Getting started in the OLC League this weekend
Old April 27th 06, 03:40 AM posted to rec.aviation.soaring
Default Getting started in the OLC League this weekend
We now have well over 100 clubs set up and ready to compete in the OLC
League in the US. So now it's time to work on how to get started in the
competition. It may take a while for clubs to catch on, so the early
adopters will have a big advantage. As long as one club member scores
on one day of the weekend, your club will score a minimum of 1 point
for the round. But if only 20 other clubs score, you will score a
minimum of 30 points for the round. So it pays to get started early.
To score you will need to get at least 50 handicapped points in 2.5
hours using only 4 legs. If you are flying in a SGS 1-26 or 2-33, or
any other glider with a handicap less than 64, the required distance is
less than 20 miles. Since you get 4 legs, each leg only has to be 5
miles long.
So the simple strategy is to pick a turnpoint 5 miles upwind, climb up
over the home airfield, then head out to the turnpoint, always staying
above a safe glide back to home. Round the turnpoint, and fly home.
Climb back up and do it again. Then, and this is important, climb back
up to to your start altitude. If you did this in less than 2.5 hours,
congratulations, your flight qualifies for the OLC League.
So let's say you want to maintain a conservative 10:1 glide to home.
Then, at 5 miles out, you only have to be 0.5 miles higer than pattern
altitude, or around 3500' AGL. This should be doable on a decent
soaring day in most places. Remember that you are working upwind, so
the tailwind provides an extra safety factor.
Of course if you are flying a higher performance glider, you will have
to go a little further, but you can see that this is doable in any
glider on a good day almost anywhere. All you need to do is carry an
FAI approved logger to claim your flight.
Naturally you should only attempt this if you have landable terrain
upwind, just in case. If you can make your turnpoint an airport, that's
even better. You also want to have the basic skills for X/C flight. The
Bronze Badge program is an excellent introduction to X/C, and this
basic OLC League task should be suitable for anyone who has properly
earned this award.
This task is also an excellent opportunity for dual instruction in X/C
procedures. It creates a goal-oriented traning situation, which is an
excellent learining opportunity. And if the goal is completed, it
creates an instant trophy in the form of an OLC claim for all to see.
Plus it can be done in any two place trainer, with minimal chance of an
actual off field landing.
So it's time to start thinking about how to get your club started in
the OLC League competition. It doesn't require anything special, other
than the logger. So start thinking about how to how to get your club
involved. The competition starts this weeked!
Old April 27th 06, 05:01 AM posted to rec.aviation.soaring
miles long.
earned this award.
Doug,
you should write an article for the SSA E-newsletter and Soaring
Magazine about OLC. I don't know of many members in my club who read
RAS.
regards,
Chip F.
miles long.
earned this award.
Doug,
RAS.
regards,
Chip F.
Old April 27th 06, 06:07 AM posted to rec.aviation.soaring
Though good ideas, I think even fewer read SSA eNews. Soaring would be
at least two months out. Probably better to forward Doug's posts to
your club's member list.
Frank Whiteley
Old April 27th 06, 08:02 PM posted to rec.aviation.soaring
Doug, thankyou for an excellent write-up and the encouragement
for the lower-performance guys to compete. May I ask
two questions on the scoring ?
First, what happens if there are only two flights from
a club on a weekend ? Is the average speed calculated
on the sum of the speeds divided by two, or divided
by three ? Makes a difference if one flight is very
fast and the other very slow, as the slow flight might
either hurt the club or benefit it.
Second, from your example, the start altitude is the
lowest point after release, setting the start time
and start position. So it is the altitude at the base
of your first climb, and your first time to climb is
counted in the speed determination. But after you
finish the last leg, and have re-achieved that low
start altitude, the scored flight is not necessarily
over. If you stay above that start altitude for another
hour, not going anywhere in particular but just enjoying
the day and maybe drifting a mile or two downwind,
the small extra distance will be included as part of
your last leg and all the time counted until your two
and half hours are up. This could hurt your speed
quite a lot; so you might want to consider landing
pretty soon, or staying below your start altitude for
the rest of your flight. Is this really how it works,
or am I mis-interpreting the scoring description ?
Fly safe,
Ian
compete in the OLC
get started in the
on, so the early
club member scores
of 1 point
will score a
started early.
points in 2.5
1-26 or 2-33, or
only has to be 5
miles long.
upwind, climb up
always staying
and fly home.
climb back
than 2.5 hours,
League.
glide to home.
higer than pattern
on a decent
upwind, so
you will have
doable in any
to do is carry an
landable terrain
an airport, that's
for X/C flight. The
X/C, and this
who has properly
earned this award.
instruction in X/C
which is an
completed, it
for all to see.
club started in
special, other
to get your club
Old April 27th 06, 08:05 PM posted to rec.aviation.soaring
Are clubs like mine that have no home base out of luck? (We're flying
out of two or three locations this year. Maybe more ...)
-Homeless in AZ
Old April 27th 06, 08:11 PM posted to rec.aviation.soaring
Hmm, according to the web site the OLC goal is to encourage XC flying.
Staying within a conservative glide from home is not considered cross
country and defeat the purpose of the OLC IMHO.
Ramy
miles long.
earned this award.
Old April 28th 06, 12:31 AM posted to rec.aviation.soaring
Ramy, everyone needs to start somewhere. This post only encourages
people to start small. Obviously as clubs and their pilots get more
experience, they will fly further and faster and score higher. So I
disagree with your concluson that starting off within gliding distance
of home is not encouraging XC flying. I think the purpose of the OLC is
to allow everyone to compete at their level. It truly is the people's
contest.
Old April 28th 06, 12:38 AM posted to rec.aviation.soaring
Hi Ian,
You finish height can't be lower than your start but there is no reason it
can't be higher than your start. There is no need to land right away.
I think some people will get caught by doing standard tasks where the start
altitude is higher than the finish. If they finish low and never get as
high as their release or low point then the system will find a shorter task
in the flight in which the start height equals the finish height. If the
"sprint" section is less than 2.5 hours long then 2.5 hours is still used as
the task time - which can lead to slow speeds. So, as Doug suggested, be
sure to do a climb after you finish if necessary to make sure your finish
height is greater than or equal to your start height. Remember that it is
all optimized to find the fastest 2.5 segment.
Paul Remde
"Ian Cant" wrote in message
Fly safe,
Ian
compete in the OLC
get started in the
on, so the early
club member scores
of 1 point
will score a
started early.
points in 2.5
1-26 or 2-33, or
only has to be 5
miles long.
upwind, climb up
always staying
and fly home.
climb back
than 2.5 hours,
League.
glide to home.
higer than pattern
on a decent
upwind, so
you will have
doable in any
to do is carry an
landable terrain
an airport, that's
for X/C flight. The
X/C, and this
who has properly
earned this award.
instruction in X/C
which is an
completed, it
for all to see.
club started in
special, other
to get your club
Old April 28th 06, 12:57 AM posted to rec.aviation.soaring
Where did you find this information?
Under the League rules section, it states that OLC will publish a list
of clubs/home airfields, but for the life of me I can't find it.
US SSA-OLC League new for Summer 2006 Season! Doug Haluza Soaring 20 April 26th 06 04:54 PM
US SSA-OLC League new for Summer 2006 Season! Doug Haluza Soaring 0 April 12th 06 07:15 PM
Weekend IFR ground school with Aviation Seminars Brad Z Instrument Flight Rules 1 September 20th 04 04:05 PM
Announcement: M-ASA Weekend Open (USA East Coast) Chris OCallaghan Soaring 1 June 29th 04 07:30 PM
The War's Lost Weekend WalterM140 Military Aviation 32 May 18th 04 08:42 AM
