, but I still enjoy the doing
the few acros I do.
Also I know people locally (Hollister, CA) with DG-300s
so there was
some good local knowledge on the glider. Control layout/simularity
with
a club DG-1000 was also a factor.
It is an extremely comfortable glider and nothing beats
having your
feet sitting in the sun nice and warm during wave flights
while other
pilots are freezing their feet off. It flies well with
water. However
it is not the highest performance glider around, especially
without
water I've been in situations where you can definitely
see the
differnece on final glide against higher performance
gliders like a
Disucs 2 I fly with occasionally. It it is still more
glider than I'm a
pilot so I don't regret the purchase. In good conditions
you will
definitely want to water up and enjoy the benefit.
I would look for one with the forward tow hook. A forward
hook can be
retrofitted but it involves fiberglass work so check
the costs of that.
The forward hook is not all the way in the nose but
under your legs.
But it will make takeoffs with a cross wind easier
and safer. I've aero
retrieved out of places in pretty demanding cross
winds that I would
not attempt with the CG hook.
I am around 185lb in a parachute. I had a brass tail
wheel installed to
get the CG back to around 85-90% for aerobatics. For
XC I normally fly
with one or two weights in the front. The seat is very
reclined, get a
long softie or similar parachute and you will be in
comfort heaven.
Take out the silly factory air bladder behind the seat
and hurl it as
far as you can - if you need to inflate it the seat
wobbles from side
to side. If you need lots of padding behind the seat
make a custom shim
out of semiflexible foam. I'm 5'8' and I usually just
pack my
parachute bag and a polartec jacket (in case of outlandings)
behind the
seat back.
DG gliders often have beautiful gel coats. But they
are thicker that
more and more prone to cracking. Many DG 300/303's
and other models,
especialy those flown in cold wave conditions, will
have fine cracks in
the upper wing spreading out from the corner of the
spoiler box bakc to
the trailing edge. Wether it is worth having these
repaired or not is a
long conversation. There are used DG-303's kicking
around for sale at
the moment that the owners describe as in perfect condition
but that
have these cracks. Just make sure you know what you
are getting. If
it's not cracked now it probably will if you fly it
a lot. I've
managed to get a fine crack the gelcoat on one wing,
it happened on a
wave flight, most people can't even see it is there.
Spend some time and look over all the technical notes
on DGs web site.
You will find information that covers all the following
in good detail.
But here is a summary...Check the glider has the rudder
lower bearing
mods (stops the rudder potentially falling off) - subject
of several
disucssions on RAS recently. Any 303 built in the last
few of years
should also come with the canopy Roeger hook installed
and the mod that
adds a sping that holds the undercarriage handle more
firmly in the
locked position. Both are available as kits if the
glider does not have
these intalled. I'd not want to fly without these.
When I was looking
at 303's I was suprised how few owners were aware of
these - and I
talked to people who have had the handle pop out of
the detent and the
U/C collapse and they were still unwaware of the U/C
handle mod. If the
glider is older make also make sure the U/C gas strut
is well inspected
and maybe replaced during your annual.
DG-300/303's are probably more likely than most to
have gear collapses
if they don't have the U/C handle mod. Therefore check
carefully for
signs of damage or repair. My glider with ony 15 hours
time on it with
the previous owner showed signs of minor damage from
a gear up landing
or collapse on a grass runway. The seller somehow forgot
to mention
this :-)
I found on very long flights my ankles where hurting
from having my
legs so bowed around the instument console. The rudder
pedals bars
camber outwards pretty significantly to get your legs
around the
console. I brought angled rudder pedal plates with
from DG that just
clip on on in place of the factory plates and help
reduce much of this
angle and straighten my legs out and these worked great.
It's very
personal however, I fly with somebody in a DG-300 who
has long legs and
he put in pedal plates that go the other way (also
available from DG)
to bend his legs out even more.
Instument panel space is tight, and there are issues
with fitting long
case instuments like Becker radios or transponders
into the panel. I'm
very happy with how I've laid out my panel and mounted
two PDAs on
gooseneck off the panel. I can provide more details
if you want.
Pay particular attention during tailplane assembly,
as with other DG
gliders, it is possible to not have the elevator control
linkage end
correcectly enter into the elevator control 'funnel'.
Instead the
linkage sits outside of the funnel but with enough
friction against the
side of the funnel that the elevator will appear to
work during a
visual check. A positive control check should discover
the problem. I
know somebody who managed to fly and safely land a
DG-300 with the
elevator 'partially' connected like this - no he did
not do a positive
check.
Remember you are not really buying a DG glider, they
are made and
supported by AMS-Flight not DG. Some parts and support
are available
through DG, mostly the parts that are common ith other
G gliders. For
others you'll need to work with AMS-Flight reps or
the factory
directly. I've found DG easier to deal with and more
responsive to deal
with if it's a part they can supply.
Regards
Darryl Ramm
DG-303 6DX
any comments about
Grob 103, 1500+
gliders.
competing in sports
class.
Thanks in advance
Old April 11th 06, 04:57 PM posted to rec.aviation.soaring
Default DG303 Acro
Bob
Where was your CG position for these spins? I don't spin mine much but
with the CG at around 85% back I don't see exactly what you are
describing. I have seen some spin asymmetry before. For example with
the CG around 50% mine would do maybe one rotation to the right and
pop itself out, it would not want to rotate to the left at all. With
the CG back at 85% I see nice spin behavior to the left and right. I
have seen the strong pitch down, but not really noticed that being
asymetric. Now you've got me interested I'll play with spinning it more
(it's in the shop for work for a while)..
The only other glider I acro is a DG-1000/17m. A nice glider otherwise,
but what a pig,...both hands on joystick, big aileron push, c'mon roll,
please roll, roll you !@#$. I'd use a different word than harmonized
to describe the control forces. Stepping out of that into my DG-303 is
fantastic. The 303 Acro is a little more aerobatic than some people
seem to believe, for example tail slides as well as snap rolls and all
the usual stuff. Lots more capability than where I'm at.
I heard from Ron he has purchased a DG-303 Acro, now Ron you need to
find a good aerobatic instructor (with a two place ship) to go with
your new glider...
Cheers
Darryl
Old April 12th 06, 04:38 AM posted to rec.aviation.soaring
Default DG303 Acro
I don't recall where the CG was. It was a borrowed
glider, and I was within a few pounds of the owner's
weight. I think the asymmetry may have something to
do with slightly different positions of the blowhole
inlets. Or maybe I just have a heavy foot. Whatever,
the pitchover was a real attention-getter. I was surprised
how reliably I could duplicate it. I'll bet with wingtip
smoke, that would be a real crowd pleaser at airshows.
If I hadn't built the jet Silent, I'd be very interested
in a DG-303 Acro for airshow work. Too bad they don't
make a motor version of it...
At 15:00 11 April 2006, wrote:
Bob
spin mine much but
what you are
For example with
to the right and
left at all. With
left and right. I
that being
spinning it more
glider otherwise,
push, c'mon roll,
than harmonized
into my DG-303 is
than some people
snap rolls and all
at.
Ron you need to
ship) to go with
your new glider...
Cheers
Darryl
Old April 12th 06, 05:47 AM posted to rec.aviation.soaring
Default DG303 Acro
Mmm a DG-400 Acro, fueslage from a DG-400, wings from a 303 Acro, some
duct tape, a fresh parachute repack, ...
I agree on the pitch down, stomach in mouth stuff. The manual does warn
that "the DG-300 shows a very large nose down pitch after leaving [the]
spin".
Darryl
FS: DG 303 Acro - Perfect!!! [email protected] Soaring 3 June 23rd 05 03:01 PM
WANTED: Left wing G103 Acro II [US] F.L. Whiteley Soaring 0 July 20th 04 04:15 PM
What acro glider is this? Kristoffer Raun Soaring 9 February 19th 04 11:35 PM
Mid-Air at Turf, Acro boxes etc Rick Brown Soaring 0 January 24th 04 05:51 AM
Turf Soaring Mid-Air, Acro Boxes, Etc Rick Brown Soaring 0 January 23rd 04 03:44 PM
