ELT Recommendation
Old April 25th 06, 09:19 AM posted to rec.aviation.owning
Default ELT Recommendation
Looking to install an ELT, does anyone have any recommendations. The
ACK ELT-01 seems okay.
I dont want a 406MHz ELT as i'll be purchasing a portable 406MHz PLB to
supplement.
Thanks
Dean
Old April 25th 06, 10:51 PM posted to rec.aviation.owning
Get the AK-450
http://www.chiefaircraft.com/cgi-bin...t/ELT/ELT.html
It uses 6 Duracell D batteries and they're a lot cheaper to replace,
not to mention that you can use them in flashlights after you remove
them from the ELT.
Old April 26th 06, 03:39 AM posted to rec.aviation.owning
"Dean" wrote in message
supplement.
Thanks
Dean
Both the ACK E01 and the AmeriKing AK450 use D cells for the main unit
(there is another small battery in the remote panel).
The ACK uses 8 Dcells while the AK450 uses 6Dcells and has a mike jack for
transmitting voice. The ACK unit was a better machanical fit to replace the
old D&M in my Cessna, so that is what I got. But I think either one of
these units will work just fine. It looks like the AK450 is going for about
$30 less these days. YMMV
John Severyn
@KLVK
Old April 26th 06, 10:08 AM posted to rec.aviation.owning
Don't you have to change your ELT to 406 Mhz anyway (B4 2009)?
check ARTEX 406 M
supplement.
Thanks
Dean
Insurance company recommendation? John Doe Owning 7 October 27th 05 09:07 PM
Nicopress Swaging Tool - Availability - Retraction of Recommendation! Gary T. Ciampa Home Built 0 February 6th 05 01:00 AM
Handheld Tranceiver Recommendation nospamPlease Piloting 44 April 2nd 04 05:50 AM
Escrow Service - Use? Recommendation? Carl Orton Owning 2 February 6th 04 09:41 PM
ASW 20 Recommendation? Eric Greenwell Soaring 1 August 11th 03 07:56 AM
