Question for the Turbine pilots.
Old April 22nd 06, 05:19 PM posted to rec.aviation.rotorcraft
Default Question for the Turbine pilots.
We have a doctor who just bought a 206 and after less than a month the
chopper has been sent for a new engine. I heard he had a "Hot Start" and
burned out the engine.
While I'm both fixed wing and helicopter certified I have zero
experience with jets so what did he do? And what's it gonna cost him?
Old April 22nd 06, 07:16 PM posted to rec.aviation.rotorcraft
The indication of a hot start is when the TOT (turbine outlet temp) runs
away and goes far too high. Internally its casued when the flameball does
not form correctly as a result of too much fuel, too high of a pre-existing
temperature, or incorrect/sufficient airflow. It requires an inspection and
if he melted enough stuff it could cost around $90,000.
Bart
"601XL Builder" wrDOTgiacona@coxDOTnet wrote in message
While I'm both fixed wing and helicopter certified I have zero experience
Old April 22nd 06, 09:45 PM posted to rec.aviation.rotorcraft
OUCH! :-(
"B4RT" wrote in message
pre-existing temperature, or incorrect/sufficient airflow. It requires an
inspection and if he melted enough stuff it could cost around $90,000.
Bart
Old April 23rd 06, 06:42 PM posted to rec.aviation.rotorcraft
Well they yanked off the rotor blades and put the 206 on a truck so my
bet is he burnt up what could be burnt.
Steve R wrote:
OUCH! :-(
Bart
Old April 30th 06, 06:58 AM posted to rec.aviation.rotorcraft
He must be very new to turbines. Had to be more than a hot start, must
have been a fire. Hot start usually would just require inspection of the
burner can. Removing can and power turbine would probably be something a
mechanic could do on site in a few hours and ship to facilitate the
inspection. Moving the complete helicopter is a waste unless being
returned to seller as a warranty return. A simple hot start only
requires a flight test procedure and at the worst can be flown to a
repair facility with in reasonable distance.
Steve R wrote:
OUCH! :-(
runs away and goes far too high. Internally its casued when the
flameball does not form correctly as a result of too much fuel, too
high of a pre-existing temperature, or incorrect/sufficient airflow.
It requires an inspection and if he melted enough stuff it could
Bart
the chopper has been sent for a new engine. I heard he had a "Hot
Start" and burned out the engine.
him?
Old April 30th 06, 06:02 PM posted to rec.aviation.rotorcraft
Wow,
"..at the worst can be flown..." ? WTF DUDE!. Are you crazy?
I don't want to be harsh, but if you do have a hot start call a factory
authorized repair station for your engine or aircraft (in this case Rolls
Royce / Bell) and follow THEIR advice. DO NOT FLY YOUR MACHINE unless you
get sage wisdom and authorization from one of these.
Bart
"RPE" wrote in message
. com...
returned to seller as a warranty return. A simple hot start only requires
a flight test procedure and at the worst can be flown to a repair facility
do
Old April 30th 06, 06:38 PM posted to rec.aviation.rotorcraft
. com...
Sorry, I disagree (with that very last part). I've released a lot of
aircraft as "Certified Safe for Flight" and I would NOT allow even a one-way
flight after an event like that. If the bird is down, it's DOWN. Aircrew
lives depend on my signature and I don't take that lightly.
They can 'fly' it over on the back of a trailer.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Question for Pressurised Baron pilots DeltaDeltaDelta Piloting 12 December 4th 03 01:54 PM
