Source Mu Metal USA
Old April 10th 06, 12:41 AM posted to rec.aviation.soaring
Default Source Mu Metal USA
Anyone have a source for MuMetal for shielding a Compass?
USA please
Hartley Falbaum
Old April 10th 06, 01:31 AM posted to rec.aviation.soaring
Aircraft Spruce has it.
Kevin Anderson
Soar 192
"HL Falbaum" wrote in message
USA please
Hartley Falbaum
Old April 10th 06, 01:37 PM posted to rec.aviation.soaring
Thanks Kevin
It is not in their online database. I'll call and ask.
I am moving the compass in my DG 800B. It is a PAI vertical card compass on
the instrument pod cover right now, but it produces a *large*, reversed HUD
right where I want to see out! I tried making a shield for it but it didnt
help much.
I am removing the clock and putting the compass in it's place. There is so
much wiring and the panel is compact. I think I will run into electrical
field problems-=so I want to be prepared.
Hartley Falbaum
"Kevin Anderson" wrote in message
Kevin Anderson
Soar 192
USA please
Hartley Falbaum
Old April 10th 06, 06:11 AM posted to rec.aviation.soaring
You don't want to shield your compass.
You can shield a speaker magnet if it is npt to close to the compass.
Having any ferromagnetic stuff near a compass is not a good idea.
Avoid magnetic fields (by proper routing of electric wires and discarding
magnets as in gps-antennae etc).
George
Old April 10th 06, 03:20 PM posted to rec.aviation.soaring
Hartley Falbaum
Hartley,
Since the root problem is glare from the compass, what about this
alternate solution:
Can you put window tint onto the front face of the compass?
The window tint film sold for car interiors may really cut the amount
of light hitting the compass markings and reflecting back out. You
could experiment with various levels of darkness.
This will probably be fine even if a little dark since you [usually]
don't fly after dark.
Chris
Old April 10th 06, 05:09 PM posted to rec.aviation.soaring
Worth a try--
Thanks
Hartley Falbaum
"chris" wrote in message
Hartley Falbaum
Hartley,
alternate solution:
Chris
KA6E and Foka 4 comparable metal ships - Laister Nugget LP15 Matthieu Soaring 18 June 7th 05 01:20 AM
P-51 wings: silver paint or natural metal ? Vicente Vazquez Military Aviation 7 July 13th 04 01:37 AM
A Remote Compass- java source [email protected] General Aviation 0 July 3rd 04 06:39 PM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 10:43 AM
A Source for Aluminum Ron Wanttaja Home Built 4 October 11th 03 01:38 AM
