Visibility is considered unrestricted if greater than 6 miles???
Old April 21st 06, 05:17 AM posted to rec.aviation.piloting
Default Visibility is considered unrestricted if greater than 6 miles???
Flying from Buffalo, NY, to Reading, PA, this afternoon, I call up
Cleveland Flight Watch to report a weather pirep.
"Visibility is restricted in haze to about one five miles," I include.
"45 Whisky," the voice responds, "visibility is considered unrestricted if
it is greater than six miles so I am going to put unrestricted."
"Huh?" I let slip out, "Really?"
"Yes, really," he answers.
If this is indeed true, I have been doing it wrong for almost 1,000 hours
now. Too late tonight for me to go digging through the AIM, but is this
really true?
Imagine being VFR through typical New England haze of 7 miles and being
told by Fligh****ch that pireps all over the region are reporting
unrestricted visibility.
That just doesn't seem right.
Peter
Old April 21st 06, 05:20 AM posted to rec.aviation.piloting
Now imagine the same thing in SoCal, which is where I learned to fly. I
think they have several definitions of "three miles", depending on the
day.
Jose
The price of freedom is... well... freedom.
Old April 21st 06, 05:39 AM posted to rec.aviation.piloting
It's not a conspiracy of mediocrity, it's due to a technical limitation
of the scatterometer technology used by ASOS's to determine visibility,
if I recall correctly. They can only really be accurate out to about 6
miles. A human with a Mark I Eyeball could pick a landmark furthre
away and provide a bigger distance, but for all intents and purposes,
the max visibility will be defined by the technical limitations of the
available data sources.
Of course, I might be dramatically incorrect, this was what I learned
from my instructor.
Ben Hallert
PP-ASEL
Old April 21st 06, 05:52 AM posted to rec.aviation.piloting
miles.
Then visibility should be reported as "greater than six" (which I have
heard)
Jose
Old April 21st 06, 05:06 PM posted to rec.aviation.piloting
Ben Hallert wrote:
snip
Since the source of a pirep is a pilot, not an automated weather station,
and the main recipient of a pirep is a pilot, not an automated weather
station, visibility should be reported as an estimation in the pilot's
opinion much greater than that which is artificially restricted by
automation.
In any event, I did call Buffalo FSS late last night to ask the specialist
about this and in his opinion the Cleveland specialist was incorrect.
Report visibility in the distance we see, were his words.
Again, had I been a low time VFR pilot launching on a cross country, I
certainly would want to know about haze limiting visibility, for even 10
miles and haze will appear much lower as the sun draws closer to the
horizon.
Peter
Old April 21st 06, 05:17 PM posted to rec.aviation.piloting
horizon.
This P6SM stuff is one of the (few) ways the ICAO weather reporting
system of TAF and METAR is inferior to our old SA/FA system. The old
FAs used to forecast visibility as 10, 15, 20, whatever was
appropriate. Now all that just gets folded into P6SM. For somebody
planning a VFR X/C (especially a student or inexperienced pilot),
there's a big difference between 6 miles and 20 (or even 10).
It's not like the computer models can't differentiate between them.
It doesn't even take any more characters to transmit. It's just plain
dumb that the information exists and is kept hidden.
Old April 21st 06, 05:39 PM posted to rec.aviation.piloting
"Ben Hallert" wrote in message
The short answer to the OP question is: YES!
This is not so much due to a "technical limitation", as it is due to
*history*.
The requirements forever (well, at least since the 1950's), have been that
.... no restriction to visibility is reported, whenever the visibility is
more than 6 statute miles... In other words, an observation may *not* read
7 miles in haze, or 7 miles in mist, etc. *Precipitation* may be reported
at visibilities greater than 6, but you do not report
non-precipitation-phenomena by itself. You would just report "visibility 7
statute miles", period.
Thus, a visibility above 6 statute miles, as per the technical requirement
of observing weather, is "not obstructed".
Now, in general, when you had manned systems, airports attempted to have
visibility markers out to *at least* 15 statute miles, and a report of 15
was the norm for "unrestricted" visibility. Thus, you kind of knew that
something was going on, should that station suddenly report "10", or "8",
even if he did *not* show the reason.
However, with the increasing advent of automated systems, you have lost that
extra human insight, because the technical requirement is met by saying....
"greater than 6" equals "not obstructed"..... so you might get "greater than
6" on a day when visibility is 50, and from the same station you get
"greater than 6", when visibility is 7.
In that sense, I *DO* say that it *is* a conspiracy of mediocrity. To
automate things, and to meet only the basic requirements of producing a
METAR... a lot of the stringent reporting practices of the 60's and 70's
seem to be slipping away.
Old April 22nd 06, 04:53 AM posted to rec.aviation.piloting
Thanks, Ice. I appreciate your knowledgeable weather contributions to this
group.
Peter
Old April 22nd 06, 07:38 PM posted to rec.aviation.piloting
"Icebound" wrote in message
When I learned to fly in the Denver area, I got accustomed to wx reports
that included "clear and 70". The guys in the tower at Stapleton would just
look south. If they could see Pike's Peak, the vis was 70. Easy.
Infallible. No gizmo to break.
Old April 22nd 06, 11:46 PM posted to rec.aviation.piloting
"Peter R." wrote in message
really true?
It isn't right. Perhaps you misunderstood him or perhaps he didn't explain
it well. If visibility is 7 miles or more the restriction to visibility is
not included in the report. If haze is reducing the visibility to 6 miles,
for example, the visibility is reported as 6 miles in haze If haze is
reducing the visibility to 7 miles the visibility is reported as 7 miles
with no mention of what is limiting visibility..
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Kid day at the airport... Jay Honeck Piloting 92 September 20th 05 05:42 AM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 09:52 PM
